3 registered members (2Sharp, kankeL, LightSpeed), 97 guests, and 17 spiders.
John V6 434
+8Rich 403
Hawki 183
Rear brake drums - 1980 4/4
by BigLes. 13/07/20 06:53 PM
Its finally here!!
by NickCW. 13/07/20 02:55 PM
Outdoor Cover for M3W
by WilsonLaidlaw. 13/07/20 02:42 PM
Brake problems after lockdown
by teifistar. 13/07/20 12:31 PM
Breakdown tow
by Pontruggermogger. 13/07/20 10:06 AM
Morgan jackets
by NickCW. 13/07/20 07:42 AM
Driver dies in Morgan accident
by Taffmog. 12/07/20 11:29 PM
peek a boo
Donington Sunday (part 2)
Donington Sunday
My old Matt black Aero
No More Five Mile Limit
GJT, Saxonian, GlenB 4475, Simon m wright, dominicalbarn
7054 Registered Users
Topics38,781
Posts637,690
Members7,054
Most Online1,033
Dec 28th, 2019
john humphreys
Plus 4 Push Button Start? #642394
05/06/20 02:45 PM
05/06/20 02:45 PM
haverfordwest
Nostalgiajohn Offline OP
haverfordwest
Hi all, Has anyone ever considered or fitted a "Push Button" start to their Morgan? Asking as I quite fancy the idea for my 2011 Plus 4.
Re: Plus 4 Push Button Start? [Re: Nostalgiajohn] #642397
05/06/20 02:54 PM
05/06/20 02:54 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
Someone has there is thread on here somewhere about it.
Regards Richard
1994 Connaught Green +8 prev
Re: Plus 4 Push Button Start? [Re: Nostalgiajohn] #642398
05/06/20 03:03 PM
05/06/20 03:03 PM
East Harling, Norfolk UK
Richard Wood Offline
I believe they all require the use of the ignition key/lock which defeats the object to me. This includes the latest Plus Four which further requires you operate the key against the normal starter detent spring to arm the starter button doh
Having said this I thought it period appropriate to have a button Start for the 1936 diesel twin on my narrowboat.
Ignition switch is simple on/off.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Plus 4 Push Button Start? [Re: Nostalgiajohn] #642399
05/06/20 03:15 PM
05/06/20 03:15 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
On my 64 4/4 I installed a push button start switch bought from Summit Racing here in the US, did not need the ignition key but did install a power switch. I also installed a cut off switch in the rear of the car for security purposes, although I have never actually used it. I ran this for many years with no problems then switched to the M3W style military switch that supplies power and also starts.
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Plus 4 Push Button Start? [Re: Nostalgiajohn] #642404
05/06/20 03:35 PM
05/06/20 03:35 PM
The other issue is how you want the Start button to operate, one touch with auto start sequence or starter operating for as long as you press the button much like early cars. My Roadster for example has an automated start sequence controlled by the powertrain control module. If you don't choose the Start button option a link is added to compensate but you still get the automated start requiring you only operate key in start position momentarily.
Upshot is if your car had a factory start button option when new it should be easy to retro-fit. Otherwise the only practical option is to add an old style starter button and wire in parallel with the key start.
Re: Plus 4 Push Button Start? [Re: Richard Wood] #642436
05/06/20 05:46 PM
05/06/20 05:46 PM
East Anglia
madmax Offline
madmax  Offline
East Anglia
All the start buttons seem to need a key to arm , safety reasons ?
Re: Plus 4 Push Button Start? [Re: Nostalgiajohn] #642439
05/06/20 05:57 PM
05/06/20 05:57 PM
Aberdeenshire
Image Offline
Image  Offline
Aberdeenshire
I guess the same reason if you turn the key on a normal setup but don't quite start the engine you have to switch off before having another try ...to stop you engaging the starter while the engine is already running
Re: Plus 4 Push Button Start? [Re: Image] #642448
05/06/20 06:17 PM
05/06/20 06:17 PM
East Anglia
madmax Offline
madmax  Offline
East Anglia
Interestingly on the newplus six and newplus four you have to turn the key then press the start button once and then press the start button again to actually start. Whereas on my Mog you turn they key and then press the start button and away you go !
Re: Plus 4 Push Button Start? [Re: Nostalgiajohn] #642449
05/06/20 06:18 PM
05/06/20 06:18 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
That is my understanding.
The child in me loves the idea but in reality it is pointless
2006 Indigo Blue Roadster S1
Re: Plus 4 Push Button Start? [Re: Nostalgiajohn] #642450
05/06/20 06:19 PM
05/06/20 06:19 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Mogs already have glitchy electrics as seen by the many query threads on here
So why add further connections, wiring & a vanity switch ?
Moderated by  Aeroman, Simon
