20 registered members (Themorganeer, Andrew Kidney, DWF, Budster, Ray, Phil4/4, RB1, LE52MOG, ChrisP, MorgantheFreeMan, PeterVD, JMcL, Rog G, John07, Arwyn Williams, TBM, truckin-on, Doar, Donkervoort, Image), 124 guests, and 18 spiders.
John V6 434
+8Rich 409
Hawki 183
Rear brake drums - 1980 4/4
by BigLes. 13/07/20 06:53 PM
Its finally here!!
by NickCW. 13/07/20 02:55 PM
Outdoor Cover for M3W
by WilsonLaidlaw. 13/07/20 02:42 PM
Brake problems after lockdown
by teifistar. 13/07/20 12:31 PM
Breakdown tow
by Pontruggermogger. 13/07/20 10:06 AM
Morgan jackets
by NickCW. 13/07/20 07:42 AM
Driver dies in Morgan accident
by Taffmog. 12/07/20 11:29 PM
peek a boo
Donington Sunday (part 2)
Donington Sunday
My old Matt black Aero
No More Five Mile Limit
GJT, Saxonian, GlenB 4475, Simon m wright, dominicalbarn
7054 Registered Users
Topics38,781
Posts637,658
Members7,054
Most Online1,033
Dec 28th, 2019
Aeroman
Page 1 of 5 1 2 3 4 5
Steel Sprocket #642474
05/06/20 07:07 PM
05/06/20 07:07 PM
Logan, Ohio USA
Dutch Offline OP
Dutch  Offline OP
Logan, Ohio USA
I'd like to replace my original aluminum rear sprocket with the steel one. Does anyone know where I might buy one in the US ?
Dutch Junge
194 Mound St
Logan, OH USA 43138
Re: Steel Sprocket [Re: Dutch] #642482
05/06/20 07:25 PM
05/06/20 07:25 PM
New River Valley, VA
rcmatt Offline
rcmatt  Offline
I would try one of the dealers. I got a replacement through the Morgan dealer in SF.
Rodger
2004 Plus 8 (wife's)
Re: Steel Sprocket [Re: Dutch] #642487
05/06/20 07:49 PM
05/06/20 07:49 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
MMC will sell you a heavy steel rear sprocket for a fairly sizeable sum of money and it will last well. There is an alternative with the Supermax poly overlay, an American company. Information on www.supermax.net or you can email vyvyanross@yahoo.com Several M3W's have run for many miles successfully with these sprockets. There was another sprocket manufactured somewhere in Europe but I don't think they are currently available, so that is the off the shelf choice at the moment.
Re: Steel Sprocket [Re: Dutch] #642489
05/06/20 07:58 PM
05/06/20 07:58 PM
planenut Offline
planenut  Offline
One other thought about rear sprocket replacement, Phil Bleazey does a belt drive to chain drive conversion. I think that, at the moment, it is more than a nuts and bolts job but it may be worth a look on his website. http://www.bleazey.co.uk/M3W.html#reason . It's always interesting to have a look at what Phil is up to anyway. If you do end up with a new steel sprocket from a Morgan dealer, don't dispose of the alloy one, I am sure it will come in handy for a chain or Supermax conversion at some point.
Re: Steel Sprocket [Re: Dutch] #642500
05/06/20 08:56 PM
05/06/20 08:56 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
Morgan Spares (https://morgan-spares.com/) will do the Supermax poly overlay (look in the three wheeler accessories section) for your sprocket and source the steel sprocket, I would give Linda a call to discuss options.
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Steel Sprocket [Re: Dutch] #642508
05/06/20 10:35 PM
05/06/20 10:35 PM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
I have a used one, as I replaced it with a Supermax unit.
If going the Supermax route you can deal directly with Supermax and save some dollars.
2012 M3W #458
Iowa, U.S.A.
Re: Steel Sprocket [Re: Bitsobrits] #642515
06/06/20 02:05 AM
06/06/20 02:05 AM
Logan, Ohio USA
Dutch Offline OP
Dutch  Offline OP
Logan, Ohio USA
A used steel one ?
Dutch Junge
194 Mound St
Logan, OH USA 43138
Re: Steel Sprocket [Re: Dutch] #642516
06/06/20 02:41 AM
06/06/20 02:41 AM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
Originally Posted by Dutch
A used steel one ?
Yes. The car had about 8500 miles on it when I bought it, and I'm not sure when it was fitted, so it has less than 8500 miles for sure. Keep in mind the steel sprocket is intended for use with the black center hub. With the silver hub I believe it would be too far inward (towards the tire).
I changed to the Supermax one to reduce weight and to see if it made any difference to the annoying sound coming from the rear. It didn't as the sound is apparently coming from the bevel box only.
2012 M3W #458
Iowa, U.S.A.
Re: Steel Sprocket [Re: Dutch] #642517
06/06/20 03:39 AM
06/06/20 03:39 AM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
I wonder if anyone has experimented with hydraulic drive systems?
It would be much more quiet, if it worked.
Stephen
2019 M3W piling on the Covid miles
Re: Steel Sprocket [Re: LightSpeed] #642518
06/06/20 04:56 AM
06/06/20 04:56 AM
Stourbridge UK
Morph Offline
Morph  Offline
Stourbridge UK
Whilst it could be built, a hydraulic drive system compared to belt drive doesn’t offer many advantages;
Hydraulic drive - High torque, low speed, heavy, expensive, issues with heat build up
Belt drive - Low torque, high speed, lightweight, cheap, less issues with heat.
The above is relative to each other but that is why hydraulic drive is used in construction equipment and belt drive is used in motorbikes etc.
Following the motorbike theme, chain or shaft drive would be a more viable alternative to belt drive.
No Morgan yet...
Moderated by  Aeroman
