Morgan Aero 8
11 registered members (+8Rich, Alistair, John07, jackmorini, xc68anc, vbalddave, deano, Gambalunga, TBM, Rog G, Sinbad), 134 guests, and 26 spiders.
John V6 436
+8Rich 399
Hawki 173
MORGAN trip around Malvern/ the Hills
by xc68anc. 15/07/20 09:03 AM
Rubber mat air dam
by 1bigfish. 15/07/20 02:45 AM
New member in Herts
by LouStar. 14/07/20 10:26 PM
Turn signal
by Mc Black. 14/07/20 05:26 PM
Seawolf in Port today
by +8Rich. 14/07/20 04:03 PM
Hi From Somerset
by Eastertown. 14/07/20 02:58 PM
Back with three wheels on my wagon
by donaldosaurus. 14/07/20 01:05 PM
peek a boo
Donington Sunday (part 2)
Donington Sunday
My old Matt black Aero
No More Five Mile Limit
Brize, Kevin Hawkins, GJT, Don70, Eastertown
7062 Registered Users
Topics38,792
Posts637,969
Members7,062
Most Online1,033
Dec 28th, 2019
No Birthdays
Aero 8 Hot air flow from the steering column #647485
29/06/20 10:38 PM
29/06/20 10:38 PM
TV5R Offline OP
TV5R  Offline OP
Hi all ,
I leave in south of France and have some hot (45-60°c) air coming from the steering of my aero série 1 ( not the heater matrix !) .
I think it's the heat from the exhaust manifold but it seems all oem thermal screen are in place .
Does anyone as the same issue and how it could be solved ?
Re: Aero 8 Hot air flow from the steering column [Re: TV5R] #647487
29/06/20 10:59 PM
29/06/20 10:59 PM
SimonH Offline
SimonH  Offline
It will be the hole around the column where it goes through the bulkhead
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Aero 8 Hot air flow from the steering column [Re: TV5R] #647490
29/06/20 11:18 PM
29/06/20 11:18 PM
TV5R Offline OP
TV5R  Offline OP
Yes I think but is it usual on s1 ?
Re: Aero 8 Hot air flow from the steering column [Re: TV5R] #647503
30/06/20 03:58 AM
30/06/20 03:58 AM
Beaumont de Lomagne, France
Philippo Offline
Philippo  Offline
Hello, don't recall having this issue on my S1 Aero 8. Where are you in the south of France? I live halfway between Montauban and Auch and if you're not too far away I'm quite happy to have a look for you and if necessary we can put it on the four poster. I don't have anywhere near the knowledge or expertise of Simon, but did all my own maintenance and repairs for 8 years and 40,000km so learnt my way around the car a bit.
Cheers
Philip
4/4 4 seater 1974 (to be replaced soon by in-build 1985 +8 4 seater)
Malone F1000
Re: Aero 8 Hot air flow from the steering column [Re: TV5R] #647538
30/06/20 09:11 AM
30/06/20 09:11 AM
Hampshire
Alistair Online happy
Smile, it confuses them
Alistair  Online Happy
Hampshire
On the S1 the heat soak did seem a little more obvious when the car was warm. The transmission tunnel and other elements around the cabin did seem to get warmer than later cars. This might also be felt and making you more aware of it.
Just time to burn a little more petrol before dinner.
Re: Aero 8 Hot air flow from the steering column [Re: TV5R] #647618
30/06/20 03:08 PM
30/06/20 03:08 PM
Cambridge UK
Stephen888 Offline
Stephen888  Offline
Cambridge UK
Andreas has a garage in Castelnau D'Auzan. He has 40 years experience with Morgans, looked after my +8 for twenty years before moving to France around 10 years ago.
https://www.garageandreas.com/
1980 +8 Blue
Stephen
Re: Aero 8 Hot air flow from the steering column [Re: TV5R] #647710
30/06/20 08:40 PM
30/06/20 08:40 PM
Essex/Herts border
Volvos60s60 Offline
Volvos60s60  Offline
Essex/Herts border
I had this'heat' issue on my S1 where the tip of the handbrake became also too hot to touch on a long journey. I was simply advised by the supplying garage that 'they all do that sir....'. To be frank, I think that is the case, the engine bay gets very hot
Re: Aero 8 Hot air flow from the steering column [Re: TV5R] #647722
30/06/20 09:28 PM
30/06/20 09:28 PM
TV5R Offline OP
TV5R  Offline OP
Many thanks for all reply .
I don't find the time to investigate more because Some other cars were needing more attention but will let you know asap.
I also do all by myself on my cars for a long time then the goal is to sort it if not usual !
Like some TVR you can feel the heat of exhaust and gearbox but in that case there is an higher flow coming from the steering .
"Phillipo" , why not meeting you ( we are not too far, I.m located 50km west of Toulouse ) and compared our cars for any thermal screen different design or miss?
The car is RHD, just in case .
Fred.
Re: Aero 8 Hot air flow from the steering column [Re: TV5R] #647771
01/07/20 08:02 AM
01/07/20 08:02 AM
aerotaff Offline
aerotaff  Offline
Air con directed on the footsie's is the only way forward Fred.
Em
Re: Aero 8 Hot air flow from the steering column [Re: TV5R] #647810
01/07/20 12:03 PM
01/07/20 12:03 PM
Hampshire
Hampshire
You can get heat shielding material to apply to the panels to reduce this, it also lowers the cabin sound level (ha ha) a little.
I would recommend going down the ventilation route to reduce the heat build up in the engine bay first.
Moderated by  Aeroman, Simon
