4 registered members (Graham, G4FUJ, yobtaf, Andrew Kidney, xc68anc), 198 guests, and 23 spiders.
+8Rich 394
John V6 331
Alistair 125
Hawki 123
Retrofit cruise control?
by SFG. 12/08/20 10:05 PM
Oil Change Question
by sbarracl. 12/08/20 08:35 PM
Ten more louvres on my wagon.
by meabh. 12/08/20 08:33 PM
Storm brewing.
by sospan. 12/08/20 08:26 PM
Fuel Gauge
by Clipper. 12/08/20 07:41 PM
Rear parcel shelf any advice
by FrancisD. 12/08/20 05:28 PM
M3W as a Delivery Van?
by 3Gs. 12/08/20 04:13 PM
Sunnier times ahead
riding through the montains
SNOWDONIA B4407/A543
GTN Soft top re-fitted
GTN Visors
Renat, StephanCarstens, Allthegearnoidea, David Aldridge, michael k76
7098 Registered Users
Topics39,059
Posts643,099
Members7,098
Most Online1,033
Dec 28th, 2019
Jeremy Edwards
Page 1 of 4 1 2 3 4
Breakdown tow #650230
13/07/20 10:06 AM
13/07/20 10:06 AM
Pontruggermogger Offline OP
Broke down recently [suspect fuel pump] only 12 miles from home. Did the correct thing and got recovery [tho' it took 7 hours to arrive!] because the handbook states 'no towing'. Handbook does not explain why. It would have been so much more convenient to have been towed home. I've written to MCC to ask why but to date have had no reply [and frankly don't really expect one]. Anyone have any thoughts - damage to transmission? - or simply the lack of a towing eye? Sorry - should've explained that I'm referring to my 3 wheeler!
Jeremy
Re: Breakdown tow [Re: Pontruggermogger] #650231
13/07/20 10:12 AM
13/07/20 10:12 AM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Which Model?
The trads have a towing eye on the offside front chassis rail.
However, I've been advised to treat this with caution because a hard jerk has the potential to pull the chassis out of true.
Ah...three wheeler......someone will be along soon
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Breakdown tow [Re: Pontruggermogger] #650238
13/07/20 10:29 AM
13/07/20 10:29 AM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
I suspect unless you remove the drive belt you shouldn't tow a MTW
Re: Breakdown tow [Re: CooperMan] #650240
13/07/20 10:50 AM
13/07/20 10:50 AM
Hi Jon - I think you may be right but being a practical sort of bloke I would really like to know WHY! - Given the right info. I could then choose between the option to be towed home or be recovered ........... I suspect it may be lack of a towing eye issue for MCC, in which case I can make an informed decision to use a tow rope. If it's a potential transmission damage issue then OK - no tow! [ I certainly won't be removing the drive belt by the side of the road! ]
Jeremy
Re: Breakdown tow [Re: Pontruggermogger] #650258
13/07/20 12:24 PM
13/07/20 12:24 PM
Austria, Vienna area
The Austrian Offline
I once did tow my M3W for some 15km.
No problems recognized.
Why should there be a problem?
Gearbox has oil without need for pressure.
(I have not heard Mazda does not allow towing a Miata where the same box is used)
Bevel box has its own oil reservoir.
The drive belt does not need lubrication.
The engine remains switched off...
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Re: Breakdown tow [Re: Pontruggermogger] #650260
13/07/20 12:28 PM
13/07/20 12:28 PM
Near Windsor Berkshire
Rog G Offline
Rog G  Offline
I believe the reason for not towing the M3W is to do with the way the lubrication system in the gearbox works, and would result in insufficient lubrication. So if you disconnect the drive belt then you would be OK. Alan Brathwaite on his Indian misadventure, was towed many times as a result of his breakdowns without removing the drive belt and no adverse effects.
I wouldn't hesitate to tow mine over short distances.
2013 M3W
1971 4/4 2 Seater
1934 Sports
Re: Breakdown tow [Re: Rog G] #650288
13/07/20 02:25 PM
13/07/20 02:25 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
If the gearbox is the reason, then my 4/4 and recent +4 cars are also affected.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: Breakdown tow [Re: Rog G] #650296
13/07/20 02:53 PM
13/07/20 02:53 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
It is to do with the distribution of oil in the transmission, over short distances not an issue. As with the trad Morgans if towing you should disconnect the drive shaft, again not an issue for short distances.
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Breakdown tow [Re: Pontruggermogger] #650302
13/07/20 03:01 PM
13/07/20 03:01 PM
Cheltenham, Glos. UK
Graham, G4FUJ Online content
Graham, G4FUJ  Online Content
Being a bit flippant, but I would recommend contacting MMC as in Morgan Motor Company rather than MCC - Marylebone Cricket Club. Unless perhaps you are contemplating beating your car with a cricket bat? smile
Haven't looked at the M3W gearbox, but I suspect, as with many modern gearboxes it is lubricated by pump, rather than splash/drip lubrication and if towing the pump does not get driven - lack of lube, worn/seized box.
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'06 Saab 9-3 Convertible
Re: Breakdown tow [Re: Pontruggermogger] #650314
13/07/20 03:11 PM
13/07/20 03:11 PM
Rog G Offline
Rog G  Offline
Cribbed from a MX5 forum
"The Miata's (and most transmissions) are indeed lubricated by "splash oiling". The input shaft rotates the counter-shaft which resides in the bottom of the transmission submerged in the oil. The output shaft is rotated by the drive wheels/drive-shaft/differential, and is above the oil level in the transmission, and does not splash the lubrication inside the transmission. The actually driven gears are constantly rotated by the counter-shaft gears when the engine is running and the clutch is out (in gear or neutral). The driven gears freely rotate (on bearings) on the output shaft unless the gear is selected.
Towing a car in neutral causes the output shaft to rotate while the gears remain stationary (and receive no splash lubrication). Will this cause harm? It depends. Many people have no problems flat towing a car with a transmission like the Miata's, however it is not receiving the proper lubrication. "
2013 M3W
1971 4/4 2 Seater
1934 Sports
Page 1 of 4 1 2 3 4
Moderated by  Aeroman, Simon
