24 registered members (IcePack, Ritchie B, DJC, Gambalunga, GIB, Themorganeer, Ragnar, M3W55, Hamwich, Mark H, HJP, IMHO, marshalben, washman54, B3MOG, Waldemar, planenut, RedThree, Rog G, Garethseries1, TBM, RB1, RobCol, Dada), 230 guests, and 29 spiders.
+8Rich 382
John V6 323
CooperMan 137
Alistair 123
M3W North Devon Day Trip
by chocadoodledoo. 14/08/20 05:47 PM
Mg midget and Morgans
by nick w. 14/08/20 03:07 PM
Rosie`s Pig
by PhilRoyle. 14/08/20 02:30 PM
Aero8 s4
by Simon m wright. 14/08/20 02:17 PM
Image posting
by Image. 14/08/20 01:37 PM
Changing colour of Mohair hood cover?
by PaulJ. 14/08/20 01:24 PM
Fantomworks Garage
by TBM. 14/08/20 01:20 PM
Sunnier times ahead
riding through the montains
SNOWDONIA B4407/A543
GTN Soft top re-fitted
GTN Visors
Paul Johnson, Jim5961, Renat, StephanCarstens, Allthegearnoidea
7100 Registered Users
Topics39,079
Posts643,470
Members7,100
Most Online1,033
Dec 28th, 2019
2to3wheels
Turn signal #650584
14/07/20 05:26 PM
14/07/20 05:26 PM
Pirmasens, Germany
Mc Black Offline OP
Mc Black  Offline OP
Pirmasens, Germany
One question: If you turn left or right at an intersection, does your turn signal also remain permanently on and must be reset manually? Mine stays on until I turn it off.
Best regards
Bernd
Added: It's a 1981 4/4 4 Siter with original indicator (it think)
Morgan 4/4, 4 Sider RHD, Build 1981
Re: Turn signal [Re: Mc Black] #650585
14/07/20 05:27 PM
14/07/20 05:27 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
With the standard switchgear, it should self cancel if you have turned sufficiently (for example a 90 degree turn should be plenty).
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: Turn signal [Re: Mc Black] #650609
14/07/20 07:04 PM
14/07/20 07:04 PM
Arwyn Williams Offline
Bernt
Can you tell us the year and model of your Morgan as it would help answer your query
Arwyn
Re: Turn signal [Re: Mc Black] #650610
14/07/20 07:08 PM
14/07/20 07:08 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
Best regards
Bernd
My '72 resets itself, so I imagine your '81 will. However, as Paul says, it is dependant on 'amount' of wheel movement.
Is it a standard indicator stalk?
1972 4/4 4 seater
Too many ratty motorbikes
Re: Turn signal [Re: Mc Black] #650613
14/07/20 07:24 PM
14/07/20 07:24 PM
Aerdenhout, The Netherlands
BertR Offline
BertR  Offline
When living in Texas, I learned that using indicators, is considered a sign of weakness.
2009 Roadster, Lancia midnight blue, cinnamon upholstery.
Re: Turn signal [Re: Mc Black] #650614
14/07/20 07:29 PM
14/07/20 07:29 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
I love my indicators so much I used to leave them on.......self cancelling can be a little sporadic if there's not a full turn of the wheel.
Now fitted a little gizmo that starts beeping after a while if I've left them on smile
1972 4/4 4 seater
Re: Turn signal [Re: Mc Black] #650643
14/07/20 10:05 PM
14/07/20 10:05 PM
There should be a little egg shaped alloy cam on the top of steering column immediately behind the steering wheel hub.
It is this cam contacting the ears on the indicator switch which causes the indicators to cancel.
Not sure if the cam came fitted to the upper steering column when Morgan sourced it or whether it was done in the factory. Its pretty crude so probably it is a factory part.
Now this cam is drilled and tapped to take a small grub screw - probably something like No8 or No10 UNC.
What happens us that the screw slackens or drops out, and the cam remains stationary whilst the steering column turns which means the signals aren't cancelled!
Kind regards
Arwyn
Re: Turn signal [Re: Arwyn Williams] #650719
15/07/20 01:02 PM
15/07/20 01:02 PM
Pirmasens, Germany
Mc Black Offline OP
Mc Black  Offline OP
Pirmasens, Germany
Thanks Arwyn for the info.
Bernd
Re: Turn signal [Re: Mc Black] #651603
20/07/20 05:22 PM
20/07/20 05:22 PM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
Hello, when I'm right in the 1970/1980ies Morgan uses the usual british stuff, as Triumph, Austin, Jaguar, Mini and so on.
It was high-tech. My Mini was selfchanceling, my Mums Volkswagen not...
As bespoke there must be a nose at the boss that switches the indicatorstalks.
If you undo the boss you see the cuts in the mechanism. And you see the noses.
In cause there are some years after the build, may be the mechanismn is worn ( you can test it with the boss off) or there is no nose at the boss. That you will see too.
That is the switch. May be you've got the sharp edged model. When you have a look at the center you see the two whole
for the reset.
https://allbrit.de/etk_detail.asp?Artikelnummer=BAU5345
Greets René
Hallo, wenn ich mich richtig erinnere wurden in den 70/80igern in den Morgans die üblichen Lenkstockschalter montiert,
die alle Engländer hatten. Die hatten den High-Tech Rücksteller, der Billig Polo meiner Mutter nicht.
Wie beschrieben müssen dazu in der Lenkradnabe ein oder zwei Nasen sein.
Nachdem das Auto ja etwas älter ist kann es sein das der Mechanismus kaputt ist (das kann man bei demontiertem Lenkrad testen) oder es fehlt die Nase an der Nabe. Das sieht man.
Oben im Link ist der Hebel. Vermutlch hast Du aber die älteren etwas eckigeren Hebel. Wenn man genau hinschaut sieht man
in der Mitte die zwei ausfräsungen in die die Nase eingreift.
Gruß aus der Landeshauptstadt
René
Re: Turn signal [Re: Mc Black] #651619
20/07/20 06:17 PM
20/07/20 06:17 PM
X
xc68anc Offline
xc68anc  Offline
X
Here you see it better:
http://www.minispares.com/product/Classic/Electrics/Switches,%20stalks/BAU5345.aspx?0912&ReturnUrl=/shop/classic/Electrics/Switches,~stalks.aspx%7CBack%20to%20shop
I think this part would fit if the mechanism is worn.
René
Moderated by  Aeroman, Simon
