8 registered members (vbalddave, Jan_1, The Austrian, BertL, Alan Patterson, Robbie Mathisen, Bonesie, M3W55), 138 guests, and 15 spiders.
John V6 299
+8Rich 285
TBM 148
Peter J 141
Mystery rubber bit
by GPC1203. 09/03/21 01:24 AM
Electric 4/4
by nick w. 08/03/21 10:41 PM
Engine Management Fault Codes
by Barrythebrave. 08/03/21 07:59 PM
Good old Banksy
by +8Rich. 08/03/21 05:47 PM
How many Morgan miles did you do in 2020?
by howard. 08/03/21 05:41 PM
Restomod
by howard. 08/03/21 05:29 PM
Relay help, please
by vbalddave. 08/03/21 05:28 PM
Mandy's Morgan so far...
Skiing in Scotland
Some pics
More Lock-Down slides
Gearbox oil check 2nd attempt at pics
Steve Thornton, RubyWexford, Steve Van Dyke, Yanto, andypandy
7412 Registered Users
Topics40,660
Posts679,546
Members7,412
Most Online1,033
Dec 28th, 2019
Andyhirst, Morgan110
Page 11 of 11 1 2 9 10 11
Re: HotMog's transformation [Re: Culminator] #648601
04/07/20 05:24 PM
04/07/20 05:24 PM
Culminator Offline OP
Time for another update and a milestone has been reached!!
Fuel filler hoses are now in place and so is the fuel gauge sender unit.
Over the last couple of days, I have now managed to finish the fuel system by connecting the tank to the pump and capping off the extra outlet I had on the new tank. So that side of things is now complete.
I've sussed out how the inlet manifold connects to the water pump and ordered the correct "S* shaped link hose. This was really foxing me for some reason, until I spoke with the engine builder who sent me link to the correct item, which is a massive £2.75! Incredible as that includes delivery.
The ignition side of things was also a bit of a mystery, so a lot of time has been sent researching and fortunately I have the correct distributor for the year of car, so just need a coil and a feed from the ignition switch side.
But, the really big news is the electrics. I decided to "dry build" the electrics by remounting the switches back onto the old race dashboard which was labelled. Luckily, I had taken loads of photos when I stripped the car, so this was a relatively easy job. I was really fearful of connecting the battery back up but unbelievably, after 2 years and having had all of the complex injection, telemetry and ECU wiring hacked out of the loom, everything worked!! Yep, fan, indicators, lights, horn, wipers etc, they all work fine.
I'm really pleased with that as the remaining loom is really nicely built and in great condition.
Re: HotMog's transformation [Re: Culminator] #650937
16/07/20 06:09 PM
16/07/20 06:09 PM
A big update!
The engine fired up for the first time today laugh
Did the final bit of wiring for the ignition, fixed a couple of minor fuel leaks, (my fault, regulator connections were not done properly) and then thought, I wonder what would happen if I pressed the start button. Well to my surprise it fired up instantly! It cut out soon after as I hadn't at that point connected a permanent positive to the coil but even so, what a magical moment.
Unfortunately, the battery is past its best, so a new one is on order. I started it a few times and it sounds very smooth and very sweet. Need to run the cam in before anything else now but happy days!
Re: HotMog's transformation [Re: Culminator] #650939
16/07/20 06:21 PM
16/07/20 06:21 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Excellent news thumbs that carb looks a beast
Re: HotMog's transformation [Re: Culminator] #650944
16/07/20 07:10 PM
16/07/20 07:10 PM
Chester, UK
Grumpy2 Offline
Grumpy2  Offline
Chester, UK
Looks like the weber 500? I put one of those on an MGB that I converted to V8 about 20 years ago. Made a huge improvement in almost every respect. Better Idle, pickup, economy and so easy to set up. The only thing I missed about the Holley 390 it replaced was the kick in the backside when the secondaries eventually decided to open.
94 plus 8 in Westminster Green - I think!
Re: HotMog's transformation [Re: Culminator] #650999
17/07/20 07:18 AM
17/07/20 07:18 AM
It is indeed the Weber 500. They certainly seem to have a good following and it's a very neat installation.
Re: HotMog's transformation [Re: Culminator] #651002
17/07/20 07:37 AM
17/07/20 07:37 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Very impressive. I like the cooling cut outs on the wings.
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
