15 registered members (TBM, Roady, PhilRoyle, Adrian Bott, AAJ, Image, John V6, M3W55, Camelot, jrd, AndyrIch, SimonH, IMHO, Craig Jezz, IvorMog), 120 guests, and 18 spiders.
+8Rich 327
John V6 252
TBM 180
Alistair 151
Hamwich 146
Local dialect
by Gordon D. 24/09/20 10:23 AM
Inside the Spitfire Factory
by Ian Wegg. 23/09/20 08:45 PM
Inside the spitfire factory
by IMHO. 23/09/20 08:06 PM
Wots Your Grammer Like?
by Clipper. 23/09/20 07:58 PM
Creaking kingpins
by Grumpy2. 23/09/20 07:10 PM
Annoying resonance at 200rpm
by Kevcaster. 23/09/20 04:33 PM
For sale post
by NickCW. 23/09/20 04:32 PM
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
A grand day out
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,447
Posts651,121
Members7,166
Most Online1,033
Dec 28th, 2019
No Birthdays
I’m stumped #653640
01/08/20 09:52 AM
01/08/20 09:52 AM
Hampshire, UK
I
IMHO Online content OP
IMHO  Online Content OP
I
Hampshire, UK
I noticed a dodgy looking in line 15A fuse holder next to my battery and on inspection the connections were loose and there was evidence of arcing. Having fixed it I then began to wonder what the fuse was protecting, it’s connected to the +ve of the battery, the wire then disappears into the insulation tape snake pit under the fuse box. I’ve tested the circuits that might demand a direct battery connection such as the charger socket and the cockpit 12v socket, in fact I’ve switched everything I can think of and started the engine Complete with immobiliser with it disconnected.
It looks to be factory installed as it enters the wrappings of the engine loom under the fuse box.
Because of the arcing marks it looks to draw decent current at some point and it’s got a 15A fuse. But there’s no draw with the ignition off and with the engine on it’s well below 1mA. Any ideas what it might be for? confused2
M3W Brooklands (2015)
Moody 41 (2013)
Re: I’m stumped [Re: IMHO] #653644
01/08/20 11:00 AM
01/08/20 11:00 AM
East Harling, Norfolk UK
Richard Wood Offline
There was nothing similar on my 2016 model, just the two +ve cables going to starter and main electrical distribution, both sheathed with convoluted tubing. The wiring loom schematics support this.
Have you owned the car from new and/or are aware of any aftermarket additions or mods that may require such a permanent feed. I'm thinking alternate headlamps, horns etc.?
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: I’m stumped [Re: IMHO] #653647
01/08/20 11:26 AM
01/08/20 11:26 AM
Hampshire, UK
I
I
Hampshire, UK
Hello Richard,
I bought the car in April 2019 it had one owner from new in 2015 and had done 350miles only. I thought the same but if some aftermarket item had been removed i would expect to see some loose ends somewhere. It’s also taped into the engine loom in a way that doesn’t look aftermarket, the charger socket is typically aftermarket with independent wires going back to the battery terminals.
Moody 41 (2013)
Re: I’m stumped [Re: IMHO] #653650
01/08/20 11:47 AM
01/08/20 11:47 AM
north yorkshire
B3MOG Online content
B3MOG  Online Content
north yorkshire
Is it for the radiator fan? Run the engine till it shows 90 degrees and see if the fan kicks in with the fuse disconnected .
David Byrne
Re: I’m stumped [Re: IMHO] #653660
01/08/20 12:14 PM
01/08/20 12:14 PM
Hampshire, UK
I
I
Hampshire, UK
I hadn’t thought of that David. Thanks.
Moody 41 (2013)
Re: I’m stumped [Re: IMHO] #653662
01/08/20 12:29 PM
01/08/20 12:29 PM
Hampshire, UK
I
I
Hampshire, UK
Award that man a medal!
Thanks David, it is for the fan which was probably retrofitted at the factory before delivery. This would also explain why I’ve not noticed the fan coming on up to now as the connection at the fuse was not good. cheers
Moody 41 (2013)
Re: I’m stumped [Re: IMHO] #653664
01/08/20 12:41 PM
01/08/20 12:41 PM
That's odd confused2. I did consider a retro-fitted urban cooling kit but they became standard fit sometime in 2014 when there was a major revision of the car, born out in the parts book. Guess there was an interim period that lasted some time before the new looms, which place the cooling fan fuse in position 19 in main fuse box, came online.
Re: I’m stumped [Re: IMHO] #653668
01/08/20 12:59 PM
01/08/20 12:59 PM
Hampshire, UK
I
I
Hampshire, UK
It fits with the history of my car which is Brooklands 11/50 but not registered until 2015 so it was at the factory for a good while. I have the chassis mods with the bolted in A frame behind the engine and I have the black rear sprocket hub but I also have the original HD Cush drive. My fuse at 19 is the 12V socket.
This forum is such a great resource.
Moody 41 (2013)
Re: I’m stumped [Re: IMHO] #653670
01/08/20 01:06 PM
01/08/20 01:06 PM
Gods own county! Oop north
Dab of oppo Offline
Dab of oppo  Offline
There can’t be many of us still with the HD compensator, just keep it greased.👍🏼
Re: I’m stumped [Re: IMHO] #653671
01/08/20 01:10 PM
01/08/20 01:10 PM
Hampshire, UK
I
I
Hampshire, UK
Unfortunately, I didn’t get the grease nipple mod. So I’m taking my engine up to see Phil in October.
Moody 41 (2013)
Moderated by  Aeroman
