14 registered members (Tresco, CooperMan, thelastgizmo, Robbie Mathisen, DickJ, DCH, Griff07, m3w_golden_co, Dada, John V6, Image, IvorMog, Shooter, Heinz), 181 guests, and 13 spiders.
John V6 369
+8Rich 232
TBM 163
CooperMan 120
DRIVERS DOOR DROP..
by KEVFITZ. 21/10/20 04:33 PM
Three wheelers galore
by Richard Wood. 21/10/20 03:42 PM
Another Configurator
by Jon G4LJW. 21/10/20 03:23 PM
For all you Landie buffs
by athelstan. 21/10/20 09:26 AM
Anyone used Colourlock on leather?
by Andrew1806. 20/10/20 08:53 PM
Magnecor leads
by thelastgizmo. 20/10/20 07:27 PM
Historic Vanwall to return
by DirkM. 20/10/20 05:01 PM
Malvern Show 2
Malvern Show 1
MGB`s can corrode..?
Winter Project
How now brown cow
Ingenious, JMT, Brian G, beetle back, Apple58
7185 Registered Users
Topics39,633
Posts655,400
Members7,185
Most Online1,033
Dec 28th, 2019
paul
Re: First Oil Change [Re: linklaw] #653694
01/08/20 03:43 PM
01/08/20 03:43 PM
Rio Del Mar, CA
kankeL Offline
kankeL  Offline
Rio Del Mar, CA
Cut the oil line under the car, drain oil, install the in-line oil drain, tighten clamps. Very easy.
2016 M3W, Army Green Matte/Tan Leather, 13k miles
Re: First Oil Change [Re: Dutch] #653697
01/08/20 04:17 PM
01/08/20 04:17 PM
Arizona USA
AZJowett Offline
AZJowett  Offline
Arizona USA
Originally Posted by Dutch
How difficult is it to install Morgancustom.net oil drain ?
Procedure ?
I am helping Emil with his installation guides. Have paused right now due to 115F+ temps but will be back on it when it cools off.
I have this mod to do myself and it looks very simple. He did finish the detailed installation guide for this so best to contact him direct.
1961 +4 Roadster
2018 S&S 110th Beetleback
1934 MX4 Beetleback
1936 JAP Barrelback
Re: First Oil Change [Re: linklaw] #653728
01/08/20 06:26 PM
01/08/20 06:26 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
Emil's installation guides are very clear and easy to work through, the oil drain installation as KrankeL says is very simple and easiest install.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Re: First Oil Change [Re: linklaw] #653925
02/08/20 09:56 PM
02/08/20 09:56 PM
UK East Anglia
Landy Offline
Landy  Offline
UK East Anglia
What holds the oil drain valve in position? Or is it just suspended between the lines?
Re: First Oil Change [Re: Landy] #653928
02/08/20 10:10 PM
02/08/20 10:10 PM
britmog Offline
britmog  Offline
The drain is a screw plug into the light weight block which has two male connectors to go into the ends of the pipe which are then clamped tight. If you go Emil's site you can see pictures of it:
www.morgancustom.net
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Re: First Oil Change [Re: linklaw] #653930
03/08/20 02:39 AM
03/08/20 02:39 AM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
This is mine with extra zip ties.
Stephen
2019 M3W leaking oil right off the showroom floor
Moderated by  Aeroman
