20 registered members (Sinbad, hugo, TBM, MOG 615, Rog G, 60Yards, Tresco, VassilisP, Robbie, Mr Mogoo, Alan Patterson, Richard Wood, Fabi0000, PaulV, RedThree, Kevcaster, tmg513, MarioCP, brownbaker, Snowden), 153 guests, and 17 spiders.
+8Rich 317
John V6 252
TBM 165
Hamwich 150
Alistair 149
Hello from Nidderdale North Yorks
by NiddMog. 21/09/20 11:14 PM
Maltese style head restraints
by +8Rich. 21/09/20 09:30 PM
Antiques Road Show
by Dean-Royal. 21/09/20 06:37 PM
Camber Setting
by Eastertown. 21/09/20 02:43 PM
Aero Windscreen seal
by NickCW. 21/09/20 02:10 PM
Snakes alive!
by Gambalunga. 21/09/20 01:45 PM
Hi from Berkshire
by KennyW. 21/09/20 12:01 PM
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
A grand day out
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,428
Posts650,700
Members7,166
Most Online1,033
Dec 28th, 2019
Peter1062
knocking from rear wheel on 3 wheeler #654831
07/08/20 03:15 PM
07/08/20 03:15 PM
Phil Wood Offline OP
Hi to all. Hope alls well. Ive got a Morgan 3 wheeler & im having a couple of issues. The first is im getting a knocking from rear wheel whilst on the move but does'nt do it with rear end in air i know this because ive taken the boot, tray & mudguard off & got a friend to kneel on passenger seat & lean over whilst on the move & determine where the noise is coming from & we will only really know if we take the rear wheel off. Reason im asking is has anybody had similar circumstances. The other problem is the indicator has stopped working & needs replacing,(ide like to take it apart because its got something loose inside) how do i get the wiring out of the connector because it needs to pass through the loom sleeve, bracket & light surround.
Re: knocking from rear wheel on 3 wheeler [Re: Phil Wood] #654832
07/08/20 03:20 PM
07/08/20 03:20 PM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
You might get more replies if you post this in the Three Wheeler section Phil, rather than the Welcome Forum smile smile
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'06 Saab 9-3 Convertible
Re: knocking from rear wheel on 3 wheeler [Re: Phil Wood] #654915
07/08/20 11:14 PM
07/08/20 11:14 PM
Taffmog Offline
Taffmog  Offline
My guess would be a loose drive belt.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Re: knocking from rear wheel on 3 wheeler [Re: Phil Wood] #654922
08/08/20 06:20 AM
08/08/20 06:20 AM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
As Graham says, try posting this in the Three wheeler Section.
You need more information about the rear wheel knocking, is it a constant, steady knocking or random with bumps? Transmission/gear related, wheel bearings or drive belt type noise? Has your indicator stopped working because of a fault with the stalk or the electrics? The indicator stalk is a Morgan only bit and not easy to repair. They are not too wildly priced from MMC.
Re: knocking from rear wheel on 3 wheeler [Re: Phil Wood] #654960
08/08/20 10:53 AM
08/08/20 10:53 AM
Antwerpen Belgium
stefan s Offline
stefan s  Offline
Antwerpen Belgium
I had 2 times before an knocking on an wheel an it was a bubbel on the tyre ( delamination)and the second time an pice of metal in the tyre. Find it by turning the wheel slowly with my hand on it.
Stefan
Re: knocking from rear wheel on 3 wheeler [Re: Phil Wood] #655102
09/08/20 11:23 AM
09/08/20 11:23 AM
Im new to using the forum & hopeless at using a computer. Thanks for all replies, ive looked closer into the rear wheel by taking it off but could`nt find anything, the bearing was fine, the drive belt looked ok, the tyre is good. I can spin it freely off the ground & there`s nothing & only does it under load at slow speed in either a straight line or turning left, not right & not all the time & its definitely a metallic sound. It was in at Beamish Morgan a couple of weeks ago for a service & brake peddle (recall) change & i told them about it then & they said it was a shock bush which is worn & does need replacing, which is on order with replacemment l,e,d indicator which rattles once its out of the cover & at £60 plus vat, But the wheel noise is more than the shock bush, its a proper knock
Re: knocking from rear wheel on 3 wheeler [Re: Phil Wood] #655103
09/08/20 11:24 AM
09/08/20 11:24 AM
All i can do now is use it until it gets worse
Re: knocking from rear wheel on 3 wheeler [Re: Phil Wood] #655108
09/08/20 11:44 AM
09/08/20 11:44 AM
M3W55 Offline
M3W55  Offline
As others have said, you will get more assistance if you post your problem on the Three Wheeler forum.
Re: knocking from rear wheel on 3 wheeler [Re: Phil Wood] #655113
09/08/20 12:25 PM
09/08/20 12:25 PM
Beaumont de Lomagne, France
Philippo Offline
Philippo  Offline
Hello Phil
Welcome to the forum, and as others have said you'll probably find someone on the 3W section who will recognise your problem immediately.
However, just as an exercise could you advise a bit more info. Does it knock:
- when you first start off?
- when you accelerate?
- when you ease off?
- when you brake?
- when you go round corners (left or right)?
- when you go over bumps?
Only had an old 3W (1934) so suspect I won't be able to help but you never know.
Enjoy your new acquisition and I'm sure teething problems will be solved quickly.
Cheers
Philip
Philip
4/4 4 seater 1974 (to be replaced soon by in-build 1985 +8 4 seater)
Malone F1000
Re: knocking from rear wheel on 3 wheeler [Re: Phil Wood] #656285
15/08/20 08:21 AM
15/08/20 08:21 AM
Philippo Offline
Philippo  Offline
Was it something we said???
Cheers
Philip
Malone F1000
Moderated by  Aeroman, Simon
