13 registered members (Viper, bmgermany, OZ 4/4, Gordon D, Image, tmg513, DavidR, Rob Thornton, M3W55, Dada, Black Adder, Grumpy2, Neptune), 199 guests, and 12 spiders.
+8Rich 325
John V6 251
TBM 184
CooperMan 157
Alistair 150
VDO Instrument manuals
by IvorMog. 25/09/20 07:19 PM
Pinking - another possible cause
by Rik. 25/09/20 06:57 PM
M3W EV Junior
by TimG. 25/09/20 02:54 PM
Summer is over
by Gambalunga. 25/09/20 02:03 PM
The App.....
by Grumpy2. 25/09/20 01:38 PM
Insurance valuation
by jrd. 24/09/20 10:31 PM
Car jack
by Pollok one nil. 24/09/20 10:14 PM
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
A grand day out
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,458
Posts651,398
Members7,166
Most Online1,033
Dec 28th, 2019
chocadoodledoo, Phil C
Page 1 of 4 1 2 3 4
Key transponder issue #655087
09/08/20 10:46 AM
09/08/20 10:46 AM
Austria, Vienna area
The Austrian Offline OP
Yesterday evening my 4/4 refused to start.
After I inserted the key the standard procedure of speedometer needle jump worked, klicking of engine valve preset was there but no reaction from the starter when I turned the key in starting position. Key out, re-inserting, same problem.
After knocking hard at the steering column starting was ok.
This morning: no starting at all. Both Starter keys were tested with the same result. On purpose I did no knocking the steering column trick.
I had a similar problem last season, brought the car to my Morgan dealer and the transponder ring got re-located (at least I think they did that for solving the problem)
The car is safe in the garage.
Any advise from the professionals if I could do the fixing of transponder ring myself?
Is there a risk to damage something? Spare part supply from MMC seems to be slow at the moment.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Re: Key transponder issue [Re: The Austrian] #655090
09/08/20 10:56 AM
09/08/20 10:56 AM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
I've not had this myself Hannes but others have, I know DaveW has a thread on here somewhere as his car suffered from it and the ring needing moving a little I seem to recall.
Regards Richard
1994 Connaught Green +8 prev
Re: Key transponder issue [Re: The Austrian] #655091
09/08/20 10:57 AM
09/08/20 10:57 AM
Mercia, UK
SALMO Offline
SALMO  Offline
Mercia, UK
Hi Hanes,
My 2006 car was a bit of a mess, whole cowl fitting and transponder ring fitted by a butcher.
A thick cable tie had been fitted to stop the ring sliding down but nothing to stop it rotating and moving, absolutely awful.
Solution for me was double sided tape. Easy job, just ensure you place the ring so that the cowl refits properly.
Best of luck
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Re: Key transponder issue [Re: +8Rich] #655092
09/08/20 11:01 AM
09/08/20 11:01 AM
Kent
Alan Patterson Offline
Kent
Here's DaveW's thread.
http://www.talkmorgan.com/ubbthreads.php/topics/539514/1
Regards
Alan
AP08 MOG
Re: Key transponder issue [Re: The Austrian] #655104
09/08/20 11:25 AM
09/08/20 11:25 AM
Hi folks!
Thank you for comments and special thanks for the link to the other thread.
I'll try the 20 seconds game!
Hannes
Re: Key transponder issue [Re: The Austrian] #655106
09/08/20 11:35 AM
09/08/20 11:35 AM
I assume the immobilizer is an integral part of the Morgan electric setup.
Otherwise I would prefer to remove it and have no immobilizer.
Murphy's law applies to Morgan cars as far as I have experienced.
What is not there can't make problems so no immobilizer would be OK.
(I think Murphy's car was a M3W) oops
Hannes
Re: Key transponder issue [Re: The Austrian] #655125
09/08/20 02:02 PM
09/08/20 02:02 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
I'd definitely be exploring a workaround it can't be too difficult.
Regards Richard
Re: Key transponder issue [Re: The Austrian] #655128
09/08/20 02:21 PM
09/08/20 02:21 PM
Mercia, UK
SALMO Offline
SALMO  Offline
Mercia, UK
Interesting thread of DaveW.
Interesting that his car had neoprene to stop the ring falling inwards.
My car only had a cable tie, with the side of the cowl to keep in place.....the poverty solution.
Best of luck with an alternative solution, Hannes
Regards
Geof
Re: Key transponder issue [Re: SALMO] #655133
09/08/20 02:44 PM
09/08/20 02:44 PM
Thank you - I may need luck.
The 20 seconds key contact does not work on my car, even with removed cover.
I will call my Mog-dealer tomorrow. Hopefully no need to transport the car to his garage.
Hannes
Re: Key transponder issue [Re: The Austrian] #655252
10/08/20 10:30 AM
10/08/20 10:30 AM
My key transponder system does look different than the one in DaveW's thread. It is a Ford origin spare part
This is the setup on DaveW's car
pic copied for ease of comparison
(no copyright violation - I hope)
Hannes
Page 1 of 4 1 2 3 4
Moderated by  Aeroman, Simon
