7 registered members (Richard Wood, tmg513, HeadlessBlue, bilibib, brownbaker, TBM, RobCol), 124 guests, and 17 spiders.
+8Rich 294
John V6 244
TBM 166
Hamwich 147
Alistair 145
This sums it all up really
by +8Rich. 19/09/20 11:24 PM
Regardless the price, isn‘t it a nice car?
by Heinz. 19/09/20 09:56 PM
modifications for a slim boat tail
by thono. 19/09/20 08:54 PM
Fuel leak help
by kankeL. 19/09/20 02:03 PM
Quantities
by Phil+8. 19/09/20 01:54 PM
Mr Toad At the Coop
by Jon G4LJW. 19/09/20 10:36 AM
Rattray and Troup 4/4 80th
A grand day out
Dashboard re-purposing
Scenic Run from Harrogate
Clodmog, Fogg, Jonesthesteam, Dr. Chris, Fagin
7154 Registered Users
Topics39,409
Posts650,332
Members7,154
Most Online1,033
Dec 28th, 2019
Fuel.inj
1990 +8 Rear Brakes #655212
09/08/20 11:43 PM
09/08/20 11:43 PM
Yorkshire, UK
jeremylparker Offline OP
Yorkshire, UK
I've got a sticking nearside rear drum brake, so jacked it up, took off the wheel and had a look.
What i found seems rather strange to me...so appreciate your thoughts, knowledge and experience of the said subject.
1. The brake adjuster on the rear of the baking plate was at 9 o'clock position - i recall (from many years ago so could be wrong) this being at the bottom or 6 o'clock position?
2. The brake pipe going to the rear nearside slave cylinder is fed from what appears to be the bleed nipple of the offside slave cylinder?
3. The handbrake linkage seems twisted, as the slave cylinder is in the 3 o'clock position?
Thoughts please.
Thx
Re: 1990 +8 Rear Brakes [Re: jeremylparker] #655223
10/08/20 07:06 AM
10/08/20 07:06 AM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
On mine the nearside adjuster is around 11 o'clock position and the slave around 5 o'clock
Identical to the ones on this thread Rear brakes
I think the rear brakes were the same for +4, 4/4 and +8 up to 1993. If not, then ignore my post!
1972 4/4 4 seater
Too many ratty motorbikes
Re: 1990 +8 Rear Brakes [Re: jeremylparker] #655224
10/08/20 07:08 AM
10/08/20 07:08 AM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
The brake pipe is fine - my has a t piece and goes to each slave individually, but i understand the set up like yours is fairly commonplace.
1972 4/4 4 seater
Re: 1990 +8 Rear Brakes [Re: jeremylparker] #655241
10/08/20 08:41 AM
10/08/20 08:41 AM
Luddite Offline
Luddite  Offline
My 85/6 +8 has a similar pipe layout to that described by the O.P. the advantage of which would seem to be that the rear brakes system has only one bleed nipple to seize or break off... hide
My guess is that GoMoG.com will have schematics of rear brake layouts for all models...?
Re: 1990 +8 Rear Brakes [Re: TBM] #655242
10/08/20 08:42 AM
10/08/20 08:42 AM
Yorkshire, UK
Yorkshire, UK
Thx - TBM & Luddite
The pictures in the link are a big help - now i know what 'good' looks like.
Guess I was expecting separate brake pipes because of the dual circuit for safety - but perhaps the car has a single brake circuit?
Re: 1990 +8 Rear Brakes [Re: jeremylparker] #655260
10/08/20 11:03 AM
10/08/20 11:03 AM
Luddite Offline
Luddite  Offline
JLP, I suspect your thinking is correct re the expectation of finding dual circuit brakes. I have not been involved in other than general brake maintenance on my Morgan, though I went out to the garage and the brake master cyl has two take off points which would suggest dual circuit, as might be expected of a car of that year. Without getting under, I suspect that the front brakes are a different circuit from the rears, as opposed to the more normal(?) diagonal front/rear split..?
Re: 1990 +8 Rear Brakes [Re: jeremylparker] #655262
10/08/20 11:10 AM
10/08/20 11:10 AM
Arwyn Williams Offline
Front rear split.
First take off nearest the bulkhead is the front brake circuit and the furthest away is the rear circuit.
I've just done a dual circuit conversion on my 1968 Plus 4
Arwyn
Moderated by  Aeroman, Simon
