15 registered members (bmgermany, Rudolf, Richard Wood, MOG 615, Fat Wolfie, Image, Spanner Juggler, SFG, IcePack, Rog G, JB62, TBM, Kevcaster, BuyBritish, petemog), 130 guests, and 10 spiders.
+8Rich 294
John V6 244
TBM 166
Hamwich 147
Alistair 145
This sums it all up really
by +8Rich. 19/09/20 11:24 PM
Regardless the price, isn‘t it a nice car?
by Heinz. 19/09/20 09:56 PM
modifications for a slim boat tail
by thono. 19/09/20 08:54 PM
Fuel leak help
by kankeL. 19/09/20 02:03 PM
Quantities
by Phil+8. 19/09/20 01:54 PM
Mr Toad At the Coop
by Jon G4LJW. 19/09/20 10:36 AM
Rattray and Troup 4/4 80th
A grand day out
Dashboard re-purposing
Scenic Run from Harrogate
Clodmog, Fogg, Jonesthesteam, Dr. Chris, Fagin
7154 Registered Users
Topics39,409
Posts650,334
Members7,154
Most Online1,033
Dec 28th, 2019
Fuel.inj
Rusty rear brake pistons. Again..... #656052
13/08/20 08:52 PM
13/08/20 08:52 PM
Sumerset
Rog Offline OP
Rog  Offline OP
Sumerset
Fantastic drive across Exmore yesterday in the oh so hot summer heat but a bit of a surprise on the way home. A few miles from home I put my foot on the brake pedal and it went to the floor (and my foot taking the accelerator pedal with it). Fortunately a quick grab of the hand brake was enough. Turned out to be the near side rear wheel cylinder semi-seized on and I guess I boiled the fluid so a slow limp home after that. It must have seized over the journey as I had been pushing the car around in the garage the day before and didn’t notice anything.
Everything too hot to strip down last night but started at 6:00 this morning and had it freed before breakfast. I was expecting a fight with the seized drum but it came off and all looked nice and clean apart from the external rust on the pistons lurking under the dust covers. Fortunately the pistons freed up with a few shots of silicone spray and all has been well today.
So I guess the moral of the story is to get some brake lube on those pistons to keep the external surface rust at bay woohoo
Roger
Re: Rusty rear brake pistons. Again..... [Re: Rog] #656122
14/08/20 10:53 AM
14/08/20 10:53 AM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
When I service my rear brakes I peel back the dust covers & wipe some red (brake rubber safe) grease around the end of the pistons
I've recently swopped to Mintex Ceratec as it's more resistant to heat
Re: Rusty rear brake pistons. Again..... [Re: Rog] #656188
14/08/20 03:13 PM
14/08/20 03:13 PM
Sumerset
Rog Offline OP
Rog  Offline OP
Sumerset
Yes an important little job I think. When I peeled back the dust covers about a quarter teaspoon of red oxide dust fell out of each. Considering the car has had many services in it 5k miles of life its obviously not on the service schedule. My dust covers now have a high temp grease inside too.
But the odd thing was only the part of the pistons behind the dust covers were covered in rust, the portion of the pistons that pokes out through the dust covers was still bright and shiny. Odd that.....
Roger
Re: Rusty rear brake pistons. Again..... [Re: Rog] #656195
14/08/20 04:08 PM
14/08/20 04:08 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Trapped moisture / condensation that can't dry out ?
Re: Rusty rear brake pistons. Again..... [Re: Rog] #656197
14/08/20 04:13 PM
14/08/20 04:13 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
I think the brake fluid attracts condensation, cylinders are usually like that. It's certainly a hot spot for corrosion, but then again I got 15 years out of my original Roadster rear cylinders.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Rusty rear brake pistons. Again..... [Re: Rog] #656200
14/08/20 04:21 PM
14/08/20 04:21 PM
Sumerset
Rog Offline OP
Rog  Offline OP
Sumerset
But the brake fluid is the other side of the seals, this is external rust. I did wonder if the dust cover elastomer was hygroscopic and saturating with external airborne moisture. It might then outgas some of that moisture internally whenever it heats up
Roger
Re: Rusty rear brake pistons. Again..... [Re: Rog] #656216
14/08/20 06:57 PM
14/08/20 06:57 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
Is the cause somewhat similar to the infamous Duratech spark plug corrosion...metal body trapped in air within a rubber shroud?
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Rusty rear brake pistons. Again..... [Re: Rog] #656218
14/08/20 07:07 PM
14/08/20 07:07 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
I think Rog that there is always traces of fluid on the piston, maybe at a molecular level, but the corrosion under the rubber boot defies logic. Unless it's simple condensation, but every car I've had has been the same. And the fluid from the rears is always badly discoloured, even at two years. In fact when I changed the fluid in the 2012, it came out dark grey.
Re: Rusty rear brake pistons. Again..... [Re: Rog] #656242
14/08/20 09:12 PM
14/08/20 09:12 PM
Sumerset
Rog Offline OP
Rog  Offline OP
Sumerset
Oh dear Dave that looks a bit grim. I guess I had better get mine out. Who knows when or if it was last changed frown
But the good news was at least I managed to spot the hand brake cable failing before it had gone too far smile
The plastic outer had just started to crack but the metal inner was still in good shape.
So a quick repair job and a chance to use some of that magic tape recommended by bmgermany from another post thumbs
Originally Posted by Rog
My first choice for many purposes!
in my workshop I use this "rubber splicing tape" (offered by many comanies) very often. You can wrap it around tubes, cables, wires and so on!
Clever stuff. I think I need some of that in my toobox
Hopefully this will keep the wet out for a while
Roger
Re: Rusty rear brake pistons. Again..... [Re: Rog] #656249
14/08/20 09:44 PM
14/08/20 09:44 PM
Australia - NSW North Coast
OZ 4/4 Offline
OZ 4/4  Offline
Pack the rubber cap with rubber grease, no problems then.
Moderated by  Aeroman, Simon
