8 registered members (Phil Bleazey, Dutch, Lance, RobCol, Steve +8, IcePack, BobtheTrain, Barry M),
172
guests, and 14
spiders. |
Fuses
by Ray. 16/01/21 03:47 PM
Topics40,273
Posts670,658
Members7,327
Most Online1,033 Dec 28th, 2019
Tilting car lifts - help please
#657043
18/08/20 04:08 PM
18/08/20 04:08 PM
Posts: 187 returned OggieMogger
Roady
Hi Folks  I've read the threads about lifts these but I'd welcome a little clarification as follows: 1 If you have a 1500 kg version how long are the tilting runners and 2 How well do the runners cope with the many nuts and bolts that protrude from the bottom of the car? Thanks in anticipation
Re: Tilting car lifts - help please
[Re: Roady]
#657217
19/08/20 02:26 PM
19/08/20 02:26 PM
Posts: 934 Evergreen, Colorado, USA
britmog
Not sure I understand what lifts you are referring too and what you mean by "tilting runners"?
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
[Re: Roady]
#657233
19/08/20 03:26 PM
19/08/20 03:26 PM
Posts: 558 Chester, UK
Grumpy2
Chester, UK
I've owned and used 3 types of car lift including the type above, which was the most inconvenient and troublesome of the lot. Two problems, first was getting it into the air, with is a super effort with the crank handle provided or you need to use a VERY powerful drill, my 18v Lion De-walt wouldn't touch it. Second was that you need a car width of space at the side so it can be rolled under the car you want to work on. The Second type was like this https://www.gumtree.com/p/other-power-tools/car-lift/1362304555it would have been great for the Morgan as the arms are positionable and it lives permanently under the car, best used with some low drive on ramps at the side as it's a bit bulky. Tips hydraulically too. Current lift (and the best in my opinion except it doesn't tilt) is like this https://geg.co/product/eurotek-mrs3-scissor-lift/?v=79cba1185463Its much neater when not in use, gives full access underneath the car, its far more stable than either of the other types and low enough to drive straight over. Only downside is the car as to be carefully positioned over the lift as the chassis is only just wider than the inner faces of the lifter pads.
94 plus 8 in Westminster Green - I think!
[Re: Roady]
#657269
19/08/20 07:32 PM
19/08/20 07:32 PM
Posts: 2,949 Co Wexford, Ireland
Robbie
Co Wexford, Ireland
I use a 1inch thick wood strip on top of the rubber on the lift rails. This then takes the puncture of the various bolts and is easily removed after use - thus the rubber strips remain in pristine condition!!
Heath Robinson is alive and well !
Cheers!
Robbie 2018 Plus4 - Snoopy 181-WX-3082
[Re: Roady]
#657281
19/08/20 09:04 PM
19/08/20 09:04 PM
britmog
I still like my EZ Car Lift all sides access with the big wheels attached can easily move Morgans around and the lift itself can be easily moved from one Moggy to another. Best investment I've made use it all the time and not just for the Morgan's.
[Re: Roady]
#657443
20/08/20 07:16 PM
20/08/20 07:16 PM
Robbie
Co Wexford, Ireland
Roady, What drill do you use as I find I have to manually get the lift up about a foot before my drill can take over
Cheers!
[Re: Roady]
#657468
20/08/20 08:25 PM
20/08/20 08:25 PM
Posts: 1,301 Staffordshire
IvorMog
Staffordshire
Robbie, so you have one of the tilting lifts?
I ask because I was also looking at these and wondered if you can get it far enough forward to give a reasonable point of balance.
Does it tend to come up nose first or tail first?
And no tendency to slide on the runners when the car is tilted?
Bob
1999 4/4 2 litre Zetec
