1 registered members (sbarracl),
190
guests, and 20
spiders. |
Topics43,863
Posts738,739
Members8,072
Most Online1,033 Dec 28th, 2019
Re: Revs not going to idle
[Re: donaldosaurus]
#745101
19/06/22 02:04 AM
19/06/22 02:04 AM
Posts: 39 Australia
PaulM3W
Australia
Hey all, similar issue at the moment, rpm remains high during gear changes and on stopping sometimes takes time for rpm to decay to idle. Definitely worse when engine is hot. (Ambient temp was 14 degrees C so not exactly a hot day!) Throttle cable moving freely, hard to tell if the butterfly is sticking while driving but when moved by pressing with my thumb it returns strongly to the closed position...I have cleaned the idle air control valve which was gunky and still has some baked on black stuff that has not wiped off. Will see how the next drive goes...
M3W 2017 RAF blue.
[Re: donaldosaurus]
#745167
19/06/22 06:51 PM
19/06/22 06:51 PM
Posts: 1,300 Southern Vermont
Michael H
Southern Vermont
This happened to me last year. The spring behind the gas pedal broke. The spring at the top of the motor is not strong enough to do the job itself. I replaced the. lower spring with a 'close enough' spring and life resumed like normal. It is a pain to do as you have to go through the access hole above the assembly and hope your wrist and fingers are flexible and strong enough to do the job.
[Re: Bluebricked]
#745706
24/06/22 01:40 PM
24/06/22 01:40 PM
Posts: 3,639 Port Orchard, WA.
LightSpeed
Port Orchard, WA.
I have been chasing a similar problem for a while. The engine sometimes took some time to return to idle at a stop and between shifts things could get lumpy as the engine hunted around for what RPM it really wanted to be at. Finally found the right guy who was a former S&S-sponsored racer who said my TPS (Throttle Position Sensor) needed to be adjusted. He manually adjusted the sensor while watching the readouts on the S&S software and my car is back to a perfect tune. I guess there are throttle stops that wear over time and can throw things kind of out of wack. You can't visually confirm anything is worn, because the throttle snapped back and close perfectly. Except my RPMs were not decaying to an idle and RPMs sometimes remained high between shifts. Hope this helps. Good info to know.
[Re: donaldosaurus]
#745775
25/06/22 02:40 AM
25/06/22 02:40 AM
Posts: 39 Australia
PaulM3W
Australia
Hey all, Results of my rest drive were very pleasing. After cleaning the gunk off the idle air control valve rpm decay is normal again! I actually noticed that I had slowly been adjusting my driving to compensate for the slow rpm decay, I am back to blipping the throttle on gear changes!
M3W 2017 RAF blue.
[Re: donaldosaurus]
#745811
25/06/22 09:30 AM
25/06/22 09:30 AM
Posts: 1,527 Cheshire, UK
nippymog
Cheshire, UK
Could you describe or have a picture of where the idle air control valve is please? Sorry , it is described clearly above doh I must read posts properly !
[Re: donaldosaurus]
#746754
03/07/22 02:40 PM
03/07/22 02:40 PM
nippymog
Cheshire, UK
I also have occasional slow return to idle, and have just got round to checking it. I have checked the throttle linkage etc and all seems ok , so I want to check the Idle Air control described above as being on top of the throttle body. Is it this ? ![[Linked Image]](https://www.tm-img.com/images/2022/07/03/IMG_3778.jpg) If so what do I clean? it all seems clean to me ! ![[Linked Image]](https://www.tm-img.com/images/2022/07/03/IMG_3781.jpg) Thanks
