16 registered members (Sir Percival, Tresco, Paulxj, Marmota, DJC, IcePack, +8Rich, SFG, JohnS, jimmyw, NeilMB, RedThree, rv6, Ritchie B, Pmh44, Spanner Juggler), 186 guests, and 18 spiders.
John V6 364
+8Rich 214
TBM 149
CooperMan 123
front stub axle failure
by bruce. 23/10/20 11:06 PM
Lockdown!
by Gambalunga. 23/10/20 05:54 PM
LAND ROVER..GRAHAM G4FUJ
by KEVFITZ. 23/10/20 02:11 PM
Battery...Again!
by Peter J. 23/10/20 02:01 PM
Continental Trail Attack 3 front tyres
by WarBird. 23/10/20 01:42 PM
Pop Master
by lowebird. 23/10/20 09:50 AM
AERO S3 NEW FACE...
by KEVFITZ. 23/10/20 07:19 AM
Another Lancastrian
For Sale: Luggage rack & front bumper
Malvern Show 2
Malvern Show 1
MGB`s can corrode..?
LOLO 04, sss6000, Dylan614, kbac, Gwyn D
7205 Registered Users
Topics39,655
Posts655,843
Members7,205
Most Online1,033
Dec 28th, 2019
No Birthdays
Cobra Lamp with a Chrome Bezel #658884
27/08/20 05:06 PM
27/08/20 05:06 PM
Hill Head, Hampshire, Uk
Frank 4x4 Offline OP
Green & Grown Up
It sounds stupid but when polishing the R100 I realised that the Cobra Stop Lamp was missing a Chrome Bezel similar to the other 4 rear lamps.
Researching my photos I found that a bezel was not part of that lamp model.
Then I found these photos of a Le Mans 62 car which has a Bezel. Speaking with Keith it is not on the Le Mans 62 Register so unable to ask the owner what lamp has been fitted.
Quite some time spent searching the internet for a 70/72mm Diameter version of the larger tail lamps has so far drawn a blank.
I wondered if any other members here had been down that route searching for such a lamp?
Frank
20 Comments
Re: Cobra Lamp with a Chrome Bezel [Re: Frank 4x4] #658961
28/08/20 08:58 AM
28/08/20 08:58 AM
Seamill, Ayrshire
Max5 Offline
Max5  Offline
Seamill, Ayrshire
Frank - the photo is mine - At the time I owned the two-tone Roadster in the foreground. It was taken on 5/5/07 during a "Jockmog" weekend at the MacDonald Hotel, Kinloch Rannoch. The Le Mans belonged to Frank Manclark who has had a number of other Morgans in the interim and I believe that he has a +8 Le Mans at this time.
Regards,
Don.
Re: Cobra Lamp with a Chrome Bezel [Re: Frank 4x4] #659092
28/08/20 04:50 PM
28/08/20 04:50 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Frank, just had a look at my Roadster as there is also no chrome ring, it does look very similar to the diameter of the ring used on the later round rear reflectors, perhaps they would fit ?
Re: Cobra Lamp with a Chrome Bezel [Re: Max5] #659279
29/08/20 06:52 PM
29/08/20 06:52 PM
Green & Grown Up
Green & Grown Up
Hello Don, Thank you for the info on Frank Manclark. I hope that you do not mind my using your photo in this quest.
I wonder if Frank changed that lamp and what lamp model he used?
The Cobra opening is only 70 mm which is too small to take the same main stop lamp who's base plate forms the bezel. I will have to check out the Reflector Jon.
There is an alternative style Stop Lamp with the 'push fit' glass & bezel which was used on the original Mini. This is 72mm diam. but is not a match to the style of the other lamps as
Frank's is in the photo
Re: Cobra Lamp with a Chrome Bezel [Re: Frank 4x4] #659392
30/08/20 03:56 PM
30/08/20 03:56 PM
Seamill, Ayrshire
Max5 Offline
Max5  Offline
Seamill, Ayrshire
Hi Frank,
Absolutely no problem with using the photo in your quest. I may see Frank at an event in mid September and if I do I will ask him about the Cobra on the Le Mans.
Don.
Re: Cobra Lamp with a Chrome Bezel [Re: Frank 4x4] #659588
31/08/20 06:42 PM
31/08/20 06:42 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Frank, I've had time to look properly, not good news, the reflector bezel is approx 5mm too small in diam & I've measured the classic Mini which 'roll in' much more to hold the glass lens and are therefore even smaller diam at the inner edge
Re: Cobra Lamp with a Chrome Bezel [Re: Frank 4x4] #659592
31/08/20 06:59 PM
31/08/20 06:59 PM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
When I‘m right there where cheaper lamps without chrome on Land-Rovers.
Also on some Minis where used orange lamps without chrome as indicator lamps.
René
This ones? https://www.ebay.de/itm/2-X-RTC5523-Land-Rover-DEFENDER-90-110-STOP-TAIL-LAMP-PAIR-TO-1994/264457684100?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200520130048%26meid%3D002748bb8927446f93a4e5566e2a496b%26pid%3D100005%26rk%3D1%26rkt%3D12%26mehot%3Dag%26sd%3D252784170003%26itm%3D264457684100%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithBBEV2bDemotion%26brand%3DAftermarket+Products&_trksid=p2047675.c100005.m1851
2018 plus4
Re: Cobra Lamp with a Chrome Bezel [Re: xc68anc] #659687
01/09/20 01:19 PM
01/09/20 01:19 PM
Petersfield, Hampshire
Ian Wegg Online content
Ian Wegg  Online Content
Wow, those eBay links are getting longer and longer!
Here is the succinct version: https://www.ebay.de/itm/264457684100
1980 Royal Ivory 4/4 4-seater.
Re: Cobra Lamp with a Chrome Bezel [Re: Max5] #659845
02/09/20 11:21 AM
02/09/20 11:21 AM
Green & Grown Up
Green & Grown Up
Originally Posted by Max5
Hi Frank,
Don.
Don,
That would be great if you could ask Frank. Hopefully he was the one who fitted the Bezelled Lamp.
Frank L.
Re: Cobra Lamp with a Chrome Bezel [Re: Frank 4x4] #661592
11/09/20 11:20 AM
11/09/20 11:20 AM
Seamill, Ayrshire
Max5 Offline
Max5  Offline
Seamill, Ayrshire
Frank - see PM
Don.
Moderated by  Aeroman
