6 registered members (Heinz, TBM, JMcL, Arwyn Williams, Hamwich, RichardV6), 306 guests, and 13 spiders.
OZ 4/4 137
John V6 125
+8Rich 118
CooperMan 111
Luddite 110
JJD1776, Newboy, Tractor Driver, Phil Bordeaux, Slushymud
8127 Registered Users
M3W Luggage Rack on eBay
by Bunny. 30/09/22 09:06 AM
Shock absorbers
by William s. 29/09/22 03:31 PM
what colour
by GrantAnderson. 29/09/22 12:51 PM
Sidescreen window sticking
by Felix42. 28/09/22 09:22 PM
CANBUS & LEDs
by Buzz44. 28/09/22 02:32 PM
S1 Aero on live UK online auction - Ends 27 Sept
by Volvos60s60. 28/09/22 08:07 AM
MORGAN SUPER 3 SUPER CLASSIC
Mirror
Fun in the Sun
My 1991 Plus 8
Morgan Super 4 EV
Topics44,101
Posts743,511
Members8,127
Most Online1,033
Dec 28th, 2019
Richard Edwards
Revs not going to idle #657755
22/08/20 12:26 PM
22/08/20 12:26 PM
Dumfries and Galloway
donaldosaurus Offline OP
Hello fellow three wheelers,
I am noticing a reluctance for engine to reduce to idle. When changing gear it does not reduce revs despite throttle being lifted off. Stranger still I stopped after a run and was still at 3000 revs.
Only done 400 miles and I remember early cars had throttle cable with a big bend above engine but maybe the cowl for fan modification causes a poor route?
2022 Plus Four, Range Rover Vogue SDV8, Lotus Elan.
Re: Revs not going to idle [Re: donaldosaurus] #657805
22/08/20 04:14 PM
22/08/20 04:14 PM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
Cable routing, unless done with insufficient radii, is unlikely to be the culprit, as if done wrong it would have been apparent from day 1.
Don't discount a sticking throttle pedal. The non sealed footwells and under dash area of the M3W allow all sorts of dust and debris into the pedal area.
After a newly developed issue this spring with a slightly high (1200-1400rpm) idle, a bit of sleuthing revealed the throttle cable had zero slack at the throttle body (there should be just a small but discernible amount) and traced the issue back to a sticking pedal. A bit of spray oil at the pedal pivot later, the pedal was freed off and normal idle returned.
One of my many winter projects this year will be to remove and clean/plate/repaint the pedal assembly and see if I can't come up with simple mods to facilitate periodic lubrication of the pedal pivots without standing on ones head.
Late 2012 M3W
Re: Revs not going to idle [Re: donaldosaurus] #657809
22/08/20 04:34 PM
22/08/20 04:34 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
If the throttle cable seems to be working correctly the problem could be with the Idle Air Control. It sits on the top of the throttle body with a plug going to it. They can be cleaned but that is unlikely to be the problem with your almost new car and it will be a back to the dealer job for warranty work I expect.
Re: Revs not going to idle [Re: donaldosaurus] #657866
23/08/20 12:34 AM
23/08/20 12:34 AM
Georgia, USA
TheScottFraser Offline
Georgia, USA
I agree with above. Start by cleaning the idle air control valve and the passage in the throtle body it sits in. I use q-tips to clean this so I don't spray crap down the i take into the engine.
Re: Revs not going to idle [Re: donaldosaurus] #657871
23/08/20 01:57 AM
23/08/20 01:57 AM
Bluebricked Offline
Bluebricked  Offline
I also have this problem on occasion. Except with my car the idle is a bit higher than normal and rougher and occurs both at the stoplight or when shifting gears. A blip of the throttle usually works to calm it down at the stoplight.
So it sounds like I need to check the throttle cable slack, gas pedal pivot point, and clean or replace the idle air control valve.
Re: Revs not going to idle [Re: donaldosaurus] #657972
23/08/20 02:17 PM
23/08/20 02:17 PM
Many thanks for input. Pedal seems to move smoothly. Cleaned sensor. Not much slack in cable. Still the same. Frustrated
Re: Revs not going to idle [Re: Bluebricked] #657978
23/08/20 02:29 PM
23/08/20 02:29 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
Mine had similar symptoms - turned out to be a frayed throttle cable at the throttle body end causing the throttle to stick open slightly.
If it is this and it gets worse then eventually the throttle will stick open and once you switch the engine off and try to restart it the fuel pump will run, the engine will turn over but it won't fire up.
Red Leader drive
Re: Revs not going to idle [Re: donaldosaurus] #658048
23/08/20 10:15 PM
23/08/20 10:15 PM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
Two more ideas:
verify the cable is properly routed at the throttle body. If the throttle is opened manually for a cleaning or inspection, the cable can come out of the groove in the 'disc' on the side of the throttle body.
when the high idle situation occurs, shut off the machine and without touching the throttle, remove the air cleaner to inspect the position of the throttle plate (which should be totally closed).
Late 2012 M3W
Re: Revs not going to idle [Re: donaldosaurus] #660273
04/09/20 12:02 PM
04/09/20 12:02 PM
I thought it was throttle cable but dealer found sticky butterfly valve . Replacement cable still not arrived from MMC!
G56 wings arrived today!!!
Re: Revs not going to idle [Re: donaldosaurus] #660278
04/09/20 12:28 PM
04/09/20 12:28 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Sticky throttle body probably from oil/gunk being pumped into the throttle body from the cam chest vent tube.
