Morgan Aero 8
14 registered members (MJF, Roady, Hamwich, aerotaff, Graham, G4FUJ, yobtaf, Paulxj, Malcolm T, Ian Wegg, Rog G, KennyW, JohnHarris, Alistair, Spanner Juggler), 152 guests, and 22 spiders.
+8Rich 322
John V6 288
Peter J 149
TBM 147
exploded compressor vid.
by Luddite. 18/01/21 07:59 PM
2019 Plus 4 Freon?
by Morgan Atlanta. 18/01/21 04:46 PM
Audi fresh out of chips
by +8Rich. 18/01/21 03:38 PM
Starting - Battery?
by Amrum. 18/01/21 12:57 PM
third brake light wiring?
by Hogzilla. 18/01/21 02:12 AM
Mystery Wire
by OhioM3W. 17/01/21 11:36 PM
Surplex adjustable rear shocks
by Mark H. 17/01/21 10:50 PM
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
Boddam and Ravenscraig
First post
Steam loco build
PH1954, HJF, Valespecial, Berlin, Spizz Oil
7327 Registered Users
Topics40,290
Posts671,097
Members7,327
Most Online1,033
Dec 28th, 2019
BertR, KennethM
Page 3 of 5 1 2 3 4 5
Re: Early headlamp [Re: Viper] #660288
04/09/20 01:10 PM
04/09/20 01:10 PM
Scotland
KevinMcR Offline
KevinMcR  Offline
Scotland
Does the quarter glass panel adjust? I have the same issue and dealer adjusted the striker plate as it was lifting the door up but it is still too tight and the quarter glass frame is still hitting slightly so can't get the paint redone yet.
Dealer said it was best they could get without shaving the wood on the door cap.
Re: Early headlamp [Re: Viper] #660294
04/09/20 01:23 PM
04/09/20 01:23 PM
Sevenoaks,Kent
Viper Offline OP
Sir S1'a'lot
Viper  Offline OP
Sir S1'a'lot
Sevenoaks,Kent
If they’ve lifted the stricken plate it will make the 1/4 closer.
I thought about spacing the hinge at the point it bolts to the hinge post but in the end I elongated the mounting point where the long front guild channel (which also secures the 1/4 glass) where it meets the horizontal arm rest stay support. This makes it possible to push the guide forward tilting the 1/4 back at its highest point
That might not make sense but I’ll get Nick to post a pic.
2000 Plus 8 4.6
2002 Aero 8 S1
Re: Early headlamp [Re: Viper] #660301
04/09/20 01:45 PM
04/09/20 01:45 PM
Scotland
KevinMcR Offline
KevinMcR  Offline
Scotland
Cheers Viper. Would appreciate pics. They actually dropped the plate by shaving some material fro bolt holes which stopped the door being lifted so much and that gained 2mm but still not enough.
Re: Early headlamp [Re: Viper] #660309
04/09/20 02:06 PM
04/09/20 02:06 PM
Cambridgeshire
asbojohn Offline
le Asbo du Bling
asbojohn  Offline
le Asbo du Bling
Cambridgeshire
Your taking this seriously I though you would have sold it by now hide
Slowly going green
Re: Early headlamp [Re: Viper] #660331
04/09/20 03:38 PM
04/09/20 03:38 PM
Buckinghamshire
NickCW Offline
NickCW  Offline
Buckinghamshire
Aero 8 S1
M3W - Green Shark
Re: Early headlamp [Re: Viper] #660334
04/09/20 03:48 PM
04/09/20 03:48 PM
Scotland
KevinMcR Offline
KevinMcR  Offline
Scotland
Fantastic. Cheers both that explains it.
Re: Early headlamp [Re: KevinMcR] #660337
04/09/20 03:52 PM
04/09/20 03:52 PM
Sevenoaks,Kent
Viper Offline OP
Sir S1'a'lot
Viper  Offline OP
Sir S1'a'lot
Sevenoaks,Kent
Got a pic Kev, I’m lost?
2000 Plus 8 4.6
2002 Aero 8 S1
Re: Early headlamp [Re: asbojohn] #660339
04/09/20 03:55 PM
04/09/20 03:55 PM
Sevenoaks,Kent
Viper Offline OP
Sir S1'a'lot
Viper  Offline OP
Sir S1'a'lot
Sevenoaks,Kent
Shut it you. I’m in it for the long haul
2000 Plus 8 4.6
2002 Aero 8 S1
Re: Early headlamp [Re: KevinMcR] #660340
04/09/20 03:57 PM
04/09/20 03:57 PM
Sevenoaks,Kent
Viper Offline OP
Sir S1'a'lot
Viper  Offline OP
Sir S1'a'lot
Sevenoaks,Kent
Actually I started looking at this area to get the 1/4 light to sit against the windscreen A pillar at the same angle.
So I’ve spaced out that hole also to tilt the top of the 1/4 glass in too and also bringing the side window in closer to the hood.
2000 Plus 8 4.6
2002 Aero 8 S1
Re: Early headlamp [Re: Viper] #660341
04/09/20 03:58 PM
04/09/20 03:58 PM
aerotaff Online content
aerotaff  Online Content
Trouble is when we were kids the Mecano set never had any wood in it to practice on.
