21 registered members (IMHO, JoeSpeetjens, NelsonG, Leroy, 2017 Betty, DirkM, HJP, drewg, bmgermany, JohnHarris, jpeck, John07, Robin Askew, stefan s, BobtheTrain, Mick Annick, John Winn, TBM, Marmota, Heinz, Moggo),
136
guests, and 24
spiders. |
Jigsaw
by David_E. 24/01/21 03:49 PM
Topics40,332
Posts672,053
Members7,333
Most Online1,033 Dec 28th, 2019
Re: Early headlamp
[Re: Viper]
#660294
04/09/20 01:23 PM
04/09/20 01:23 PM
Posts: 1,553 Sevenoaks,Kent
Viper
Sir S1'a'lot
Sir S1'a'lot
Sevenoaks,Kent
If they’ve lifted the stricken plate it will make the 1/4 closer.
I thought about spacing the hinge at the point it bolts to the hinge post but in the end I elongated the mounting point where the long front guild channel (which also secures the 1/4 glass) where it meets the horizontal arm rest stay support. This makes it possible to push the guide forward tilting the 1/4 back at its highest point
That might not make sense but I’ll get Nick to post a pic.
2000 Plus 8 4.6 2002 Aero 8 S1
Re: Early headlamp
[Re: Viper]
#660309
04/09/20 02:06 PM
04/09/20 02:06 PM
Posts: 3,770 Cambridgeshire
asbojohn
le Asbo du Bling
le Asbo du Bling
Cambridgeshire
That might not make sense but I’ll get Nick to post a pic. Your taking this seriously I though you would have sold it by now
Slowly going green
Re: Early headlamp
[Re: KevinMcR]
#660337
04/09/20 03:52 PM
04/09/20 03:52 PM
Viper
Sir S1'a'lot
Sir S1'a'lot
Sevenoaks,Kent
Cheers Viper. Would appreciate pics. They actually dropped the plate by shaving some material fro bolt holes which stopped the door being lifted so much and that gained 2mm but still not enough. Got a pic Kev, I’m lost?
Re: Early headlamp
[Re: asbojohn]
#660339
04/09/20 03:55 PM
04/09/20 03:55 PM
Viper
Sir S1'a'lot
Sir S1'a'lot
Sevenoaks,Kent
That might not make sense but I’ll get Nick to post a pic. Your taking this seriously I though you would have sold it by now  Shut it you. I’m in it for the long haul
Re: Early headlamp
[Re: KevinMcR]
#660340
04/09/20 03:57 PM
04/09/20 03:57 PM
Viper
Sir S1'a'lot
Sir S1'a'lot
Sevenoaks,Kent
Cheers Viper. Would appreciate pics. They actually dropped the plate by shaving some material fro bolt holes which stopped the door being lifted so much and that gained 2mm but still not enough. Actually I started looking at this area to get the 1/4 light to sit against the windscreen A pillar at the same angle. So I’ve spaced out that hole also to tilt the top of the 1/4 glass in too and also bringing the side window in closer to the hood.
