0 registered members (), 203 guests, and 6 spiders.
+8Rich 333
John V6 261
TBM 191
CooperMan 152
Alistair 142
Hello! - first post on here
by Cumbriankeith. 26/09/20 03:24 PM
Blackjack Avion
by IMHO. 26/09/20 12:41 PM
Workshop Note: LED Headlamps
by DaveW. 26/09/20 12:28 PM
LED sidelights & headlights
by John V6. 26/09/20 11:12 AM
Speedster Wheels
by Peter J. 26/09/20 11:01 AM
VDO Instrument Manual
by IvorMog. 25/09/20 07:19 PM
How now brown cow
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,465
Posts651,601
Members7,166
Most Online1,033
Dec 28th, 2019
No Birthdays
Coolant +8 #662472
16/09/20 07:48 AM
16/09/20 07:48 AM
Cheshire
Fus969 Offline OP
Fus969  Offline OP
Cheshire
Hi all I’ve just fitted an aly rad to my 97 +8 and have been doing a bit of research on coolant / antifreeze and I’m none the wiser so advice would be appreciated, do I go for ready mixed OAT ( organic ) or silicate based , concentrate with distilled water or tap water ? It just strikes me as odd that the engine is aluminium block and silicate based was recommended in one manual then a site I visited said organic for aluminium rads is best or am I just being to over cautious after spending a few quid on a new rad ?
Re: Coolant +8 [Re: Fus969] #662530
16/09/20 01:12 PM
16/09/20 01:12 PM
County Down
lightsphere Offline
lightsphere  Offline
County Down
Sounds like the perfect opportunity to go for Evan Waterless, I have a 97 Plus 8 with new alloy rad and that is what I went for.
Re: Coolant +8 [Re: Fus969] #662544
16/09/20 01:48 PM
16/09/20 01:48 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
There's a lot of mixed metals on a Mog cooling system, I personally would not use OAT & would stick to the more traditional Glycol types
I know some like Evans, but I think it's very heavily advertised wet snake oil & hugely overpriced
Re: Coolant +8 [Re: Fus969] #662588
16/09/20 05:32 PM
16/09/20 05:32 PM
Northern California
davewhite Offline
davewhite  Offline
Northern California
I use traditional IAT in my 2003 +8. I still have the factory radiator.
Dave White
2003 Plus 8
Re: Coolant +8 [Re: lightsphere] #662596
16/09/20 06:20 PM
16/09/20 06:20 PM
Hertfordshire
Steve3.9+8 Offline
Steve3.9+8  Offline
Hertfordshire
I also used Evans waterless coolant after fitting an ally rad five years ago, Been very happy so far👍👍
1997 Indigo Blue +8
Re: Coolant +8 [Re: Fus969] #662621
16/09/20 08:20 PM
16/09/20 08:20 PM
Cotswolds
Treesurveyor Offline
Cotswolds
https://www.gomog.com/allmorgan/plus8coolant.html
Almost everything you could want to know regarding traditional (non waterless) coolant.
06 Saab 93
Re: Coolant +8 [Re: Fus969] #662814
17/09/20 08:22 PM
17/09/20 08:22 PM
Cheshire
Fus969 Offline OP
Fus969  Offline OP
Cheshire
Thanks for the reply’s very helpful, waterless doesn’t seem like an option after looking at gomog so I’ve gone for distilled water and a glycol concentrate . I think I need a beer now
Re: Coolant +8 [Re: Fus969] #662892
18/09/20 10:38 AM
18/09/20 10:38 AM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
All this talk of antifreeze and knowing some +8’s are a bit marginal on cooling I thought I’d dig out my old notes from trying to cool tuned Minis I’ve tweaked
The best coolant is actually pure water, distilled to remove hardness & bits, this will not then contribute to corrosion & has the best heat capacity
Antifreeze (ethylene glycol) heat capacity is only 2.42 jules, water 4.20 & it’s denser than water, so when you crunch the numbers it actually carries around 37% less heat per volume than water
So for simplicity if we call water 1.0, then a 25% antifreeze mix will have a heat capacity of 0.91 and a 50% mix just 0.82
As you can see the less antifreeze, the better the ability of the water to move heat from the engine to the radiator, BUT of course you need some corrosion protection & resistance to winter freezing so we use antifreeze, but it’s not good practice to use too much just to be safe
As an aside to this the various ‘waterless’ coolants blend of magic additives is mainly…taadaa!.. ethylene glycol.., you pay’s your money & take your choice, but remember it WILL reduce vital heat transfer
Re: Coolant +8 [Re: Fus969] #662907
18/09/20 11:53 AM
18/09/20 11:53 AM
Llanelli
sospan Offline
sospan  Offline
Llanelli
Yesterday I jury rigged a flexible pipe totry getting extra air to the rad. The number plate box extends back well past the bottom of the rad and about 10-15% of the rad is shielded from the grill airflow. I went for a run and it does have an effect, though small. The gauge showed about 2 deg lower until traffic slowed things down. Worth investigating more though so will put a second one on and do some better tests. It looks a bit odd at the moment with the rough cut flexi hose visible by the side of the number plate. It is an attempt to duplicate the scoop style air box intake that can replace the original.
Red Plus8
Re: Coolant +8 [Re: Fus969] #662908
18/09/20 12:07 PM
18/09/20 12:07 PM
East Harling, Norfolk UK
Richard Wood Offline
Can recommend one of these inexpensive Refractometers. Once calibrated with pure water they will measure a sample droplet against a scale of freezing point or SG of battery electrolyte to give charge condition.
Most useful I find to see what frost protection you have from coolant.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Moderated by  Aeroman, Simon
