16 registered members (Island Mog, Gordon D, TBM, Rob8, Richard Wood, DJC, Ricardo, Craig Jezz, JohnMat, M3W55, HeadlessBlue, Ray, Stevo666, nick w, KennyW, RJW), 184 guests, and 16 spiders.
John V6 355
+8Rich 247
TBM 161
CooperMan 116
Magnecor leads
by thelastgizmo. 20/10/20 07:27 PM
Historic Vanwall to return
by DirkM. 20/10/20 05:01 PM
Westovers
by Viper. 20/10/20 04:52 PM
HD cyclecar...?
by Luddite. 20/10/20 03:09 PM
The speedometer has gone crazy
by Bilymog. 20/10/20 12:41 PM
Sevenoaks Audi rage..
by +8Rich. 19/10/20 09:42 PM
WHITE MORGAN IN BARRY TODAY
by Sinbad. 19/10/20 05:37 PM
Malvern Show 2
Malvern Show 1
MGB`s can corrode..?
Winter Project
How now brown cow
Ingenious, JMT, Brian G, beetle back, Apple58
7185 Registered Users
Topics39,628
Posts655,259
Members7,185
Most Online1,033
Dec 28th, 2019
Fergie, JMC06
Faulty fuel guage #662919
18/09/20 01:36 PM
18/09/20 01:36 PM
Buckinghamshire UK @ Phnom Pen...
Riverstar Offline OP
The fuel guage on my 2006 4/4 has started to go from zero to full as soon as the ignition is turned on and stays there irrespective of the amount of fuel in the tank. The tank is a Mulfab extended range tank fitted before l bought the vehicle and l assume is fitted with a more sophisticated system thsn the old fashion float which could get stuck (or am I wrong).
Before l start undoing bits on the tank what checks should l take?
Thanks
Chris
2006 4/4 70th Anniversary Edition
2004 3.2 Audi TT Quattro
Re: Faulty fuel guage [Re: Riverstar] #662921
18/09/20 02:09 PM
18/09/20 02:09 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
Check the electrical connections especially the earth.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Faulty fuel guage [Re: britmog] #662922
18/09/20 02:13 PM
18/09/20 02:13 PM
London
MOG 615 Offline
MOG 615  Offline
London
And particularly the earth of the gauge. Normally all the dashboard instruments share a common earth, but I am not so familiar with the 4/4 of that era.
Andy G
1999 +8 , Indigo Blue.
Re: Faulty fuel guage [Re: Riverstar] #662936
18/09/20 03:47 PM
18/09/20 03:47 PM
East Harling, Norfolk UK
Richard Wood Online NoMood
Usually the earth associated with the fuel gauge is at the tank end and connected to one leg of the sender, if not independently then via the sender mounting. In the latter case there will be an earth connection from tank to chassis to check.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Faulty fuel guage [Re: Riverstar] #662966
18/09/20 07:04 PM
18/09/20 07:04 PM
If there was a earth problem wouldn't that result in no reading on the guage not the guage swinging to full?
Re: Faulty fuel guage [Re: Riverstar] #662969
18/09/20 07:54 PM
18/09/20 07:54 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
It could even be an earth fault on the signalling wire between the gauge and sender. i.e. if the signal wire from the gauge to sender is connected direct to earth due to failed insulation along its length,, the gauge will read full. So try disconnecting at both ends and test the wire with a multimeter on ohms range to see if there is a spurious earth connection.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Faulty fuel guage [Re: Riverstar] #662976
18/09/20 09:06 PM
18/09/20 09:06 PM
SimonH Offline
SimonH  Offline
The fuel sender on a 2006 car is part of the in tank fuel pump assembly, and is an arm with a float
I might have a spare at the workshop
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Faulty fuel guage [Re: Riverstar] #662988
18/09/20 10:17 PM
18/09/20 10:17 PM
britmog Offline
britmog  Offline
No not necessarily, a loose or poor connection i.e. dirty can cause the gauge to go to default which is full. It is the simplest place to start fault finding and eliminating factors before starting to dismantle the fuel system.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Faulty fuel guage [Re: Riverstar] #662990
18/09/20 10:25 PM
18/09/20 10:25 PM
britmog Offline
britmog  Offline
Did this start happening after you had filled the fuel tank? If it did had you filled the tank to first click of the pump or did you go beyond and kept filling through a number of clicks? If all this is the case then the float arm could be stuck in the up position, try giving the fuel tank a good shake when the fuel level is around half empty (as best you can estimate)
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Faulty fuel guage [Re: Riverstar] #663004
19/09/20 07:28 AM
19/09/20 07:28 AM
Chester, UK
Grumpy2 Offline
Grumpy2  Offline
Chester, UK
Managed to brim my tank full last weekend, gauge showed 3/4!
Think I may have a sender problem there
94 plus 8 in Westminster Green - I think!
Moderated by  Aeroman, Simon
