17 registered members (Grumpy2, TBM, BuyBritish, Tim1598, David@Belmont, Richard Wood, AZJowett, Terence, PaulV, Bunny, Eurosystem0, sbarracl, M3W55, RB1, Nonsuch, Viper, Ragnar), 169 guests, and 10 spiders.
John V6 365
+8Rich 231
TBM 162
CooperMan 122
Mosquito Back to the Skies
by Steve3.9+8. 21/10/20 07:09 PM
DRIVERS DOOR DROP..
by KEVFITZ. 21/10/20 04:33 PM
Three wheelers galore
by Richard Wood. 21/10/20 03:42 PM
Another Configurator
by Jon G4LJW. 21/10/20 03:23 PM
For all you Landie buffs
by athelstan. 21/10/20 09:26 AM
Anyone used Colourlock on leather?
by Andrew1806. 20/10/20 08:53 PM
Magnecor leads
by thelastgizmo. 20/10/20 07:27 PM
Malvern Show 2
Malvern Show 1
MGB`s can corrode..?
Winter Project
How now brown cow
Ingenious, JMT, Brian G, beetle back, Apple58
7185 Registered Users
Topics39,635
Posts655,424
Members7,185
Most Online1,033
Dec 28th, 2019
paul
Power supply for a GPS speedo #663228
20/09/20 01:52 PM
20/09/20 01:52 PM
Suffolk
John V6 Online content OP
John V6  Online Content OP
Suffolk
On my Brooklands I need a GPS speedo as the factory fit one undereads by 10% and is not inl line of site.
I started powering from the cigarette lighter but of course that is always on , so one day I will drain the battery.
I discovered the radio USB port for a USB stick is actually powered up with the ignition and live even if the USB port is not selected.
So a simple result.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: Power supply for a GPS speedo [Re: John V6] #663255
20/09/20 04:27 PM
20/09/20 04:27 PM
East Harling, Norfolk UK
Richard Wood Online NoMood
If you want a dedicated feed John then a 12 volt fed USB socket could be hooked into the ignition switched light green/white wire on the radio feed loom. This will be available whether radio fitted or not, and also feeds the horns via a 10 amp fuse.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Power supply for a GPS speedo [Re: John V6] #663259
20/09/20 04:31 PM
20/09/20 04:31 PM
Suffolk
Suffolk
Richard,
Ill see how B&C get on re the recalibration. Thanks for the idea though.
Re: Power supply for a GPS speedo [Re: Richard Wood] #663270
20/09/20 05:20 PM
20/09/20 05:20 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
That's what I used, works well & I can leave to TomTom feed plugged in & just forget it
Re: Power supply for a GPS speedo [Re: CooperMan] #663282
20/09/20 06:13 PM
20/09/20 06:13 PM
Costock, South Nottinghamshire...
Paul F Online happy
Paul F  Online Happy
Me too. I bought a radio power cable adaptor off ebay which enabled me to plug into the radio wiring and then connect a USB socket without modifying the car wiring in any way.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: Power supply for a GPS speedo [Re: John V6] #663354
21/09/20 10:38 AM
21/09/20 10:38 AM
Reading
A11OGE Offline
A11OGE  Offline
Reading
what type of reader. I was thinking of doing the same, espacilly for kph.
ps you would have enjoyed West Green House yesterday. 220 cars, with 24 Morgans.
So a simple result.
Re: Power supply for a GPS speedo [Re: John V6] #663386
21/09/20 01:29 PM
21/09/20 01:29 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Are you wanting a GPS unit to use as a speedometer or a specific GPS Speedo?
You could power a gps unit by piggybacking a fuse so you would have dedicated power to it. Just select a circuit that is either on with the ignition or always on and put the fuse in place.
Stephen
2019 M3W leaking oil right off the showroom floor
Re: Power supply for a GPS speedo [Re: John V6] #663416
21/09/20 03:52 PM
21/09/20 03:52 PM
Suffolk
Suffolk
Lightspeed I didn't want to start altering the electrics & am happy with this solution.
Steve. I bough this of fleabay It has a standard display. I have have it stuck on the dash with sticky pads just above the wheel boss.
GPS speedo
Moderated by  Aeroman, Simon
