6 registered members (AZJowett, Barkingdog, linklaw, LightSpeed, Leroy, MarioCP), 196 guests, and 17 spiders.
John V6 366
+8Rich 229
TBM 161
CooperMan 122
2021 Montlhery Vintage Revival
by Jacques. 21/10/20 08:26 PM
Mosquito Back to the Skies
by Steve3.9+8. 21/10/20 07:09 PM
DRIVERS DOOR DROP..
by KEVFITZ. 21/10/20 04:33 PM
Three wheelers galore
by Richard Wood. 21/10/20 03:42 PM
Another Configurator
by Jon G4LJW. 21/10/20 03:23 PM
For all you Landie buffs
by athelstan. 21/10/20 09:26 AM
Anyone used Colourlock on leather?
by Andrew1806. 20/10/20 08:53 PM
Malvern Show 2
Malvern Show 1
MGB`s can corrode..?
Winter Project
How now brown cow
Ingenious, JMT, Brian G, beetle back, Apple58
7185 Registered Users
Topics39,636
Posts655,452
Members7,185
Most Online1,033
Dec 28th, 2019
mac caber, VassilisP
Camber Setting #663403
21/09/20 02:43 PM
21/09/20 02:43 PM
Axbridge, Somerset
E
Eastertown Offline OP
E
Axbridge, Somerset
Hi
I have a recently acquired 1981 4/4 (1600Crossflow). It's in great condition, having had a complete rebuild - pretty much as new, and we are trying to iron out a few little niggles. My question, and please be patient, as I am not proficient with spanners, is to do with the Camber angle.
My handbook states that the camber angle should be 2 degrees, but it does not say whether that is positive, ie top of the wheel leaning out, or negative, leaning in. My car is leaning out by precisely 2 degrees. Is that correct, or should it be leaning in?
Instagram @eastertown
1980 Morgan 4/4
Porsche 986 Boxster S
Abarth 595
Porsche 911 (996) Targa
Re: Camber Setting [Re: Eastertown] #663436
21/09/20 04:55 PM
21/09/20 04:55 PM
East Harling, Norfolk UK
Richard Wood Offline
You want negative camber, i.e. top leaning in. Later cars have adjustment for this at base of kingpins which have rounded ends to acommodate.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Camber Setting [Re: Eastertown] #663442
21/09/20 05:55 PM
21/09/20 05:55 PM
SimonH Offline
SimonH  Offline
Originally Posted by Eastertown
Hi
2 degrees of positive camber is correct for your car.
Zero would be more preferable with modern radial tyres
It can be adjusted by heating the top frame lug where the kingpin is bolted in, and using offset “camber plates” at the bottom of the kingpin
It’s not a job for the amateur, and the track rod between the wheels may need remanufacturing to be longer, so as to allow the correct toe angle to reset
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Camber Setting [Re: Eastertown] #663464
21/09/20 08:01 PM
21/09/20 08:01 PM
UK
BuyBritish Offline
BuyBritish  Offline
UK
Im guessing my 1956 plus 4 needs the same on CROSSPLY, the steering is a little stiff and I believe I have too much toe in, any measurments for toe in ..perhaps 1/8 inch? measured on yhe fron and rear radius of the wheels?
I may look at the roller bearings to fit under the coil springs..or just some lubrication.
[Linked Image]IMG_6688 by Robert & Ali Davies, on Flickr
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
Re: Camber Setting [Re: Eastertown] #663517
22/09/20 08:12 AM
22/09/20 08:12 AM
Article on the subject here.
Moderated by  Aeroman, Simon
