13 registered members (Gordon D, Jacques, twotribes, rockabilly john, BuyBritish, xc68anc, Grumpy2, Clipper, thelastgizmo, sbarracl, TBM, M3W55, Richard Wood), 176 guests, and 12 spiders.
John V6 355
+8Rich 244
TBM 161
CooperMan 116
Magnecor leads
by thelastgizmo. 20/10/20 07:27 PM
Historic Vanwall to return
by DirkM. 20/10/20 05:01 PM
Westovers
by Viper. 20/10/20 04:52 PM
HD cyclecar...?
by Luddite. 20/10/20 03:09 PM
The speedometer has gone crazy
by Bilymog. 20/10/20 12:41 PM
Sevenoaks Audi rage..
by +8Rich. 19/10/20 09:42 PM
WHITE MORGAN IN BARRY TODAY
by Sinbad. 19/10/20 05:37 PM
Malvern Show 2
Malvern Show 1
MGB`s can corrode..?
Winter Project
How now brown cow
Ingenious, JMT, Brian G, beetle back, Apple58
7185 Registered Users
Topics39,628
Posts655,263
Members7,185
Most Online1,033
Dec 28th, 2019
Fergie, JMC06
Fitting LED lights in the under tray #663542
22/09/20 11:01 AM
22/09/20 11:01 AM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
I have seen several trads with lights in the vent holes in the under tray.
I decided to give it a go as part of fitting LED lights to Belle.
The vents are 50mm ID so I bought some plastic plugs & some LED lights.
I also used some reflective silver tape to the rear of the plug.
There will be wires for the wing side lights I don't have under the wings so the next step will be to fix the lights & wire them in. Probably on Thursday.
As a test I ran them of a 12v DC power supply.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: Fitting LED lights in the under tray [Re: John V6] #663548
22/09/20 11:26 AM
22/09/20 11:26 AM
London
MOG 615 Offline
MOG 615  Offline
London
I think these holes were designed for brake cooling ducts to be fitted, but presumably there was no trunking behind them on your Brooklands Roadster?
If you are using them as position lights , they are very low down, I decided to upgrade the wing lights for my +8.
I assume the Roadster does not have a Canbus system protecting the electrical circuits, in which case the use of additional LEDs should be fine?
Andy G
1999 +8 , Indigo Blue.
Re: Fitting LED lights in the under tray [Re: John V6] #663552
22/09/20 11:56 AM
22/09/20 11:56 AM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Andy,
correct not canbus for the lights. Canbus for the indicators though. Several folk have done the same & they have passed the MOT.
Re: Fitting LED lights in the under tray [Re: John V6] #663571
22/09/20 02:58 PM
22/09/20 02:58 PM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
I would fill the front with optical grade resin and tack some form of heatsink on the back, I have had these style of eagle eye LEDs as DRLs on my smart they fail after a year or two, not sure if water ingress or heat failure.
Mark - No Longer driving
Re: Fitting LED lights in the under tray [Re: MOG 615] #663585
22/09/20 03:59 PM
22/09/20 03:59 PM
Oxfordshire UK
E
Eurosystem0 Offline
Eurosystem0  Offline
E
Oxfordshire UK
Originally Posted by MOG 615
Just finished upgrading my 2006 +4 wing lights to DRLs and they dim when main headlights dipped. Isolated wing lights from headlight parking lights. Used radio live from fuse box as DRL power source and fitted £5 voltage sensing relay for auto dimming. Really pleased with the outcome.
Re: Fitting LED lights in the under tray [Re: milligoon] #663613
22/09/20 06:07 PM
22/09/20 06:07 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Mark,
they are supposedly water proof. Time will tell.
Re: Fitting LED lights in the under tray [Re: MOG 615] #663623
22/09/20 06:34 PM
22/09/20 06:34 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
No issues with mine, everything swopped to LED except indicators as I like the longer dwell time with proper bulbs as they flash
Re: Fitting LED lights in the under tray [Re: John V6] #663629
22/09/20 06:40 PM
22/09/20 06:40 PM
UK
BuyBritish Online content
BuyBritish  Online Content
UK
John 'Betsy' has the LED front lights inb the undertray brake cooling duct and they are bright and look the part
[Linked Image]Untitled by Robert & Ali Davies, on Flickr
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
Re: Fitting LED lights in the under tray [Re: John V6] #663632
22/09/20 06:51 PM
22/09/20 06:51 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
I'm sure I met the owners of Betsy in Hartington a few years ago (prior to owning mine), I was on a DofE expedition with the kids, and had a quick chat with them.
1972 4/4 4 seater
Too many ratty motorbikes
Re: Fitting LED lights in the under tray [Re: John V6] #663637
22/09/20 07:12 PM
22/09/20 07:12 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Rob I know but they are heavier bike headlights. Paul told me had to beef up the support to stop them vibrating.
Cooperman has something similar to what I am doing.
Moderated by  Aeroman, Simon
