13 registered members (Jacques, DJC, Black Adder, Gerhard, Richard Wood, Stevo666, IcePack, kankeL, John07, TBM, Craig Jezz, Ray, Island Mog), 185 guests, and 8 spiders.
John V6 355
+8Rich 246
TBM 161
CooperMan 116
Magnecor leads
by thelastgizmo. 20/10/20 07:27 PM
Historic Vanwall to return
by DirkM. 20/10/20 05:01 PM
Westovers
by Viper. 20/10/20 04:52 PM
HD cyclecar...?
by Luddite. 20/10/20 03:09 PM
The speedometer has gone crazy
by Bilymog. 20/10/20 12:41 PM
Sevenoaks Audi rage..
by +8Rich. 19/10/20 09:42 PM
WHITE MORGAN IN BARRY TODAY
by Sinbad. 19/10/20 05:37 PM
Malvern Show 2
Malvern Show 1
MGB`s can corrode..?
Winter Project
How now brown cow
Ingenious, JMT, Brian G, beetle back, Apple58
7185 Registered Users
Topics39,628
Posts655,261
Members7,185
Most Online1,033
Dec 28th, 2019
Fergie, JMC06
1974 4/4 ...steering wheel #663633
22/09/20 06:56 PM
22/09/20 06:56 PM
Norfolk
thelastgizmo Offline OP
Norfolk
What would have been the original fit steering wheel for this model/year? Mine is currently fitted with an Astrali leather rimmed wheel. I do fancy a wood rimmed one and wondered if Astrali was an original fit. Or did Morgan only use MotoLita?
Re: 1974 4/4 ...steering wheel [Re: thelastgizmo] #663635
22/09/20 07:12 PM
22/09/20 07:12 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
My '72 had the Astrali leather rim with the rubber central boss. Have changed to a wood rim. Looks better in my opinion and more vegan friendly smile
1972 4/4 4 seater
Too many ratty motorbikes
Re: 1974 4/4 ...steering wheel [Re: thelastgizmo] #663638
22/09/20 07:14 PM
22/09/20 07:14 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
It's a Mountney - same hole spaces as the Astrali (different number/spacing to Moto-Lita)
1972 4/4 4 seater
Re: 1974 4/4 ...steering wheel [Re: thelastgizmo] #663672
22/09/20 10:16 PM
22/09/20 10:16 PM
Arwyn Williams Offline
Original would have been an Astrali but these are prone to cracking.
You can get a new wood rimmed Astrali for sub 100 quid which would probably fit on your centre boss
Incidentally Astrali bought out the Les Leston name in the early 70's
Arwyn
Re: 1974 4/4 ...steering wheel [Re: thelastgizmo] #663692
23/09/20 07:20 AM
23/09/20 07:20 AM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
I think the new Astralis have the same hole pattern as the Moto-Lita wheels - 9 hole. The originals had only 6 holes, as do the new Mountneys.
They are also around the £100 mark. They do a flat and dish wheel in light wood. If you want dark (like mine) then it's dish only.
Mountney Wheels
1972 4/4 4 seater
Re: 1974 4/4 ...steering wheel [Re: thelastgizmo] #664303
26/09/20 11:00 AM
26/09/20 11:00 AM
Norfolk
Norfolk
TBM is that a flat wheel? Seen an offer for Astralis on ebay with 20% off (so comes out at £75) but will probably need a new boss. I think I have clearance for a flat wheel (current one is dished slightly).
Oh, just seen yours is dished.
Re: 1974 4/4 ...steering wheel [Re: thelastgizmo] #664306
26/09/20 11:04 AM
26/09/20 11:04 AM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
Yep, dished. Works better with my mini (austiin, not small) indicator stalk.......
1972 4/4 4 seater
Re: 1974 4/4 ...steering wheel [Re: thelastgizmo] #664310
26/09/20 11:20 AM
26/09/20 11:20 AM
Norfolk
Norfolk
Mmmm will have to look at that. Currently got the steering wheel off as have dropped the dash to redo the wrinkle finish.
Re: 1974 4/4 ...steering wheel [Re: thelastgizmo] #664311
26/09/20 11:26 AM
26/09/20 11:26 AM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
You can see it in the picture above - much shorter and you can keep it straight rather than the 'double bend' of the Morgan one. I burnt out the original by fitting halogens, but was always smacking the horn with my knee when I was getting in. It's now just the right length with a 13" or 14" wheel (as I have now) so you can easily operate without moving hands from wheel.
You have to swap the connector plugs over, but it's fairly easy.
1972 4/4 4 seater
Re: 1974 4/4 ...steering wheel [Re: thelastgizmo] #664336
26/09/20 01:39 PM
26/09/20 01:39 PM
Norfolk
Norfolk
Just had a look to check clearances. I have a Mountney leather wheel at the moment. I note that the boss skirt has a diameter of 80mm. I have another Mountney boss which is 88mm at the skirt. This fouls the cowl. The steering column doesnt sit central in the cowl. Is yours the same?
Moderated by  Aeroman, Simon
