10 registered members (Malcolm T, M3W55, TBM, Gordon D, Brian G, Phil4/4, RobCol, Scrambledsignals, AlyMatt, Grumpy2), 142 guests, and 13 spiders.
John V6 366
+8Rich 236
TBM 141
CooperMan 128
plus 8 oil pressure relief valve
by Grumpy2. 31/10/20 08:57 PM
shifting
by stanley. 31/10/20 08:52 PM
Front baffle removed
by Hogzilla. 31/10/20 07:17 PM
My Plus 8 is Plus zero
by Viper. 31/10/20 05:52 PM
Rear springs
by thelastgizmo. 31/10/20 02:25 PM
Plus 8 air box upgrade
by Viper. 31/10/20 01:48 PM
RIP Sean Connery
by Paul F. 31/10/20 12:44 PM
The Great Escape Gang does Flixton
Krazy Horse Spacer
Cobra Bezel
Definition of a classic sports car
Another Lancastrian
LOLO 04, sss6000, Dylan614, kbac, Gwyn D
7205 Registered Users
Topics39,721
Posts657,400
Members7,205
Most Online1,033
Dec 28th, 2019
No Birthdays
Creaking kingpins #663846
23/09/20 07:10 PM
23/09/20 07:10 PM
Chester, UK
Grumpy2 Online content OP
Grumpy2  Online Content OP
Chester, UK
Greasing my kingpins tonight and jacking the car up the drivers side lifted with quite a bit of creaking and a jerky motion
They were newly installed just 500 miles ago and were correctly reamed at the time of installation. Filled with grease at the time and re-greased after 200 miles (months ago now!)
Managed About 10 squirts into the top and lower nipples before grease came out As anticipated
All the joints were clean of excess grease before starting and wiped clean after greasing tonight.
So is theirs creaking and jerkiness normal with newish kingpins. The car drives great with no jerkiness or creaking apparent
Thanks
Gary
94 plus 8 in Westminster Green - I think!
Re: Creaking kingpins [Re: Grumpy2] #663849
23/09/20 07:56 PM
23/09/20 07:56 PM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
I‘m inMOGs just for two years, but in classic MINIs for over 40years.
If a suspension is renewed there is the usual service nesseary. It‘s about 1000 miles.
When I read the manual there isn’ t a notice for a service in the early miles.
I think you have it just overdone. From the top there are only around five at the lower end only three pumps to do.
You hear it when it is enough. Than one more pump would be okay.
The sound you hear could be the compressed grease.
René
2018 plus4
Re: Creaking kingpins [Re: Grumpy2] #663854
23/09/20 08:13 PM
23/09/20 08:13 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
Could be that reaming was just a few thou tighter on that side. I believe the test is that after reaming, a greased kingpin inserted into the bush should just about hold its own weight without falling out. I would guess that after some use where the suspension has been worked a bit, (not difficult nowadays to find a bumpy road!)... it will settle down. On the subject of “how many squirts” it all depends of course on the output of your particular grease gun. As you correctly say, wait until the grease exudes and you know you are done. You can’t overdo greasing on kingpins as long as excess is wiped off.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Creaking kingpins [Re: Grumpy2] #663861
23/09/20 08:40 PM
23/09/20 08:40 PM
Surrey
Kevcaster Offline
Kevcaster  Offline
Surrey
At the recent service at BHM the mechanic advised that kingpins sometimes need several hundred miles to wear in and work as they should once that occurs. Your set might just need a little more.
Kevin
2009 Morgan Plus 4 4 seater
Re: Creaking kingpins [Re: Grumpy2] #663868
23/09/20 08:55 PM
23/09/20 08:55 PM
Suffolk
John V6 Online content
John V6  Online Content
Suffolk
I would agree.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: Creaking kingpins [Re: Grumpy2] #663875
23/09/20 09:18 PM
23/09/20 09:18 PM
Solihull
Spanner Juggler Online content
Spanner Juggler  Online Content
Solihull
I would recommend you Jack up and remove road wheel, axle stands if you haven them. Then disconnect the track rod end and move away by turning on full opposite lock.
You can now turn the stub axle from fully one way to the other. Starting at lowest point squirt WD40 at all rub points, start with lower rebound spring to base plate contact area, whilst you spray move the stub back and forth and listen for a change in creak and there you are!
My bet is it’s the top of the main spring rubbing underneath the dust cover where the spring contacts. I always used to put a smear of grease on them and in fact on every rub point. Good news is the noise will probably ‘bed in’ and disappear after a few miles use, wet weather often starts the creaks and groans.
BR
Colin (you didn’t mention year or if you have steering bearings fitted?)
BR Colin
Re: Creaking kingpins [Re: Grumpy2] #663878
23/09/20 09:59 PM
23/09/20 09:59 PM
Chester, UK
Chester, UK
Colin
I’ll give that a go and see what happens, my feeling is that it just needs bedding in given so few miles since reaming due to this ruddy pandemic.
I don’t have bearings but I did renew everything including fitting new ptfe dampers and associated blades
Re: Creaking kingpins [Re: Grumpy2] #663879
23/09/20 10:12 PM
23/09/20 10:12 PM
Suffolk
Suffolk
PTFE dampers? On my cars they were always metal. Or do you mean bushes for the shocks?
Re: Creaking kingpins [Re: Spanner Juggler] #663880
23/09/20 10:23 PM
23/09/20 10:23 PM
SimonH Offline
SimonH  Offline
BR
This^^^^
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Creaking kingpins [Re: Grumpy2] #663881
23/09/20 10:35 PM
23/09/20 10:35 PM
Chester, UK
Chester, UK
No. They replace the bronze blades with a steel thinner blade and ptfe washer, instead of the roller or ball bearings
Came highly recommended by a couple of well known contributors
Lightened the steering and improved the shimmy I had.
See eBay item. 264300098940
Moderated by  Aeroman, Simon
