12 registered members (John Winn, Marc518, +8Rich, Topline123, Bourbonmog, Craig Jezz, Camelot, RichardV6, DavidR, Davetherave, Player99, DickJ), 74 guests, and 15 spiders.
+8Rich 198
John V6 178
Peter J 93
Rosendahl, Vladimir T, 2949olivier, peter tierney, Tom ff
7771 Registered Users
3no Aeros for sale
by PJC. 08/12/21 02:02 PM
Runabout
by Image. 08/12/21 01:35 PM
Braided hoses for the oil tank
by Reevie. 08/12/21 04:16 AM
The Ashes....
by OZ 4/4. 08/12/21 01:32 AM
Adjusting side view mirrors, Plus 4
by LarryS. 07/12/21 07:42 PM
The Video about Making the Morgan Calendar
by Frank 4x4. 07/12/21 07:30 PM
ULEZ 2 a win.
by howard. 07/12/21 03:57 PM
Combat Stress Build A Morgan 2022 Calendar
Short winterride
Morgan Grand Prix 1917 Replica-Progress-12/02/21
Plus 8
November in the New Forest
Topics42,516
Posts713,644
Members7,771
Most Online1,033
Dec 28th, 2019
Worthers +8
Page 1 of 10 1 2 3 9 10
Workshop Note: LED Headlamps #664325
26/09/20 12:28 PM
26/09/20 12:28 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
The standard Trad headlamps are really quite pitiful compared to modern cars, producing a dim yellow glow, which is hardly safe on today’s roads. If you are a fair weather Morgan driver this may not trouble you much. But my early morning outings often begin in the dark, and it can often be dark for quite some time. I have replaced both pairs of headlamps on my Morgans. The Roadster has a pair of Halo sidelamp units designed for Land Rovers. My Plus 4 has Cibie units, sold by Librands. In both cases I fitted good quality H4 bulbs, but the light output is still poor.
First the legal disclaimer. Technically, aftermarket LED bulbs are not road legal according to the Road Vehicles Lighting Regulations, as they are not E marked. Sections 4 & 5 state that dipped beam and main beam headlights are required to have an approval mark - usually E mark or a British Standard mark. For nearly every other application, an approval mark is also required. If the bulbs for your headlights are H4, the “H” stands for Halogen meaning the headlight unit including the reflector has been purposely built for a Halogen bulb. The number that follows the “H” indicates that only an H bulb with the same number can be installed.
Rear brake lights are required by law to operate between 15 and 36 watts, however a 15w LED would produce an immense amount of light, and so is totally unsuitable at that wattage. Unfortunately, the legislation is old and outdated. Written in 1986, there are still many things that need to be changed. For example, the legislation doesn’t take new technologies into account. It was written at a time when the idea of replacing one technology for another within the same headlight unit just wasn’t on the table.
The MOT manual states “Check HID and LED headlamps for mandatory levelling and cleaning devices” and the tester should check the lighting for “Operation“, “Security” and “Condition” which essentially means that they need to make sure that the lights work, and are fitted correctly. Nothing else is mentioned regarding the use of LED headlight bulbs. In respect of self levelling and cleaning devices, section 4.1.5 of the MOT inspection manual states that not all vehicles are fitted with a levelling device, and so if your vehicle doesn’t have one, it would not be tested. With no other mention of after-market LEDs in the MOT guidelines, all that is left is for them to check is that the beam pattern is correct and the colour of the light is predominantly white, white with a blue tint or yellow. Any good quality after-market LED bulbs will meet this criteria. As long as the beam pattern and the colour of the light is correct – then there is no reason an LED upgrade bulb will fail an MOT.
Having made the case that this technology is technically not road legal, I’ll now justify making these changes on the grounds of safety. And also bear in mind that there is a strong anti LED lobby out there, if you search the internet. My headlamp bulbs were sourced from Classic Car LEDs (www.classiccarleds.co.uk)….no connection, (coughs), and other suppliers are out there.
Fitting is fiddly. Be under no illusions about that. The first one I did, probably took me about two hours, as I tried various ways of fitting the control box and much larger bulb unit into the available space in the headlamp cowl. Both my Morgans have plastic headlamp bowls. The headlamp unit will just fit inside the plastic bowl if the black heat sink is reversed. But the control unit has to be fitted behind the plastic bowl inside the cowl. This is a weatherproof component, but inside the cowl is weatherproof anyway. Interestingly inside my cowls showed dried water droplets, but touring Scotland does mean driving in torrential rain over long distances. I wanted to do a quality fit with two holes cut into the plastic cowl, with grommets, but the reality is that the control box wires are only just long enough to reach and the positioning of the box is “suck it and see”. So in the end I put two large holes in the plastic cowl at roughly nine o’clock and three o’clock positions. Then juggled the cowl back into place until I could refit the four self tappers which hold the plastic cowl securely onto the headlamp nacelle. One of the self tappers was odd.........handmade cars eh!
Then the headlamp unit with LED bulb can be connected. One end of the control box wiring is plugged into the H4 three spade plug. The other end is a 4 pin screwed weatherproof connector, with an idiot proof fitting, so I was good. I checked the alignment before removing the old bulbs, on a piece of brown paper, attached to my bench with drawing pins. The new lights needed lowering slightly. I’ll get the alignment checked when I can. A few days later I was out in the dark and was not flashed by anyone approaching, so they obviously don’t dazzle. Light output is transformational. Hopefully the images attached will show the difference. The light is white, rather than yellow, and with a much better spread. So for me, while recognising that these lights are not technically road legal, I feel that the safety improvements are worth making this change. I may at some point change the brake lamps. Still thinking about that!
I might change the Roadster to the Cibie Units, because the dip spread is significantly better than with the Halo lights.
Now the pictures......................
This is one bulb and the control unit.
Mark the position of the "marker".
Two holes in the cowl, with control unit behind.
Headlamp with heat sink.
Dip beam. LED on the right,
Main beam. LED on the right.
Re: Workshop Note: LED Headlamps [Re: DaveW] #664330
26/09/20 01:19 PM
26/09/20 01:19 PM
Suffolk
John V6 Offline
Brooklands Register contact
John V6  Offline
Suffolk
Dave,
when I asked Duncan at Classic Car LEDs about that box he gave me two options.
1. an extension cable so you can run it into the wing area
2. the slightly less powerful bulbs I fitted that don't have that box. Which I chose.
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Workshop Note: LED Headlamps [Re: John V6] #664332
26/09/20 01:32 PM
26/09/20 01:32 PM
South Yorkshire
DaveW Offline OP
DaveW  Offline OP
South Yorkshire
Originally Posted by John V6
Dave,
There's just enough space John....... grin2
Re: Workshop Note: LED Headlamps [Re: DaveW] #664339
26/09/20 01:42 PM
26/09/20 01:42 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Glad to hear it.
Re: Workshop Note: LED Headlamps [Re: DaveW] #664346
26/09/20 01:59 PM
26/09/20 01:59 PM
East Harling, Norfolk UK
RichardV6 Online NoMood
I sense an LEDfest pub meet coming with a "who's got the brightest" shoot out innocent hide
Just need to wait for the clocks to go back.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Workshop Note: LED Headlamps [Re: DaveW] #664375
26/09/20 04:20 PM
26/09/20 04:20 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
Yes, a night time meet in a dark carpark could be fun....
If we are allowed such things...by 25th October....
As an amusing addition to the comment DW made about legislation falling behind technology, as many will know in France drivers are required to carry a spare set of bulbs.
The 2 Mercedes C Class we have have all has LED bulbs, there isn't a single filament or halogen bulb anywhere. Models sold in other European markets have traditional bulbs: my dealer advised me to carry a set of bulbs for the C Class from one of the markets that doesn't have all LEDS, just to keep the Policeman/woman happy.
Power Corrupts.....
Tarka the 'Otter Mog....2014 Plus 8
Tesla Model 3 AWD.
Re: Workshop Note: LED Headlamps [Re: DaveW] #664433
27/09/20 06:35 AM
27/09/20 06:35 AM
It will be a blessing when all cars have full LED lighting. The number I see with failed lights seems to be on the increase and often cars only a few years old. Brake lights especially given some drivers can't travel for more than a few hundred yards without dabbing them even on a straight traffic free road in some cases.
Re: Workshop Note: LED Headlamps [Re: Peter J] #664439
27/09/20 07:36 AM
27/09/20 07:36 AM
Aberdeenshire
Gordon D Offline
Gordon D  Offline
Aberdeenshire
I was faced with a similar problem last year. My car has led headlights that are sealed units, Not practical carrying a spare so just took a standard bulb and crossed my fingers.
Gordon Duguid
2014 plus 4, Montreal blue.
Re: Workshop Note: LED Headlamps [Re: RichardV6] #664458
27/09/20 09:23 AM
27/09/20 09:23 AM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
Automatic transmission and left foot braking with left foot resting permanently on the pedal?
Re: Workshop Note: LED Headlamps [Re: Gambalunga] #664505
27/09/20 01:39 PM
27/09/20 01:39 PM
Northern Capital of Cool
CooperMan Offline
CooperMan  Offline
More likely poor concentration or they've just received a text nono
