Morgan Aero 8
13 registered members (IcePack, Ray, Ian Wegg, Mogdavid, flyfisher, Jon G4LJW, Steve +8, westgardronning, paulmog, SimonH, TBM, Marmota, Billymog), 177 guests, and 22 spiders.
+8Rich 322
John V6 288
Peter J 149
TBM 147
exploded compressor vid.
by Luddite. 18/01/21 07:59 PM
2019 Plus 4 Freon?
by Morgan Atlanta. 18/01/21 04:46 PM
Audi fresh out of chips
by +8Rich. 18/01/21 03:38 PM
Starting - Battery?
by Amrum. 18/01/21 12:57 PM
third brake light wiring?
by Hogzilla. 18/01/21 02:12 AM
Mystery Wire
by OhioM3W. 17/01/21 11:36 PM
Surplex adjustable rear shocks
by Mark H. 17/01/21 10:50 PM
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
Boddam and Ravenscraig
First post
Steam loco build
PH1954, HJF, Valespecial, Berlin, Spizz Oil
7327 Registered Users
Topics40,290
Posts671,102
Members7,327
Most Online1,033
Dec 28th, 2019
BertR, KennethM
Loose trim #664460
27/09/20 09:33 AM
27/09/20 09:33 AM
Scotland
KevinMcR Offline OP
KevinMcR  Offline OP
Scotland
My latest issue seems to be trim that comes loose after every run as shown in the picks below. It appears this has had some sort of sealant on it at some stage which is degrading and coming loose. My issue is I don't want to use something like gorilla glue which would might cause paint issues if the trim needed to be removed for some reason.
Does anyone have any suggestions for glue that will be strong enough but not permanent?
Re: Loose trim [Re: KevinMcR] #664461
27/09/20 09:40 AM
27/09/20 09:40 AM
Suffolk
John V6 Online content
John V6  Online Content
Suffolk
I wolud have thought some sort of evostick which would peel off with light heat like a hair dryer.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Loose trim [Re: KevinMcR] #664469
27/09/20 10:20 AM
27/09/20 10:20 AM
Aberdeenshire
Gordon D Offline
Gordon D  Offline
Aberdeenshire
Silicone would work well, sticks well and easy to peel off.
Gordon Duguid
2013 plus 4, Montreal blue.
Re: Loose trim [Re: KevinMcR] #664472
27/09/20 10:33 AM
27/09/20 10:33 AM
Newcastle Upon Tyne
James B W Offline
James B W  Offline
Newcastle Upon Tyne
Kevin, 'Sikaflex' or 'Tigerseal' is your friend thumbs
Tigerseal
It is messy (but you can remove any excess with Meths or white spirit) .
It sticks very well and ,unlike silicone sealant , will not affect any future paint work you wish to have done.......
James
Range Rover Evoque S
Smart Brabus Convertible
Honda Monkey Z125
Re: Loose trim [Re: KevinMcR] #664477
27/09/20 10:58 AM
27/09/20 10:58 AM
SimonH Offline
SimonH  Offline
Those rubbers were glued with contact adhesive from new
You’ve done well and they’ve lasted 19 years before falling off
We were re-gluing them at PDI on some cars.....
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Loose trim [Re: KevinMcR] #664480
27/09/20 11:07 AM
27/09/20 11:07 AM
Derby
PhilRoyle Offline
PhilRoyle  Offline
Derby
Carbuilder solutions do a nice silicone type beading which sticks like S%$£ and can be stretched to thin it if needed..
Re: Loose trim [Re: KevinMcR] #664484
27/09/20 11:23 AM
27/09/20 11:23 AM
Scotland
KevinMcR Offline OP
KevinMcR  Offline OP
Scotland
Thanks guys. Like the thought of it not affecting future paint as it's on the front balance stone catcher so going with sikaflex crystal clear as tiger seal is coloured and not sure if evo stick products affect paint.
As an aside is this round rubber trim with a slot in it as per the first picture easy to get hold of?
Re: Loose trim [Re: KevinMcR] #664486
27/09/20 11:26 AM
27/09/20 11:26 AM
Scotland
KevinMcR Offline OP
KevinMcR  Offline OP
Scotland
PDI throwing those up is worrying Simon but somehow I'm not surprised.
Re: Loose trim [Re: KevinMcR] #664520
27/09/20 02:59 PM
27/09/20 02:59 PM
Newcastle Upon Tyne
James B W Offline
James B W  Offline
Newcastle Upon Tyne
- yes Kevin , I got some from the Bay of E - but it was a while back so don't have a link.
It shouldn't be too hard to find some.
Wise move to steer clear of silicone on the paintwork ;if you have ever had the dreaded 'fisheyes' in your newly painted finish you will know what I mean..... mad2
James
Honda Monkey Z125
Re: Loose trim [Re: James B W] #664611
28/09/20 06:58 AM
28/09/20 06:58 AM
Aberdeenshire
Gordon D Offline
Gordon D  Offline
Aberdeenshire
James
That's a good point. I've used silicone in the past to re fix door seals that have fallen off, it worked well but could have been an issue
later had the door needed painting. I would have thought a good panel wipe or cleaner would remove any silicone residue but maybe not.
Gordon Duguid
