29 registered members (JBu1, Randall, John07, +8Rich, Dave Collis, MATTMOG, MR11MOG, Alistair, Craig Jezz, Spanner Juggler, TBM, Moggo, keithA, Tim Crump, nick w, Jon G4LJW, jrt, Pmh44, GBpluseight, MJF, DB07, Black Adder, Stewart S, M3W55, JohnHarris, nippymog, Cumbriankeith, Dada, howard),
212
guests, and 19
spiders. |
Topics40,300
Posts671,314
Members7,333
Most Online1,033 Dec 28th, 2019
Re: Limit Fabrications wheel spinner removal tool
[Re: JohnHarris]
#665108
01/10/20 11:28 AM
01/10/20 11:28 AM
Posts: 960 Newton Abbot, South Devon UK
Felix42
There must be a real risk of over-tightening the spinner if using a powerful electric drill. I have the Devil's own job undoing over-tightened spinners because of arthritis in my wrists (too much rugby!). I don't seem able to get my garage not to tighten them too much.
[Re: JohnHarris]
#665122
01/10/20 12:11 PM
01/10/20 12:11 PM
Posts: 3,416 Costock, South Nottinghamshire...
Paul F
Part of the problem is that they self tighten as you drive. Painted wheels are more of a problem than stainless ones as the paint finish tends to “grab” the wheel nut / spinner.
Paul Costock, UK 2014 4/4 Rolls Royce Garnet Red Disco 4 Teddy - 17h1 Irish Draught cross
[Re: Paul F]
#665131
01/10/20 12:43 PM
01/10/20 12:43 PM
Posts: 220 Lytham St Annes, Lancashire
Part of the problem is that they self tighten as you drive. Painted wheels are more of a problem than stainless ones as the paint finish tends to “grab” the wheel nut / spinner. I think that is what may have happened to my wheels, they may not have been off for years and had self tightened to the point that I would not have been able to get them off myself.
2006 4/4 70th (1972) Black LOKI prev 1977 4/4 4 seater Green SEAMUS prev 1985 4/4 Red MOLLY
[Re: Paul F]
#665137
01/10/20 01:39 PM
01/10/20 01:39 PM
Felix42
Part of the problem is that they self tighten as you drive. Painted wheels are more of a problem than stainless ones as the paint finish tends to “grab” the wheel nut / spinner. I had always understood that the spinner would tighten to the correct torque and not too much. Quote from MWS: "Apply the spinner by hand and tighten 3 to 3½ turns; give the spinner a couple of taps with the hammer; lower the wheel to the ground and give the spinner a couple more taps. As long as the hubs are fitted correctly then the spinners will self-tighten and lock as the car is driving. If you hammer the spinners too enthusiastically then you will deform the thread of the spinner and the hub and they are more likely to work loose. Over-tightening also means that if you ever need to replace either the hub or spinner then you will also need to replace the other part as the deformed thread of the old part will not fit with the new thread."
[Re: JohnHarris]
#665143
01/10/20 02:17 PM
01/10/20 02:17 PM
Posts: 127 Netherlands
60Yards
Netherlands
Thomas 2017 Plus4
[Re: 60Yards]
#665144
01/10/20 02:27 PM
01/10/20 02:27 PM
Felix42
You would have to drive backwards very fast for a long way and using your brakes a lot for the spinners to undo.
[Re: JohnHarris]
#665153
01/10/20 03:54 PM
01/10/20 03:54 PM
Posts: 1,424 South Oxfordshire
SFG
South Oxfordshire
Actually that’s a good question. The handbook recommends that you should re-tighten the wheelnuts every time you reverse the car.
SFG 2012 4/4 Sport
[Re: SFG]
#665155
01/10/20 03:59 PM
01/10/20 03:59 PM
Posts: 1,464 Oxon
Craig Jezz
Oxon
Actually that’s a good question. The handbook recommends that you should re-tighten the wheelnuts every time you reverse the car. Thanks for the heads up SFG, I must check mine when I get home tonight!
Craig Jezz
Morgan 4/4 Sports Sand
[Re: JohnHarris]
#665160
01/10/20 04:22 PM
01/10/20 04:22 PM
SFG
South Oxfordshire
Actually It can be difficult to undo the wheel nuts if they’ve been on a while. A spray of warm water helps, which is why many Morgan owners keep a dog in the car
SFG 2012 4/4 Sport
[Re: JohnHarris]
#665161
01/10/20 04:24 PM
01/10/20 04:24 PM
Posts: 18,741 Suffolk
Suffolk
Damn that is what I am doing wrong. Now I am back on wires they will be coming off once a year.
JohnV6 2006 Indigo Blue Roadster S1 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
