13 registered members (JoeSpeetjens, petemog, Rovert, TomS, Tresco, locky1, Dada, Katanazz, Rog G, PhilipNZ, mph, Black Adder, SimonH), 211 guests, and 16 spiders.
John V6 328
TBM 211
+8Rich 203
Watch point reversing light corrosion
by John V6. 29/11/20 04:30 PM
Aerosol paint for Morgans
by Richard Wood. 29/11/20 01:25 PM
How many cheeses in your fridge ?
by +8Rich. 29/11/20 12:33 PM
Tyre age and renewal
by Neil49. 28/11/20 09:54 PM
Oil pressure
by M2AERO. 28/11/20 06:46 PM
1997 Plus 8 tickover
by Phil+8. 28/11/20 04:22 PM
Iridium spark plugs
by Jads. 28/11/20 03:42 PM
More November Sun...
November Sun
Is this a 4 to 3 wheeler conversion?
Sunday Trip Out
New member
E.Gumiero, Grump, Fjmorgan, KJD, Mike Woodroffe
7255 Registered Users
Topics39,951
Posts662,524
Members7,255
Most Online1,033
Dec 28th, 2019
Nicko
DRIVERS DOOR DROP.. #668256
21/10/20 04:33 PM
21/10/20 04:33 PM
YORK
KEVFITZ Offline OP
KEVFITZ  Offline OP
YORK
Lazy post before I research ...but it was picked up on my =4 Supersport that the drivers door is beginning to droop a bit..
This is because I use it a lot !!!..ha ha
So best solution..replace both hinges or get hinge pin replaced .
Any thoughts people ?
I think Phil Royle had his pins replaced and it was a bugger of a job.
I could of course enter from the passenger side while I still can !!!!
Re: DRIVERS DOOR DROP.. [Re: KEVFITZ] #668259
21/10/20 04:35 PM
21/10/20 04:35 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Hearts of England sell over sized pins. Also check all the nuts & bolts are tight
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: DRIVERS DOOR DROP.. [Re: John V6] #668260
21/10/20 04:36 PM
21/10/20 04:36 PM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
This ^^^ smile
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'06 Saab 9-3 Convertible
Re: DRIVERS DOOR DROP.. [Re: KEVFITZ] #668262
21/10/20 04:40 PM
21/10/20 04:40 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
I did the pins on my 4/4 and it wasn't so difficult with oversized pins.
Re: DRIVERS DOOR DROP.. [Re: KEVFITZ] #668266
21/10/20 04:55 PM
21/10/20 04:55 PM
Staffordshire
IvorMog Offline
IvorMog  Offline
Staffordshire
Are you sure it's not just that the hinge screws to the frame need nipping up.
Especially the top hinge.
BTW "Equals 4 Supersport"?? Also lazy somestick
Bob
1999 4/4 2 litre Zetec
Re: DRIVERS DOOR DROP.. [Re: KEVFITZ] #668268
21/10/20 05:01 PM
21/10/20 05:01 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Did the hinge screws on mine a couple of weeks back, made a surprising difference
Re: DRIVERS DOOR DROP.. [Re: KEVFITZ] #668292
21/10/20 07:44 PM
21/10/20 07:44 PM
Chester, UK
Grumpy2 Offline
Grumpy2  Offline
Chester, UK
On mine the hinge screws were tight and the pins were good also.
Taking the door skin off revealed that the nuts were a little lose. Tightened and the door drop has gone.
94 plus 8 in Westminster Green - I think!
Re: DRIVERS DOOR DROP.. [Re: KEVFITZ] #668384
22/10/20 12:56 PM
22/10/20 12:56 PM
Derby
PhilRoyle Offline
PhilRoyle  Offline
Derby
Hi Kev,
I did not replace the pins but some of the captive nuts had made a bid for freedom and on others the screws 1/4" Whitworths!! were a bit stuck. It was easy to get to the ones behind the door but the ones on the bulkhead side were a bit of a so&so and needed arms of an octopus and flexibility of a contortionist. Sadly I`m not a contortionist so that`s why I`ve always had difficulty in making ends meet!
Love & XXXXX
Re: DRIVERS DOOR DROP.. [Re: John V6] #668401
22/10/20 02:38 PM
22/10/20 02:38 PM
Norfolk
thelastgizmo Offline
Norfolk
They didn't have any when I contacted them a few months ago. And they didn't expect to be the highest priority things to produce when they opened up again. May have changed of course. If you find any let me know as I'm after a set!
Re: DRIVERS DOOR DROP.. [Re: KEVFITZ] #668412
22/10/20 03:33 PM
22/10/20 03:33 PM
YORK
KEVFITZ Offline OP
KEVFITZ  Offline OP
YORK
Thanks for your input,,,all screws tight and play is in pin..so will live with it till Mr Worrell comes up with new stock.
Not a major issue.
Moderated by  Aeroman, Simon
