23 registered members (ewn, Gordon D, stefan s, Robbie Mathisen, Redfate, TBM, AlyMatt, Ray, JCK, CooperMan, DirkM, NoelD, John V6, peterd, Saxonian, Sinbad, Scrambledsignals, Mick Annick, Leroy, MR11MOG, dogmog, M3W55, Rog G), 243 guests, and 19 spiders.
John V6 337
TBM 198
+8Rich 196
Aero 8 Start issues
by Vianney Colombo. 01/12/20 05:17 PM
New to the forum and Morgan!
by MorGun 3. 01/12/20 04:54 PM
Forum Rules Reminder - Please Read
by TalkMorgan. 01/12/20 04:44 PM
Aerosol Paint can for Sport Ivory Plus4?
by AlyMatt. 01/12/20 04:16 PM
A little Devon speed camera cheque/check ;-)
by +8Rich. 01/12/20 02:53 PM
For Sale - Plus 4 Baby Doll Minilite wheels
by RogerQ. 01/12/20 12:45 PM
2021 NEC Restoration Show New Dates
by mal. 01/12/20 12:29 PM
FolkMog is celebrating 25th year Anniversary
Best of British IMHO!!!
More November Sun...
November Sun
Is this a 4 to 3 wheeler conversion?
RedSocks, Tim Green, Tyler+8, Karl chapman, Albel
7268 Registered Users
Topics39,966
Posts662,840
Members7,268
Most Online1,033
Dec 28th, 2019
PSS
Page 1 of 8 1 2 3 4 5 6 7 8
Battery...Again! #668594
23/10/20 02:01 PM
23/10/20 02:01 PM
Salisbury, UK
Peter J Offline OP
Formerly known as Aldermog
Peter J  Offline OP
Salisbury, UK
In April 2019 I replaced the original Banner battery, it was 5 years old, so a reasonable life.
The new battery was a YUSA HSB075, from Halfords, with a 5 year guarantee.
In October it was going flat regularly, alternator charging properly, so Halfords replaced it, under warranty.
Now, a year later, it is holding charge for no more than a week, today after 8 days in the garage it is showing 6.2v, so on charge again.
Back to Halfords, but I'm getting a mite fed up with this. I'll get Williams to check the charging rate and voltage, I can't believe that the car is pulling any power with the ignition off: the only device that is "always on" is the radio, it needs a non switched power line to retain station memory.
Any thoughts, collective?
V8s are best....
Tarka the 'Otter Mog....2014 Plus 8
AMG C63 Estate.
Re: Battery...Again! [Re: Peter J] #668595
23/10/20 02:09 PM
23/10/20 02:09 PM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
If your MOG has the factoryfitted immobilizer that‘s the problem.
The factory itself writes in the manual „if the car is out of use for more than three! days connect it to a charger.
My BANNER battery does her work after two years with a time out of use for a week.
My expierence with cheap batteries is very worse. They would work in a daily, but not under „toy conditions“.
René
2018 plus4
Re: Battery...Again! [Re: Peter J] #668598
23/10/20 02:15 PM
23/10/20 02:15 PM
Lancashire
RobCol Offline
RobCol  Offline
Lancashire
Although Yusa appear to be a good quality battery, I would go back to Halfords and ask them to replace it with another make a offer to pay the difference if necessary.
Wouldn't Halfords be able to check your alternator was charging properly?
Rob
4/4 Sport Grey
Re: Battery...Again! [Re: Peter J] #668601
23/10/20 02:38 PM
23/10/20 02:38 PM
Suffolk
John V6 Online content
John V6  Online Content
Suffolk
Ages ago my wife's Golf did this. We found an earth leakage on the headlight switch.
Good luck as this stuff is very hard to find. We only discovered it when the switch failed & the problem stopped.
Do you have a trickle charger? That might help
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: Battery...Again! [Re: Peter J] #668608
23/10/20 02:49 PM
23/10/20 02:49 PM
Salisbury, UK
Peter J Offline OP
Peter J  Offline OP
Salisbury, UK
The car has no immobiliser...
I think the next step is to charge the battery and turn off the "master switch", all Aero 4s have this on the front of the electronics box.
If the battery still discharges it is the battery and yes, I'll go back to Halfords. But if it stays charged then it is a "car issue".....
It is booked into Williams next month for Service, MOT, etc, so they can see what they can find...
Joy.
V8s are best....
AMG C63 Estate.
Re: Battery...Again! [Re: Peter J] #668609
23/10/20 03:05 PM
23/10/20 03:05 PM
Powick
tmg513 Offline
tmg513  Offline
Powick
Disconnect the negative terminal on the battery and bridge it with an ammeter to find if there's a drain.
1972 4/4 2 Seater
Re: Battery...Again! [Re: Peter J] #668626
23/10/20 04:36 PM
23/10/20 04:36 PM
East Harling, Norfolk UK
Richard Wood Offline
Or you could find the keep alive fuse(s) for the ECU or BCU. Remove and put your ammeter set to 10A range across the socket(s). You might be surprised innocent
ETA: if the battery has been allowed to drain to an incredibly low six volts it will have taken a fair chunk of its life due to sulphation. It might not even take a charge now. Whatever, I would keep quiet about that if looking for a replacement from Halfords.
Note also it's the battery that determines the charge current. The alternator is just regulated to a max voltage - you should be seeing at least 14.4 volts on a near fully charged battery at a fast idle, measured at the battery terminals ideally.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Battery...Again! [Re: Peter J] #668636
23/10/20 05:27 PM
23/10/20 05:27 PM
Devonshire
+8Rich Online content
+8Rich  Online Content
Devonshire
I have a clip on current meter that plugs into my Fluke which is worth purchasing for your workshop they are very handy bits of kit, far safer than disconnecting batteries and taking fuses out and it is a perfect interface/buffer for your meter.
Or this sort of stand alone device.
Regards Richard
1994 Connaught Green +8 prev
Re: Battery...Again! [Re: Peter J] #668660
23/10/20 07:38 PM
23/10/20 07:38 PM
Hampton Hill, Middx.
DavidR Offline
DavidR  Offline
Peter, I have been told that if you store your ignition key to close to the vehicle when not in use, then some part of the electrical system doesn't shut down fully. I'm an electrical numpty so can't comment directly, but find it helps with mine to keep the two apart. I had no success with a Ctek and have reverted to a Halfords smart charger, which so far works a treat and keeps it starting happily.
David
Aero S4
Re: Battery...Again! [Re: DavidR] #668688
24/10/20 07:22 AM
24/10/20 07:22 AM
Preston, Lancashire
Saxonian Online content
Saxonian  Online Content
Preston, Lancashire
Oh don't say that .... I just ordered one last night.......... frown
Ian S
2019 Sports Green Morgan Plus 4
2019 Gunmetal Mercedes 220 CLA
Moderated by  Aeroman, Simon
