12 registered members (Colin_Mackay, PaulyG, Mogsr4fun, RB1, truckin-on, Barrythebrave, DCH, Lance, JohnHarris, Mogdavid, Ricardo, Katanazz), 165 guests, and 19 spiders.
John V6 348
TBM 218
+8Rich 207
Pulling bearings from hubs
by NelsonG. 25/11/20 04:04 AM
Test Track in the sky
by Gambalunga. 24/11/20 09:03 PM
Kit car fun
by +8Rich. 24/11/20 06:56 PM
Where have the ~2500 M3Ws ended up?
by truckin-on. 24/11/20 06:06 PM
Christmas Present for the boss
by IMHO. 24/11/20 05:01 PM
M3W & factory feature: The Motorbike Show
by TheCustomer. 24/11/20 11:05 AM
Is this a 4 to 3 wheeler conversion?
Sunday Trip Out
New member
Marty's New Stable Mate
Arrival day August 2020
E.Gumiero, Grump, Fjmorgan, KJD, Mike Woodroffe
7255 Registered Users
Topics39,917
Posts661,793
Members7,255
Most Online1,033
Dec 28th, 2019
Colsmog, Indian Bob
OBD pinouts, wiring etc #668894
25/10/20 10:33 AM
25/10/20 10:33 AM
Grange over Sands, Cumbria, UK...
Cumbriankeith Offline OP
On my new-to-me 2017 Plus 4 the speedo is way over to the left, away from an easy glance to check one's speed.
So like others I've read about on TM, I thought I would fit a small discreet digital readout on the top of the steering column.
I acquired one with a nice easy-to-read display that simply plugs into the OBD port - and it worked perfectly in my tin-top (2014 Golf GTD). However, plugged into the Morgan, all the functions work except for the speed!
So am I right in assuming that the OBD on the GDI engine setup is not Euro OBD2? The instructions with the display showed a few different wiring protocols that involved changing/removing some of the pins - which I tried, but none of those options worked any better.
I have acquired another, solderable OBD plug - so I could rewire the lead to suit the Mog, if I only knew how (or even whether it's possible!) - ie which pinouts provide the speed sensing and so on.
Any OBD wiring/pinout experts out there, please?
Many thanks if you can help!
Keith
2017 Plus 4, lapis blue
Re: OBD pinouts, wiring etc [Re: Cumbriankeith] #668913
25/10/20 12:01 PM
25/10/20 12:01 PM
East Harling, Norfolk UK
Richard Wood Offline
Some useful stuff here from Wicki. As you can see there is plenty of manufacturers discretion on the pinout standards. Buying a Ford friendly OBDII Bluetooth adaptor seems to help therefore and setting up the display app to match of course.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: OBD pinouts, wiring etc [Re: Cumbriankeith] #668919
25/10/20 12:27 PM
25/10/20 12:27 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
I bough a GPS speedo on flea bay. It connects to the USB port on the radio so comes on with the ignition. About £16.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: OBD pinouts, wiring etc [Re: Richard Wood] #668922
25/10/20 12:35 PM
25/10/20 12:35 PM
Thanks Richard. I'll look into that. Trying to keep it to a hard wired option rather than Bluetooth.
Keith
Re: OBD pinouts, wiring etc [Re: Cumbriankeith] #668923
25/10/20 12:37 PM
25/10/20 12:37 PM
Thatcham
Tresco Offline
Tresco  Offline
Thatcham
I have a unit to plug in to the port with an app on the phone but that doesn’t show the speed either.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Re: OBD pinouts, wiring etc [Re: John V6] #668924
25/10/20 12:37 PM
25/10/20 12:37 PM
Thanks John. I actually tried one of those as well - the numeral font wasn't anywhere near as clear and readable as the OBD one.
Keith
Re: OBD pinouts, wiring etc [Re: Cumbriankeith] #668926
25/10/20 12:45 PM
25/10/20 12:45 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
If you use your phone there is also an app called GPS speedo.
I found on both Roadsters that one OBD rader I bought didn't work on fords. I have a cheap blue tooth dongle that works well with the Torque app
Re: OBD pinouts, wiring etc [Re: Cumbriankeith] #668928
25/10/20 12:49 PM
25/10/20 12:49 PM
Sumerset
Rog Offline
Rog  Offline
Sumerset
Hi Keith
Not familiar with the GDI but would hazard a guess that the non-Ford MBE ECU doesn’t control the speedo over any of the OBD2 CAN protocols and perhaps the speedo grabs its pulses directly from the sensor on the front wheel hub?
Awaiting to be shot down..... smile
Roger
Re: OBD pinouts, wiring etc [Re: John V6] #668949
25/10/20 02:51 PM
25/10/20 02:51 PM
Bergen, Norway
Robbie Mathisen Offline
Bergen, Norway
John, what is the brand of your functioning OBD reader? I have tried the ELM 327 on my Roadster S1, but no luck. Seems to connect in some way, but no readings. What is your solution?
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Re: OBD pinouts, wiring etc [Re: Cumbriankeith] #668956
25/10/20 03:19 PM
25/10/20 03:19 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Robbie it was cheap one of ebay.
Sadly I can't search purchase history far back enough to find it.
Here is a
[Linked Image sorry about the glare from the polished bonnet.</div>
<br>
</div>
<div class=
Moderated by  Aeroman, Simon
