2 registered members (Dan_Lockwood, OZ 4/4), 204 guests, and 20 spiders.
+8Rich 325
John V6 286
Peter J 147
Alistair 147
classictravellinglug
gage.com
by +8Rich. 19/01/21 11:15 PM
Mini build...
by Grumpy2. 19/01/21 09:04 PM
Gas Smell
by KenShapiro. 19/01/21 06:58 PM
Ball Joint removal tool
by Bluesman. 19/01/21 05:55 PM
MORGAN WEST Garage collection tour
by Jacques. 19/01/21 04:20 PM
Wanted - First few Mog Mags
by NickCW. 19/01/21 01:46 PM
exploded compressor vid.
by Luddite. 18/01/21 07:59 PM
TOK 258 drawings
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
Boddam and Ravenscraig
First post
dodol, John Welch, CityGarage, Uzi, 1thebeano
7333 Registered Users
Topics40,298
Posts671,228
Members7,333
Most Online1,033
Dec 28th, 2019
Katanazz, Rho8
Plastic steering column shroud #668954
25/10/20 03:18 PM
25/10/20 03:18 PM
Warren NJ USA
SAE Offline OP
SAE  Offline OP
Warren NJ USA
I tried to remove steering column plastic shroud this morning on my 2000 Morgan plus 8 to cover in leather.I removed the 3 screws from underneath the shroud and separated the 2 halves but the bottom part I am having trouble get over the lift lever that raises and lowers the steering wheel as lever is bigger then the slot opening on the shroud.Any help would be appreciated also going to replace the airbag steering wheel with the new mot lita wheel I just got and boss after I deactivate airbag.
2000 plus 8 Connaught green
1966 corvette
1928 Ford hot rod
Re: Plastic steering column shroud [Re: SAE] #669020
25/10/20 07:23 PM
25/10/20 07:23 PM
Bergen, Norway
Robbie Mathisen Offline
Bergen, Norway
Are you shure it is too big? I remember I had just the same problem and was on the verge of giving up. Then, all of a sudden the lever went through the hole, and off it came. So it boiled down down to fiddling about long enough and finding the exact angle. If the lever went in, it should come out. My car is from 2004, so I guess the design of the shroud is equal or at last similar. As for the airbag, sorry can't help. My reason for taiking the shroud off was to change the indicator/light stalk. While off, I sprayed the quite ugly plastic shroud dark brown, to blend in with the wooden dash and tan leather. Turned out rather nice. Of course to cover in leather is more elegant, but my solution wasn't bad either, cheap and simple.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Re: Plastic steering column shroud [Re: SAE] #669060
26/10/20 12:33 AM
26/10/20 12:33 AM
Llanelli
sospan Offline
sospan  Offline
Llanelli
I have a 2002 Plus8. You need to jiggle the cover (ooo er matron) to get the angle right to get over the height adjuster. Removing the dash gives lots of extra room. 3 screws. I have a removable steering wheel so that creates extra room.
Red Plus8
Re: Plastic steering column shroud [Re: sospan] #669451
28/10/20 12:20 AM
28/10/20 12:20 AM
Warren NJ USA
SAE Offline OP
SAE  Offline OP
Warren NJ USA
Wiggled it around and it came off and now have a moto lita steering wheel much better.Thanks for the help
1966 corvette
1928 Ford hot rod
