15 registered members (Richard Wood, James B W, M3W55, Mogdavid, pandy, HJP, MOG 615, Rog G, JohnMat, TBM, MJF, Neilda, PeterG, Dean-Royal, nick w), 177 guests, and 18 spiders.
John V6 348
TBM 218
+8Rich 207
Pulling bearings from hubs
by NelsonG. 25/11/20 04:04 AM
Test Track in the sky
by Gambalunga. 24/11/20 09:03 PM
Kit car fun
by +8Rich. 24/11/20 06:56 PM
Where have the ~2500 M3Ws ended up?
by truckin-on. 24/11/20 06:06 PM
Christmas Present for the boss
by IMHO. 24/11/20 05:01 PM
M3W & factory feature: The Motorbike Show
by TheCustomer. 24/11/20 11:05 AM
Is this a 4 to 3 wheeler conversion?
Sunday Trip Out
New member
Marty's New Stable Mate
Arrival day August 2020
E.Gumiero, Grump, Fjmorgan, KJD, Mike Woodroffe
7255 Registered Users
Topics39,917
Posts661,797
Members7,255
Most Online1,033
Dec 28th, 2019
Colsmog, Indian Bob
Front suspension lubrication questions #669023
25/10/20 07:46 PM
25/10/20 07:46 PM
Norfolk
thelastgizmo Offline OP
Norfolk
I'm thinking of removing the 1 shot lubrication system on my 4/4. Can anyone tell me the blanking plug size to use to block off the outlets of the valve and the top of the suspension struts.
Also what is the recommended grease to use on the grease points at the front (and elsewhere)? When I picked up the car from Williams they look to have used a red looking grease. Not seen that before!
Re: Front suspension lubrication questions [Re: thelastgizmo] #669024
25/10/20 07:50 PM
25/10/20 07:50 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
Grease is red n tacky,
1/8 BSP for the fittings.
1972 4/4 4 seater
Too many ratty motorbikes
Re: Front suspension lubrication questions [Re: thelastgizmo] #669025
25/10/20 07:52 PM
25/10/20 07:52 PM
Arwyn Williams Offline
Fittings should be 1/8 BSP(P)
I use 'bush and pin' grease, much cheaper than Red and Tacky
Arwyn
Re: Front suspension lubrication questions [Re: thelastgizmo] #669026
25/10/20 07:54 PM
25/10/20 07:54 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
Here's the thread from when I removed.
Oiler Removal
1972 4/4 4 seater
Re: Front suspension lubrication questions [Re: thelastgizmo] #669027
25/10/20 08:04 PM
25/10/20 08:04 PM
Norfolk
Norfolk
Thanks for the prompt replies guys. I'll get some blanking plugs. Are any sealing washers needed? Tapered tips or anything? I've seen plenty of parallel thread plugs. As you can see I'm not into hydraulics!
Where did you get your pipe from TBM? Ebay?
Re: Front suspension lubrication questions [Re: thelastgizmo] #669032
25/10/20 08:25 PM
25/10/20 08:25 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
I put grease nipples in the tip of the kingpins, not to grease, but just to keep the crud out.
IIRC I used flat blank plugs, but put small ball bearings in first, No washers.
The pipe was from Ebay - I'll try and find some links.
1972 4/4 4 seater
Re: Front suspension lubrication questions [Re: thelastgizmo] #669035
25/10/20 08:29 PM
25/10/20 08:29 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
This is the pipe Pipe
1972 4/4 4 seater
Re: Front suspension lubrication questions [Re: thelastgizmo] #669042
25/10/20 08:58 PM
25/10/20 08:58 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
Williams used to use and supply Millers Deltaplex 2EP which is a red lithium based grease and is also good for prop shaft and wheel splined hubs. Other alternatives are of course Red n Tacky (which is also EP rated), or Miller Delta 2EP which is similar but brown in colour. The important identifier is the “EP” which rates the product for extreme pressure usage.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Front suspension lubrication questions [Re: thelastgizmo] #669045
25/10/20 09:18 PM
25/10/20 09:18 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
I once had to replace a grease nipple a day before a trip to Italy. I have a box full of different sizes if you want to come to Felixstowe.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: Front suspension lubrication questions [Re: thelastgizmo] #669070
26/10/20 06:58 AM
26/10/20 06:58 AM
Bergen, Norway
Robbie Mathisen Offline
Bergen, Norway
I have no personal experience with Red 'n Tacky, but I am curious about why it is so frequently mentioned as a superior product.
However, I use the charcoal coloured molybden-based grease. Cheap, you get it anywhere, any brand will do. It is supposed to be well suited to slower, gliding movements which is what you find in the sliding pillar compared to the higher speeds in for instance a wheel bearing. It also has less tendency to get washed away when driving in rain. My KPs and (Devol) bushings are ok after 41k km, so it cannot be totally wrong. Can also be used on the propshaft (two grease points in front, one in the rear, don't overdo it...) and most likely at the two ends of the axle, if it is a Salisbury. The BTR axle has none. Lots of info at GoMog.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Moderated by  Aeroman, Simon
