16 registered members (Roady, Graham, G4FUJ, yobtaf, Paulxj, Malcolm T, B3MOG, aerotaff, Ian Wegg, Rog G, KennyW, JohnHarris, Alistair, Spanner Juggler, M500, +8Rich, Eurosystem0),
163
guests, and 22
spiders. |
Topics40,290
Posts671,097
Members7,327
Most Online1,033 Dec 28th, 2019
Plastic steering column shroud
#668954
25/10/20 03:18 PM
25/10/20 03:18 PM
Posts: 26 Warren NJ USA
SAE
Warren NJ USA
I tried to remove steering column plastic shroud this morning on my 2000 Morgan plus 8 to cover in leather.I removed the 3 screws from underneath the shroud and separated the 2 halves but the bottom part I am having trouble get over the lift lever that raises and lowers the steering wheel as lever is bigger then the slot opening on the shroud.Any help would be appreciated also going to replace the airbag steering wheel with the new mot lita wheel I just got and boss after I deactivate airbag.
2000 plus 8 Connaught green 1966 corvette 1928 Ford hot rod
Re: Plastic steering column shroud
[Re: SAE]
#669020
25/10/20 07:23 PM
25/10/20 07:23 PM
Posts: 297 Bergen, Norway
Robbie Mathisen
Bergen, Norway
Are you shure it is too big? I remember I had just the same problem and was on the verge of giving up. Then, all of a sudden the lever went through the hole, and off it came. So it boiled down down to fiddling about long enough and finding the exact angle. If the lever went in, it should come out. My car is from 2004, so I guess the design of the shroud is equal or at last similar. As for the airbag, sorry can't help. My reason for taiking the shroud off was to change the indicator/light stalk. While off, I sprayed the quite ugly plastic shroud dark brown, to blend in with the wooden dash and tan leather. Turned out rather nice. Of course to cover in leather is more elegant, but my solution wasn't bad either, cheap and simple.
Robbie the Norseman 2004 V6 Roadster Sherwood green
[Re: SAE]
#669060
26/10/20 12:33 AM
26/10/20 12:33 AM
Posts: 7,574 Llanelli
sospan
Llanelli
I have a 2002 Plus8. You need to jiggle the cover (ooo er matron) to get the angle right to get over the height adjuster. Removing the dash gives lots of extra room. 3 screws. I have a removable steering wheel so that creates extra room.
Red Plus8
[Re: sospan]
#669451
28/10/20 12:20 AM
28/10/20 12:20 AM
SAE
Warren NJ USA
Wiggled it around and it came off and now have a moto lita steering wheel much better.Thanks for the help
