3 registered members (BertL, JohnMat, kankeL),
135
guests, and 22
spiders. |
Rad Work
by Treesurveyor. 25/01/21 06:05 PM
Topics40,347
Posts672,419
Members7,346
Most Online1,033 Dec 28th, 2019
Re: Technical models to build ? anyone.
[Re: lowebird]
#667917
19/10/20 05:02 PM
19/10/20 05:02 PM
Posts: 25,076 Cheltenham, Glos. UK
I'm just about to order a 4 cylinder, twin cam engine to build during the winter months. It is a full metal bolt and screw kit and will work via a small electric motor. It costs around £450 delivered from:- www.scparts.co.uk 01293 847200. Have a look and see what you think. For a few hundred more you could have a full size Ford engine
Graham (G4FUJ) D8921 L44FOR '93 4/4 Giallo Fly 2 seat  '90 LR 90 SW '06 Saab 9-3 Convertible
[Re: Graham, G4FUJ]
#667920
19/10/20 05:21 PM
19/10/20 05:21 PM
Posts: 2,746 Northants, UK
TBM
Northants, UK
I'm just about to order a 4 cylinder, twin cam engine to build during the winter months. It is a full metal bolt and screw kit and will work via a small electric motor. It costs around £450 delivered from:- www.scparts.co.uk 01293 847200. Have a look and see what you think. For a few hundred more you could have a full size Ford engine   For £450 I'd be after 12 mths MOT
1972 4/4 4 seater - 3G Morganeer Too many ratty motorbikes
[Re: TBM]
#667921
19/10/20 05:28 PM
19/10/20 05:28 PM
Posts: 26,299 Devonshire
Devonshire
I'm just about to order a 4 cylinder, twin cam engine to build during the winter months. It is a full metal bolt and screw kit and will work via a small electric motor. It costs around £450 delivered from:- www.scparts.co.uk 01293 847200. Have a look and see what you think. For a few hundred more you could have a full size Ford engine   For £450 I'd be after 12 mths MOT  My first car a Singer Chamois (Imp with badges rusted like a bugger) cost £350 with new MOT...
Regards Richard
1999 Indigo Blue +8 2009 4/4 Sport Green prev 1994 Connaught Green +8 prev
[Re: +8Rich]
#667927
19/10/20 05:52 PM
19/10/20 05:52 PM
TBM
Northants, UK
I'm just about to order a 4 cylinder, twin cam engine to build during the winter months. It is a full metal bolt and screw kit and will work via a small electric motor. It costs around £450 delivered from:- www.scparts.co.uk 01293 847200. Have a look and see what you think. For a few hundred more you could have a full size Ford engine   For £450 I'd be after 12 mths MOT  My first car a Singer Chamois (Imp with badges rusted like a bugger) cost £350 with new MOT... Bought my current Corsa a couple of years ago - it wasn't much more and with full ticket
[Re: Bonesie]
#667932
19/10/20 06:09 PM
19/10/20 06:09 PM
Posts: 454 Germany, Rhein-Main Area
xc68anc
Since a few years I‘m in worries with my VESPA VLB1M engine....
I‘ve got a lot of experience, but I struggle... may be that‘s interesting stuff.
Build up a real engine and get money.
On the other way HONDA flat onecylinders (MONKEYs, DAXs and clones) are cheap. Do and undo for small money.
Something like this: https://www.monkeypower.de/epages/61916048.sf/de_DE/?ObjectPath=/Shops/61916048/Categories/%22Zubehör/Ersatzteile%22/%22Motoren_Vergaser%20Luftfilter%20Zylinder%20Dichtungsätze%22/Komplettmotoren
René
2018 plus4
[Re: Graham, G4FUJ]
#668024
20/10/20 09:55 AM
20/10/20 09:55 AM
Posts: 4,571 norfolk, UK
lowebird
norfolk, UK
I'm just about to order a 4 cylinder, twin cam engine to build during the winter months. It is a full metal bolt and screw kit and will work via a small electric motor. It costs around £450 delivered from:- www.scparts.co.uk 01293 847200. Have a look and see what you think. For a few hundred more you could have a full size Ford engine  Yes, but SWMBO wouldn't let me play with it in the dining room and winter is coming.
[Re: Grumpy2]
#668031
20/10/20 10:33 AM
20/10/20 10:33 AM
Posts: 13,832 Mandello del Lario
Gambalunga
Mandello del Lario
I have purchased several things from China, usually from Aliexpress or Alibaba, but also from others including Amazon. Sometimes delivery times are very slow because ordinary mail is often used, which from China costs next to nothing. The only problems I have ever had were: 1. a replacement drone camera that was faulty, a new one was sent and I posted back the original which was repaired and returned to me so I finished up with 2 cameras and the only additional cost was the return postage on one. 2. a multimeter that was obviously new old stock and had corroded batteries in it and slightly damaged contacts. In the second case I got a full refund from Aliexpress after sending photos and they did not want the multimeter returned. In the end I cleaned the contacts and replaced the batteries. It now works fine. All in all I have no fear of dealing with Chinese suppliers though I am very careful to avoid sites that could be fraudulent. I am very cautious about giving card details and if it is not a known site I create a limited virtual credit card via my home banking. I limit it to one transaction at a figure slightly higher than the quoted price because the actual charge is often not in the currency quoted so you need to allow for exchange differences.
[Re: Gambalunga]
#669196
26/10/20 05:45 PM
26/10/20 05:45 PM
Posts: 568 Chester, UK
Grumpy2
Chester, UK
I have purchased several things from China, usually from Aliexpress or Alibaba, but also from others including Amazon. Sometimes delivery times are very slow because ordinary mail is often used, which from China costs next to nothing. The only problems I have ever had were: 1. a replacement drone camera that was faulty, a new one was sent and I posted back the original which was repaired and returned to me so I finished up with 2 cameras and the only additional cost was the return postage on one. 2. a multimeter that was obviously new old stock and had corroded batteries in it and slightly damaged contacts. In the second case I got a full refund from Aliexpress after sending photos and they did not want the multimeter returned. In the end I cleaned the contacts and replaced the batteries. It now works fine. All in all I have no fear of dealing with Chinese suppliers though I am very careful to avoid sites that could be fraudulent. I am very cautious about giving card details and if it is not a known site I create a limited virtual credit card via my home banking. I limit it to one transaction at a figure slightly higher than the quoted price because the actual charge is often not in the currency quoted so you need to allow for exchange differences. Well something arrived today, a month later than originally promised and an absolute pile of rubbish. Just a small pack go fake lego! Paypal are on the case - not expecting much success there either but at the moment I've got quite a bit of free time on my hands!!!!
94 plus 8 in Westminster Green - I think!
