13 registered members (Jays ex Nero, sprinty, DCH, Jacques, Image, RJW, IcePack, mal, M3W55, Laurens, BuyBritish, TBM, RedThree), 230 guests, and 19 spiders.
John V6 328
TBM 212
+8Rich 203
Watch point reversing light corrosion
by John V6. 29/11/20 04:30 PM
Aerosol paint for Morgans
by Richard Wood. 29/11/20 01:25 PM
How many cheeses in your fridge ?
by +8Rich. 29/11/20 12:33 PM
Tyre age and renewal
by Neil49. 28/11/20 09:54 PM
Oil pressure
by M2AERO. 28/11/20 06:46 PM
1997 Plus 8 tickover
by Phil+8. 28/11/20 04:22 PM
Iridium spark plugs
by Jads. 28/11/20 03:42 PM
More November Sun...
November Sun
Is this a 4 to 3 wheeler conversion?
Sunday Trip Out
New member
E.Gumiero, Grump, Fjmorgan, KJD, Mike Woodroffe
7255 Registered Users
Topics39,951
Posts662,516
Members7,255
Most Online1,033
Dec 28th, 2019
Nicko
Tilting Scissor Lift #669331
27/10/20 02:11 PM
27/10/20 02:11 PM
Staffordshire
IvorMog Offline OP
IvorMog  Offline OP
Staffordshire
A while back there was a thread discussing types of lifts for garage use and whilst a 2 post lift or mid rise scissor lift might be more convenient in many ways I felt the cost and space they take up in a domestic garage meant that I should keep researching before I made a decision.
In the same thread, Rainbowj on here, said he was struggling to get along with his tilting scissor lift due to the type of rippled concrete floor in his garage so I PM'd him and we struck a deal as I thought it might be a good compromise and when not in use it can be hung on the wall.
When I went down to visit John, I could see what he meant about the rippled concrete floor and my floor, whilst not perfect, is much flatter. Many thanks to John for the help and explanation of how it all worked. And still having all the attachments and original manual.
I decided to give it a go and whilst I had played with it a couple of time prior to today, I had not fully put it to the test.
As I'm going to be stripping out the fuel tank, I wanted maximum height and stability and I have to say it worked like a dream.
I started the lift by hand to make sure everything was lined up then used my Screwfix Titan 1500 watt SDS drill (about £60 IIRC) for the remainder of the lift.
Worked like a dream and up in no time lifting in stages to keep the car at a reasonable angle as it went up.
When I had reached the height I wanted (about 23") I put my heavy duty axle stands in place and lowered the scissor lift slightly to share the weight and take some of the pressure off the scissor lift screw.
I'm over the moon with the access I have front and back and if I did need to get to the middle of the car, I could simply lower the lift so all the weight was on the axle stands and wheel the lift out from under the car.
As this was my first proper attempt and I had to develop the methodology it took just over an hour but next time I'm sure I can do it in well under 30 minutes.
It won't be right for everyone but it works for me.
BTW, I did loosen off all the wheel nuts before I did the lift so they will only need a tap when I do come to remove them.
Bob
1999 4/4 2 litre Zetec
Re: Tilting Scissor Lift [Re: IvorMog] #669335
27/10/20 02:51 PM
27/10/20 02:51 PM
Costock, South Nottinghamshire...
Paul F Online happy
Paul F  Online Happy
Thanks for posting - that looks the business. Lots of temptation there ......
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: Tilting Scissor Lift [Re: IvorMog] #669422
27/10/20 08:24 PM
27/10/20 08:24 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Having spent this morning with Cain and seeing how easy work is with a lift. Then spending this afternoon fitting a buzzer to the Roadster so I can tell the indicators are on the difference was clear & my back is telling that.
I can see why you are pleased
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Moderated by  Aeroman, Simon
