8 registered members (+8Rich, JoeSpeetjens, Rovert, Barry M, JohnHarris, MarioCP, Katanazz, Treesurveyor),
166
guests, and 24
spiders. |
Fuses
by Ray. 16/01/21 03:47 PM
Topics40,273
Posts670,663
Members7,327
Most Online1,033 Dec 28th, 2019
Re: Led light bulbs
[Re: rockabilly john]
#669337
27/10/20 02:56 PM
27/10/20 02:56 PM
Posts: 2,870 Port Orchard, WA.
LightSpeed
Port Orchard, WA.
Change the whole unit. I tried the bulb replacement led and it does not even come close to LED Headlamps.
Stephen 2019 M3W, AR Stage 2
Re: Led light bulbs
#669352
27/10/20 04:25 PM
27/10/20 04:25 PM
Posts: 265 CT, USA
06032
CT, USA
Ditto, change the whole unit. It's a great upgrade (brightness, lower draw).
'17 M3W: '08 Ural Gear-Up
Re: Led light bulbs
#669355
27/10/20 04:30 PM
27/10/20 04:30 PM
Posts: 116 Las Vegas
JohnMat
Las Vegas
You can ignore the CAN bus warnings. Morgan does not have a CAN bus, so the problems that arise in cars that have CAN bus system that sense the bulb current don’t arise.
Agree with others, replacing the whole unit is simplest. The expensive JW Speaker headlights recommended multiple time in prior threads work great. I fitted them recently.
2020 M3W
Re: Led light bulbs
#669358
27/10/20 04:48 PM
27/10/20 04:48 PM
Posts: 1,160 Oxon
PaulV
Oxon
Won't be relevant to Americans, but to Brits who may want to drive in the Eurozone, how do the LED full headlamp units adapt to RHD? Does one use a sticky bit of plastic tape as per the Halogen headlamps? I would have expected some LED lamps to be switchable but not seen that offered...
Re: Led light bulbs
#669359
27/10/20 04:49 PM
27/10/20 04:49 PM
Posts: 3,399 East Harling, Norfolk UK
At some point i want to change/swap out some lamps on after market lights. My question is what type of lamps should we use? The fitting is Ba15s. I`ve had look on the .net and and Canbus comes up quite a lot.
BA15s is a common single filament bulb fitting and not used on an M3W as they have OE LED's other than headlamp fittings Car Builder Solutions have replacements for the OE LED units used as stop/tail, fog and indicators. Would recommend full dedicated LED headlamp replacement though with DRL function. As suggested no Canbus issues with M3W and most of the trads.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1960 Velocette Venom
Re: Led light bulbs
#669363
27/10/20 05:03 PM
27/10/20 05:03 PM
Posts: 295 Bergen, Norway
Robbie Mathisen
Bergen, Norway
But it is not the headlamps you want to change, is it? If the socket is Ba15s, it sounds like DRL, rear DRL, indicators, stopping light or the like. If you have a car with canbus system and ordinary incandescent bulbs, the system migth give you a bulb failure warning when you put in a LED, unless the LED is built to be canbus compatible. If the car does not have such a system, just put in a LED with the same socket. I have no idea about the M3W. If you put a LED in the indicator lamp, it might go into "hyperflash" - a very quick cadence unless the LED is specified as non-hyperflash. A few are, most are not, but you can put i an extra ballast/resistor. Remember, a red LED behind red lens, a white LED and red lens will turn out pink. Concerning headlamps, there are LED versions of most bulbs, H7, H4 and others. They are a direct replacement, but possibly not road legal in the UK - you'll find out. Watch the canbus issue, though. I do not have personal experience of M3W headlamps, but they will most likely be a lot better than OE. It might be even better though, changing the whole unit. So the question is how bright is bright enough for yor kind of driving, how much are you willing to spend and how invasive do you want to be.
Robbie the Norseman 2004 V6 Roadster Sherwood green
Re: Led light bulbs
#669381
27/10/20 05:56 PM
27/10/20 05:56 PM
JohnMat
Las Vegas
Apart from the headlights, all the light bulbs in the three-wheeler are LED from the factory (in mine at least), so I assume this is in fact a headlight question.
Rockabilly John - are you asking about the marker/side-light bulbs in the European headlamps? (The US ones don't have these)
2020 M3W
Re: Led light bulbs
[Re: JohnMat]
#669385
27/10/20 06:15 PM
27/10/20 06:15 PM
Robbie Mathisen
Bergen, Norway
Right, and I now understand that all bulbs exept headlamps are LED. But the headlamps cannot be BA15s? I am confused, and I seem not to be the only one. Perhaps the thread starter could specify the problem a little more?
