11 registered members (PhilRoyle, Leroy, M3W55, GBpluseight, DavidR, HeadlessBlue, GRB, MJF, SFG, DaveW, Jon G4LJW), 179 guests, and 20 spiders.
+8Rich 322
John V6 289
Peter J 149
TBM 147
exploded compressor vid.
by Luddite. 18/01/21 07:59 PM
2019 Plus 4 Freon?
by Morgan Atlanta. 18/01/21 04:46 PM
Audi fresh out of chips
by +8Rich. 18/01/21 03:38 PM
Starting - Battery?
by Amrum. 18/01/21 12:57 PM
third brake light wiring?
by Hogzilla. 18/01/21 02:12 AM
Mystery Wire
by OhioM3W. 17/01/21 11:36 PM
Surplex adjustable rear shocks
by Mark H. 17/01/21 10:50 PM
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
Boddam and Ravenscraig
First post
Steam loco build
PH1954, HJF, Valespecial, Berlin, Spizz Oil
7327 Registered Users
Topics40,290
Posts671,112
Members7,327
Most Online1,033
Dec 28th, 2019
BertR, KennethM
plus 8 oil pressure relief valve #670267
31/10/20 08:57 PM
31/10/20 08:57 PM
Chester, UK
Grumpy2 Offline OP
Grumpy2  Offline OP
Chester, UK
I don't have a problem but something I've wondered about.
My oil pressure is fine, approx 15psi on idle and 30-40 psi when running. Drops a fraction when things are very warm in summer on a hot day.
I've had lots of Rover V8 engines but never one with the high pressure relief valve spring fitted.
Has anyone experience of the high pressure relief valve and what was the outcome.
Just looking for things to do during 'lockdown lite/lockdown two' after I've fitted the indicator repeater buzzer.
cheers
94 plus 8 in Westminster Green - I think!
Re: plus 8 oil pressure relief valve [Re: Grumpy2] #670339
01/11/20 11:23 AM
01/11/20 11:23 AM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Don't all pressure lubricated IC engines require a pressure release valve even if incorporated within the pump body? This to alleviate high pressure from cold oil, strain on pump and seals etc.
As an aside read an article the other day suggesting a rule of thumb of 10 psi oil pressure for every 1000 rpm of crank rotation up to max 60 - 70 psi.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: plus 8 oil pressure relief valve [Re: Grumpy2] #670384
01/11/20 05:28 PM
01/11/20 05:28 PM
Chester, UK
Grumpy2 Offline OP
Grumpy2  Offline OP
Chester, UK
Yes Richard, but the V8 runs low oil pressure but at a high flow rate. Theres a fairly common mod that increases the pressure a tad by fitting a higher rated relief valve spring.
Although its a well know mod I've never come across anyone with direct experience to ask if its worth doing
Standard V8 oil pressure is approx the same as mine so I'm reluctant to go fiddling unless theres some benefit that I dont know of
cheers
Re: plus 8 oil pressure relief valve [Re: Grumpy2] #670395
01/11/20 06:29 PM
01/11/20 06:29 PM
RichardV6 Offline
RichardV6  Offline
Sorry misunderstood your first post. I do have a dry sump vintage diesel with adjustable external PRV incorporating non-return valve to offset wet sumping when not running. The adjustment which pre-loads main spring has almost no effect when oil is warm though.
ETA: found these pressures as good for a rebuilt pre serp. engine after which (around '94) oil pump drive was taken from crank rather than distributor shaft.
1000 rpm = 10psi
2000 rpm = 28psi
3000 rpm = 32 psi
4000 rpm = 38 psi
5000 rpm = 40 psi
Sounds like your engine is not far from rebuilt findings and as you suggest the high flow rate offsets the need to strictly adhere to the rule of thumb I mentioned.
