5 registered members (JohnHarris, Rovert, +8Rich, JoeSpeetjens, Barry M), 160 guests, and 19 spiders.
+8Rich 324
John V6 288
Peter J 155
TBM 155
New member from Nice
by Olivier. 16/01/21 06:35 PM
Solar power.
by Sportster. 16/01/21 04:47 PM
Replacement M3W.
by Sportster. 16/01/21 03:58 PM
Fuses
by Ray. 16/01/21 03:47 PM
This years meanderings
by aerotaff. 16/01/21 11:09 AM
Guess the movie.
by Sportster. 16/01/21 07:54 AM
New member and potential owner
by HJF. 15/01/21 08:00 PM
First post
Steam loco build
GBpluseight avatar
Adding a number to the grill
Lockdown slide show
PH1954, HJF, Valespecial, Berlin, Spizz Oil
7327 Registered Users
Topics40,273
Posts670,663
Members7,327
Most Online1,033
Dec 28th, 2019
Massimo
Page 3 of 4 1 2 3 4
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #653567
31/07/20 04:24 PM
31/07/20 04:24 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
Try disconnecting the battery for 10 -15 mins. This will clear the ECU adaptive modifications to it's base map. A long shot but might work.
Red Leader drive
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #653611
01/08/20 02:05 AM
01/08/20 02:05 AM
AlexKnoll Offline OP
BINGO we have a winner!
https://imgur.com/a/SmCOKwu
Pulled the throttle body away, I can see the o-ring slipping out.
Thanks for the suggestions everyone and good call by those who figured it out.
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #653612
01/08/20 03:01 AM
01/08/20 03:01 AM
Las Vegas
JohnMat Offline
JohnMat  Offline
Las Vegas
Glad you found the issue. Hope it’s easy to fix.
2020 M3W
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #653615
01/08/20 04:25 AM
01/08/20 04:25 AM
Rio Del Mar, CA
kankeL Offline
kankeL  Offline
Rio Del Mar, CA
Alex, can you point to the problematic o-ring in your picture?
2016 M3W, Army Green Matte/Tan Leather, 15k miles
Re: S&S Stealth Air Filter Troubles [Re: kankeL] #653677
01/08/20 01:56 PM
01/08/20 01:56 PM
https://imgur.com/a/8Nc7E2s
That's where it's slipping out.
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #653680
01/08/20 02:28 PM
01/08/20 02:28 PM
Rio Del Mar, CA
kankeL Offline
kankeL  Offline
Rio Del Mar, CA
Got it! In case you need a new gasket: https://rover.ebay.com/rover/0/0/99?loc=https%3A%2F%2Fwww.ebay.com%2Fp%2F657674973%3Fiid%3D323772287724
Were the bolts tight?
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #653714
01/08/20 05:32 PM
01/08/20 05:32 PM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
I can't imagine how the o ring could try to exit like that unless the throttle body mounting screw were quite loose. Did you loosen those for some reason while mounting the new air cleaner?
When I disassembled my intake system to clean (part of the the polished lifter cover install project) my throttle body fit tight to the intake manifold with the o-ring installed in its' annular groove and correctly compressed; i.e. there should be no discernible gap between the throttle body and intake.
Looking at the stains present in your photograph it looks as it you have had a leak here for some time, so perhaps your throttle body was installed incorrectly at some point in the past with the o-ring not correctly clamped in position but still providing a (mostly) functional seal. Then just recently, perhaps due to a misfire on starting, the o-ring was blown out as depicted.
2012 M3W
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #653743
01/08/20 08:21 PM
01/08/20 08:21 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
It looks cocked at an angle and not torqued down evenly.
Stephen
2019 M3W, AR Stage 2
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #670414
01/11/20 08:00 PM
01/11/20 08:00 PM
Las Vegas
JohnMat Offline
JohnMat  Offline
Las Vegas
I just encountered the same issue on my M3W. It has been idling a little fast recently, and on my last drive it was hard to keep running after starting, idling with strange chuffing noises then stalling, although running great once under power.
Thanks to AlexKnoll, I remembered this thread, pulled my S&S Stealth air filter off to take a look, and when I rotated the throttle I could see the bottom of the O-ring had popped loose inside the throttle body. It turned out that the head of the bottom retaining bolt for the throttle body had sheared off, so the only thing holding it on was the top bolt. I guess it was either a defective bolt, or when I mounted the air filter I must have put it under enough stress to shear it off. I'll be careful when I re-mount the filter to make sure it is not stressed. Others with this filter might want to look out for this issue.
Ordered a replacement bolt and spring washer today, and am hoping that this will resolve the problem. I'd have been paying for a tow truck and a mechanic without the accumulated wisdom here. Thank you!
2020 M3W
Re: S&S Stealth Air Filter Troubles [Re: JohnMat] #670641
03/11/20 12:21 PM
03/11/20 12:21 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Where did the sheared off head of bolt go?
Stephen
Page 3 of 4 1 2 3 4
