9 registered members (Doug J, brian battersby, +8Rich, IcePack, UlrichW, Barry M, SDJ, thelastgizmo, Bourbonmog),
162
guests, and 26
spiders. |
Fuses
by Ray. 16/01/21 03:47 PM
Topics40,273
Posts670,660
Members7,327
Most Online1,033 Dec 28th, 2019
Re: Third brake light
[Re: Marmota]
#670512
02/11/20 02:34 PM
02/11/20 02:34 PM
Hogzilla
A third higher lamp will be for sure a nice safety DIY winter project. But Hogzilla: consider that the kind of third lights shown in the pictures above have a "con": if you plan to travel and consequently use a luggage rack, this light will interfere with the rack and/or be hidden behind the luggage. Check out my luggage set: it's not too tall but it would definitely hide any third lamp. ![[Linked Image]](https://www.tm-img.com/images/2020/11/02/Hangar-works-10---Img10.jpg) But if you don't plan to travel ever with your 3-Wheeler, then this may never need a luggage rack and so many bags on it. Also if you travel solo, you can use the co-pilot's side and footwell to put your bags, and don't need again the luggage rack. In our case we're two travelling with the 3-Wheeler, so we really need it. The Australian version will do! Now I need to get that ordered. Thanks!
[Re: Bunny]
#670513
02/11/20 02:36 PM
02/11/20 02:36 PM
Hogzilla
Richard is correct. I ordered those part numbers a while ago and received the following: ![[Linked Image]](https://www.tm-img.com/images/2020/11/02/P1150338.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/11/02/P1150339.jpg) I found the finish on the aluminium upstand to be poor so this will require refinishing & polishing before fitting. ![[Linked Image]](https://www.tm-img.com/images/2020/11/02/P1150340.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/11/02/P1150341.jpg) I haven't got around to fitting it yet, partly because it goes against the grain to cut a 12mm hole in the bodywork.  Also, my car is a 2012 model so will almost certainly not have the necessary electrical connector in the wiring loom. Not a big problem I guess but another reason to put the project on the back burner for now! By the way, in 2018 I paid Uncle Melvyn £38.31 for the lamp (U340032) and £8.67 for the pedestal (T400037). Both prices exclude VAT & delivery. THANK YOU!!!!
[Re: Hogzilla]
#670514
02/11/20 02:39 PM
02/11/20 02:39 PM
Posts: 934 Evergreen, Colorado, USA
britmog
For visibility I use two small LED rear bicycle lights that are attached to the hoops via rubber straps. These are the ones you see flashing on the rear of bicycles, I have them on a slow repeat flash that can be seen for hundreds of yards and are very bright even in daylight, cheap and removable.
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
[Re: kankeL]
#670518
02/11/20 03:11 PM
02/11/20 03:11 PM
Posts: 2,870 Port Orchard, WA.
LightSpeed
Port Orchard, WA.
Mine has the hollow shaft through the lamp and that light can be seen from every angle because the video I posted was taken from the ground. From another drivers position it is clearly visible, no stalk needed. That must have been some Australian requirement that has no bear, especially if you have a rack with luggage. Luggage racks might be great for campers but I find small bags in the passgenger footwell do just fine and a credit cardf or the hotel :-)
Stephen 2019 M3W, AR Stage 2
[Re: LightSpeed]
#670519
02/11/20 03:15 PM
02/11/20 03:15 PM
Posts: 506 Rio Del Mar, CA
kankeL
Rio Del Mar, CA
Mine has the hollow shaft through the lamp and that light can be seen from every angle because the video I posted was taken from the ground. From another drivers position it is clearly visible, no stalk needed. That must have been some Australian requirement that has no bear, especially if you have a rack with luggage. Luggage racks might be great for campers but I find small bags in the passgenger footwell do just fine and a credit cardf or the hotel :-) Where on earth do you put your wife’s hairdryer? 😉
2016 M3W, Army Green Matte/Tan Leather, 15k miles
[Re: Hogzilla]
#670536
02/11/20 04:27 PM
02/11/20 04:27 PM
Posts: 1,397 New River Valley, VA
rcmatt
Mine is like Javiers.... I put enough on the luggage rack all I would do it light up the first thing on the rack
[Re: Hogzilla]
#670543
02/11/20 05:07 PM
02/11/20 05:07 PM
Posts: 116 Las Vegas
JohnMat
Las Vegas
Another option for those with the tall roll-bars with built-in headrests is to add lights on the back of the headrests. I used these Dogeye Puckz and wired them as brake lights, running lights and turn signals. It makes the M3W a lot more visible in traffic, and they are really bright. I wired them to the brake light connector, and then tapped into the turn signals and running lights. ![[Linked Image]](https://www.tm-img.com/images/2020/11/02/221973A5-E12C-463D-9FF9-2B5B9C6C1D2A.jpg)
2020 M3W
