7 registered members (Barry M, JohnHarris, MarioCP, Katanazz, Treesurveyor, +8Rich, Island Mog), 160 guests, and 24 spiders.
+8Rich 324
John V6 288
Peter J 155
TBM 155
New member from Nice
by Olivier. 16/01/21 06:35 PM
Solar power.
by Sportster. 16/01/21 04:47 PM
Replacement M3W.
by Sportster. 16/01/21 03:58 PM
Fuses
by Ray. 16/01/21 03:47 PM
This years meanderings
by aerotaff. 16/01/21 11:09 AM
Guess the movie.
by Sportster. 16/01/21 07:54 AM
New member and potential owner
by HJF. 15/01/21 08:00 PM
First post
Steam loco build
GBpluseight avatar
Adding a number to the grill
Lockdown slide show
PH1954, HJF, Valespecial, Berlin, Spizz Oil
7327 Registered Users
Topics40,273
Posts670,663
Members7,327
Most Online1,033
Dec 28th, 2019
Massimo
Media projector #670516
02/11/20 02:54 PM
02/11/20 02:54 PM
returned OggieMogger
Roady Offline OP
Roady  Offline OP
Hi Folks
I give talks on Morgans down here in the west country (raising money for BHF - selfish you see as I've a dickey ticker) and need some projector advice. I've been searching the web but just get confused as I'm not au fait with what works best. Basically I need something that will give a very good PowerPoint presentation in medium sized rooms and provide a useful way of projecting my holiday pictures at home. Oh, and I don't want to spend more than £500.
Any advice based on personal experience would be very welcome. confused
Roady
Re: Media projector [Re: Roady] #670523
02/11/20 03:44 PM
02/11/20 03:44 PM
Preston, Lancashire
Saxonian Offline
Saxonian  Offline
Preston, Lancashire
Take a look here
https://www.richersounds.com/tv-projectors/projectors/all-projectors.html
Listed in price order ascending
I have an Optoma 108P (also 3D)
There are many other low cost projectors out there - under £50 - some are ok - others not so
Ian S
2019 Sports Green Morgan Plus 4
2019 Gunmetal Mercedes 220 CLA
Re: Media projector [Re: Roady] #670525
02/11/20 03:54 PM
02/11/20 03:54 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
Another vote for Optoma - the one I have is now obsolete but was recommended to me by a local firm that specialise in such things. It was less than £500 and works well. Amazon list something that looks similar to mine (Optoma H184X 3600 Lumens HD Ready Projector - Black) at £350 but I haven't checked the reviews.
Do check the connections match your PC - some machines no longer have a VGA input if you rely on that.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: Media projector [Re: Roady] #670527
02/11/20 04:02 PM
02/11/20 04:02 PM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
what connector for output does your laptop have.
Older
VGA D15, small D shape with three rows pins - https://en.wikipedia.org/wiki/VGA_connector
DVI-?, slightly larger and with several options - https://en.wikipedia.org/wiki/Digital_Visual_Interface
More modern
HDMI like your telly and now most common for some time. https://en.wikipedia.org/wiki/HDMI
If you can share what model of laptop/device you are showing from I can help more.
Projectors.
By priority of benefit IMHO.
Lumens - how bright and so how dark the room needs to be - bigger is better. Older units have a more limited life on the bulb as it burns out but this will be ages for most home users. Modern units use DLP which is better.
Resolution - In general PPT likes a 1920x1080 resolution these days but usually can work on lower if needed so the ideal projector will provide this (FullHD)
There is a bit of a cheat floating around here. They will claim FullHD but when you look in the technical spec it actually runs at a lower res and the electronics fake this out to the laptop to make it think it is actually FullHD.
This is not a massive problem but means the screen might not be so perfect. For £500 you should expect real FullHD.
As an example you will see on this site (eBuyer) the resolution and "native" resolution options down the side https://www.ebuyer.com/store/Visual/cat/Projectors?q=projector&price=20+TO+588
If it is any help I have an older one I used to use in my office which has been retired from daily use. More than happy to do you a small price and shipment, where are you based ? I can get the spec if you like?
Just time to burn a little more petrol before dinner.
Re: Media projector [Re: Roady] #670598
02/11/20 11:36 PM
02/11/20 11:36 PM
Nth. Bucks, England
minikeefy Offline
minikeefy  Offline
Nth. Bucks, England
I recently purchased one of these for similar purpose with my semi retirement role with a GP Surgery so budget was low..
Epson EH TW650 from Currys
I used to use expensive Dell projectors but this is far brighter and easy to set up with decent 'throw' on lens to ensure a good screen projection size. Very impressed.
Mind you I expect you could find second hand ones as everyone in corporate world is switching to large flat screens.
I saw some Epson projectors at £ 70,000!!!!
Keith
Re: Media projector [Re: Roady] #670648
03/11/20 12:53 PM
03/11/20 12:53 PM
Roady Offline OP
Roady  Offline OP
Thanks for the offer Alistair.
My existing laptop is a pretty ancient Dell Latitude D410: it's well over ten years old. It's so old the battery gave up ages ago but it works fine on the mains.
It has VGA and USB ports but no HDMI. I have however, a conversion lead that takes the VGA feed to an HDMI socket which works fine with my smart TV.
The only key feature I know I'd need is tomb stoning.
Thanks in anticipation.
Roady
Re: Media projector [Re: Roady] #670663
03/11/20 02:29 PM
03/11/20 02:29 PM
Renfrewshire
BobtheTrain Offline
BobtheTrain  Offline
Renfrewshire
Do you not have Lara Croft's number?
Best Regards
Lang may yer lum reek
Re: Media projector [Re: Roady] #670664
03/11/20 02:36 PM
03/11/20 02:36 PM
Hampshire
Alistair Offline
Alistair  Offline
Hampshire
I am guessing you mean Keystoning or making the side parallel when aiming from short range?
https://en.wikipedia.org/wiki/Keystone_effect
It has VGA so direct connection is fine with a standard VGA lead. It has probably less than a couple of hundred hours on the bulb.
I will look it out this evening when I get home, once tested we can flip it to DM and sort out details. Where are you based as if it is in the Basingrad/Newbury/Reading area I am able to drop off, if not then it means posting and they are a little delicate.
