2 registered members (JohnMat, kankeL), 138 guests, and 22 spiders.
+8Rich 377
John V6 299
Alistair 166
Peter J 138
Lockdown Petrol
by aerotaff. 26/01/21 10:34 AM
Shameless plug of my wares
by Bonesie. 26/01/21 05:44 AM
Terminal Ride of your life !
by Moggo. 26/01/21 05:14 AM
Bloodhound project
by +8Rich. 25/01/21 09:42 PM
Rip Off Quotes
by Moggo. 25/01/21 09:27 PM
Rad Work
by Treesurveyor. 25/01/21 06:05 PM
Second and Foremost
by BobtheTrain. 25/01/21 05:02 PM
Another High Level brake light
Morgan puzzle made to order
TOK 258 drawings
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
bear65, Mogster +4, JimV6, IainG, Ollie
7346 Registered Users
Topics40,347
Posts672,419
Members7,346
Most Online1,033
Dec 28th, 2019
No Birthdays
Kingpins 1000miles... #671496
07/11/20 07:18 PM
07/11/20 07:18 PM
Germany, Rhein-Main Area
X
xc68anc Offline OP
xc68anc  Offline OP
X
How I start?
Next week my Mog has her second birthday. As I‘m in old MINIs I know: keep it/her lubed.
First mistake: to late, after 10.000 KM I fitted some homemade „BHM“style gaiters.
But all the time I use the greasegun regulary. But as the manual says: every 1000miles. More or less.
Today it was time to do it. 19500KM in my counting „13000“miles. Greasing as usual topnipples until I noticed a light sound of pop out the
grease, than the lower nipples in the same way.
As she was high up in the front I think: let‘s have a look at the wheels. Good idea/ bad result. I feel (not visible) some movement when
I had my hands at the 12/6 point.
Worn kingpins. Is it too much? Where is the tolerance?
And what‘s the choice for a replace? Wolf? Librands? Sifab?
I‘m not lefthanded, so is a thing to DIY?
Thank for comments.
René
2018 plus4
Re: Kingpins 1000miles... [Re: xc68anc] #671505
07/11/20 07:46 PM
07/11/20 07:46 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Rene, some of the play you feel could also be wheel bearing, you should be able to 'feel' a little play, or it is too tight, if you can't see actual movement it sounds like you Mog is ok
Re: Kingpins 1000miles... [Re: xc68anc] #671510
07/11/20 08:00 PM
07/11/20 08:00 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
This seems too low a mileage for king pin wear considering your greasing regime; but not unknown. If it’s a wheel bearing, you should get a similar movement at the 9/3 position. May need someone to hold onto the steering wheel while you check it.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Kingpins 1000miles... [Re: xc68anc] #671512
07/11/20 08:06 PM
07/11/20 08:06 PM
Chester, UK
Grumpy2 Offline
Grumpy2  Offline
Chester, UK
My kingpins were quite badly worn but the wear was masked by the force on the springs and I couldn't detect any movement at all. I'd suggest your wear may well be in the bearings and nipping them up may well solve the problem
94 plus 8 in Westminster Green - I think!
Re: Kingpins 1000miles... [Re: xc68anc] #671515
07/11/20 08:10 PM
07/11/20 08:10 PM
Solihull
Spanner Juggler Offline
Solihull
René
You can isolate the wheel bearing movement by getting someone to sit in the car and press the brake hard whilst you check for play. A little ‘rock’ is actually desirable, just a little in the bearings and also a small amount in the kingpins (ideally 0.002”) is perfect.
BR
Colin
BR Colin
Re: Kingpins 1000miles... [Re: xc68anc] #671516
07/11/20 08:14 PM
07/11/20 08:14 PM
X
xc68anc Offline OP
xc68anc  Offline OP
X
Puh, that all Sounds good. Sun is rising up again.
Thanks! A new try the next days.
René
2018 plus4
Re: Kingpins 1000miles... [Re: xc68anc] #671592
08/11/20 09:35 AM
08/11/20 09:35 AM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
If it really is worn kingpins isn't your car still under the 30 month warranty?
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Kingpins 1000miles... [Re: xc68anc] #671593
08/11/20 09:46 AM
08/11/20 09:46 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Richard I suspect that will not covered as it is "wear & tear" . Worth a go though. 19,500 km seems way low for king pin failure.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Kingpins 1000miles... [Re: xc68anc] #671601
08/11/20 10:21 AM
08/11/20 10:21 AM
RichardV6 Offline
RichardV6  Offline
Apologies for slight thread drift but can anyone give a definitive answer on the latest factory fit kingpin material? I was told it was chrome plated stainless steel which is possible, but wonder if this is correct as its chrome (among others) that are added to steel to make it stainless.
I do understand the "hard chrome" finish commonly offered as replacement is the more desirable though for longevity. This begs another question, what is the base material of such, plain or stainless?
Re: Kingpins 1000miles... [Re: xc68anc] #671612
08/11/20 11:11 AM
08/11/20 11:11 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Richard,
you can hard chrome stainless steel. It is often done for scrapped surface heat exchanges especially with products to be heated or cooled that have a high chloride or abrasive content that would cause pin hole corrosion in stainless.
Cain is now the supplier of king pins to MMC. They use hard chrome (not chrome on stainless).
I have always replaced with hard chrome.
