23 registered members (Stewart S, John V6, RedThree, Viper, keithA, Jon G4LJW, CooperMan, Mark H, Ron C, Ian Wegg, Robbie, HeadlessBlue, SCX358G, Cuna2016, Berlin, JBu1, DJC, JohnHarris, V8Dave, Tim Crump, nick w, madmax, ChrisP),
200
guests, and 17
spiders. |
Topics40,300
Posts671,322
Members7,333
Most Online1,033 Dec 28th, 2019
Re: S&S Stealth Air Filter Troubles
[Re: AlexKnoll]
#670660
03/11/20 01:41 PM
03/11/20 01:41 PM
Posts: 1,406 New River Valley, VA
rcmatt
I have heard the advice.... tighten it until it breaks and then back off 1/4 turn
[Re: LightSpeed]
#670674
03/11/20 03:11 PM
03/11/20 03:11 PM
Posts: 116 Las Vegas
JohnMat
Las Vegas
Where did the sheared off head of bolt go?
No sign of it. I assume it came off while driving as I have done about 1200 miles since I changed the air filter, and the idling problems are recent. It would have dropped between the cylinders, so I would guess it rolled out from there.
2020 M3W
[Re: AlexKnoll]
#670679
03/11/20 03:36 PM
03/11/20 03:36 PM
rcmatt
When I used to race sailboats, we would sometimes toss a nut or two onto another boat. Would drive the crew crazy trying to find where it went
[Re: rcmatt]
#670701
03/11/20 06:57 PM
03/11/20 06:57 PM
Posts: 265 CT, USA
06032
CT, USA
When I used to race sailboats, we would sometimes toss a nut or two onto another boat. Would drive the crew crazy trying to find where it went Rodger, where/what did you race? I'm an offshore, short-handed and distance and guy myself and pull a lot of RC duty in Newport and Long Island Sound.
'17 M3W: '08 Ural Gear-Up
[Re: AlexKnoll]
#670819
04/11/20 02:05 PM
04/11/20 02:05 PM
rcmatt
This was decades ago in the San Francisco area with one design boats. My dad raced Snipes, I started off with an "El Toro" which is an 8' dinghy and then in high school build an OK Dinghy which was a junior Olympic boat a wee bit smaller than a Finn.
[Re: AlexKnoll]
#671691
08/11/20 04:20 PM
08/11/20 04:20 PM
JohnMat
Las Vegas
For those fitting one of these filters, I recommend taking a close look at the alignment of the filter to the cylinder heads before fitting the chrome mount “arms” that support the air filter. In my case on re-assembling mine having fitted the replacement bolts and O-ring that attach the throttle body to the inlet manifold, it was clear that this alignment was well off. I suspect this was why one of my throttle body mount bolts bolts sheared off (see above) and caused the air leak, as tightening these up before must have put a lot of tension on the throttle bolts. I tried to follow kankeL’s advice on loosening the intake manifold bolts, but the lower ones are very hard to access and I could not get them loose, so instead I put a couple of bends in the mount to create an offset. It is soft enough steel that it bends easily. See below. Having finished re-assembly with copious loc-title, it is now idling and running great again. Phew! ![[Linked Image]](https://www.tm-img.com/images/2020/11/08/D9EE682F-7AEB-4092-98E1-EEED7BB01AAE.jpg)
2020 M3W
[Re: AlexKnoll]
#671693
08/11/20 04:35 PM
08/11/20 04:35 PM
Posts: 2,885 Port Orchard, WA.
LightSpeed
Port Orchard, WA.
When I installed mine I remember something about the offset distances and spacers maybe being involved? I installed and purchased mine in July 2019.
Stephen 2019 M3W, AR Stage 2
[Re: AlexKnoll]
#671729
08/11/20 07:21 PM
08/11/20 07:21 PM
Posts: 938 Evergreen, Colorado, USA
britmog
When I installed my Stealth Air Filter one bracket came made with the offset the other not, so they were fitted to the appropriate side!!!
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
[Re: britmog]
#671749
08/11/20 10:12 PM
08/11/20 10:12 PM
JohnMat
Las Vegas
When I installed my Stealth Air Filter one bracket came made with the offset the other not, so they were fitted to the appropriate side!!! Interesting. Mine were both supplied flat.
2020 M3W
