15 registered members (Taffmog, AlyMatt, Jeff D, DavidR, Spanner Juggler, mal, nippymog, Dab of oppo, SimonH, Hamwich, Alan Patterson, RichardV6, Image, Robin Askew, DickJ), 217 guests, and 23 spiders.
+8Rich 328
John V6 288
Alistair 155
Peter J 147
Main Beam Indicator (Blue)
by Tim Crump. 20/01/21 04:31 PM
Lockdown OCD
by John V6. 20/01/21 11:20 AM
Selling a Morgan in lockdown
by M3W55. 20/01/21 09:18 AM
classictravellinglug
gage.com
by +8Rich. 19/01/21 11:15 PM
Mini build...
by Grumpy2. 19/01/21 09:04 PM
Gas Smell
by KenShapiro. 19/01/21 06:58 PM
Ball Joint removal tool
by Bluesman. 19/01/21 05:55 PM
TOK 258 drawings
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
Boddam and Ravenscraig
First post
dodol, John Welch, CityGarage, Uzi, 1thebeano
7333 Registered Users
Topics40,301
Posts671,328
Members7,333
Most Online1,033
Dec 28th, 2019
Katanazz, Rho8
Page 4 of 4 1 2 3 4
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #670660
03/11/20 01:41 PM
03/11/20 01:41 PM
New River Valley, VA
rcmatt Offline
rcmatt  Offline
I have heard the advice.... tighten it until it breaks and then back off 1/4 turn
Rodger
2004 Plus 8 (wife's)
Re: S&S Stealth Air Filter Troubles [Re: LightSpeed] #670674
03/11/20 03:11 PM
03/11/20 03:11 PM
Las Vegas
JohnMat Offline
JohnMat  Offline
Las Vegas
Where did the sheared off head of bolt go?
No sign of it. I assume it came off while driving as I have done about 1200 miles since I changed the air filter, and the idling problems are recent. It would have dropped between the cylinders, so I would guess it rolled out from there.
2020 M3W
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #670679
03/11/20 03:36 PM
03/11/20 03:36 PM
rcmatt Offline
rcmatt  Offline
When I used to race sailboats, we would sometimes toss a nut or two onto another boat. Would drive the crew crazy trying to find where it went
Rodger
Re: S&S Stealth Air Filter Troubles [Re: rcmatt] #670701
03/11/20 06:57 PM
03/11/20 06:57 PM
CT, USA
0
06032 Offline
06032  Offline
CT, USA
Rodger, where/what did you race? I'm an offshore, short-handed and distance and guy myself and pull a lot of RC duty in Newport and Long Island Sound.
'17 M3W:
'08 Ural Gear-Up
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #670819
04/11/20 02:05 PM
04/11/20 02:05 PM
rcmatt Offline
rcmatt  Offline
This was decades ago in the San Francisco area with one design boats. My dad raced Snipes, I started off with an "El Toro" which is an 8' dinghy and then in high school build an OK Dinghy which was a junior Olympic boat a wee bit smaller than a Finn.
Rodger
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #671691
08/11/20 04:20 PM
08/11/20 04:20 PM
Las Vegas
JohnMat Offline
JohnMat  Offline
Las Vegas
For those fitting one of these filters, I recommend taking a close look at the alignment of the filter to the cylinder heads before fitting the chrome mount “arms” that support the air filter. In my case on re-assembling mine having fitted the replacement bolts and O-ring that attach the throttle body to the inlet manifold, it was clear that this alignment was well off. I suspect this was why one of my throttle body mount bolts bolts sheared off (see above) and caused the air leak, as tightening these up before must have put a lot of tension on the throttle bolts.
I tried to follow kankeL’s advice on loosening the intake manifold bolts, but the lower ones are very hard to access and I could not get them loose, so instead I put a couple of bends in the mount to create an offset. It is soft enough steel that it bends easily. See below.
Having finished re-assembly with copious loc-title, it is now idling and running great again. Phew!
2020 M3W
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #671693
08/11/20 04:35 PM
08/11/20 04:35 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
When I installed mine I remember something about the offset distances and spacers maybe being involved? I installed and purchased mine in July 2019.
Stephen
2019 M3W, AR Stage 2
Re: S&S Stealth Air Filter Troubles [Re: AlexKnoll] #671729
08/11/20 07:21 PM
08/11/20 07:21 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
When I installed my Stealth Air Filter one bracket came made with the offset the other not, so they were fitted to the appropriate side!!!
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Re: S&S Stealth Air Filter Troubles [Re: britmog] #671749
08/11/20 10:12 PM
08/11/20 10:12 PM
Las Vegas
JohnMat Offline
JohnMat  Offline
Las Vegas
Interesting. Mine were both supplied flat.
2020 M3W
Page 4 of 4 1 2 3 4
