15 registered members (GARYMYNARD, Ray, John V6, rockabilly john, DirkM, Image, JoeSpeetjens, IMHO, Craig Jezz, NelsonG, 2017 Betty, +8Rich, Hamwich, PaulV, Bourbonmog),
147
guests, and 16
spiders. |
Jigsaw
by David_E. 24/01/21 03:49 PM
Topics40,333
Posts672,056
Members7,333
Most Online1,033 Dec 28th, 2019
Re: Aero SS - passenger window failure!
[Re: taffy]
#671850
09/11/20 04:22 PM
09/11/20 04:22 PM
Posts: 8,086 Hampshire
Alistair
Smile, it confuses them
Hampshire
The door cards on mine are held down with the plug/pins along the bottom edge and to get them out you need to get under them and pull them like a thumb tack or drawing pin away from the door frame. To do this you need a v-claw shape but one that spreads the load. The dealer had one of these as they do it often. I am afraid I do not have one.
Just time to burn a little more petrol before dinner.
[Re: taffy]
#671855
09/11/20 04:44 PM
09/11/20 04:44 PM
Posts: 1,280 Zurich, Milan
Ale_72
Zurich, Milan
If somebody decides to dismantle the panel, please a few pics of the process. I'd really be willing to do it (and maybe replace the speakers) but I am not so brave without a proper visual guide.
2010 Violet Aero Supersports | 2010 White Boxster Spyder
[Re: taffy]
#671857
09/11/20 04:59 PM
09/11/20 04:59 PM
taffy
Thanks all for the responses. Ale- can you point me to where the diagrams are located please? Kevin - those items on Amazon look worth a punt! If not the chisel is at hand! Thanks T
02 Aero 8 S1 11 Aero 8 SS 13 Defender 17 Q7 18 Range Rover Vogue 20 Defender 110S 1960 XK150 DHC
[Re: taffy]
#671968
10/11/20 01:25 PM
10/11/20 01:25 PM
Alistair
Hampshire
Please excuse this - not meant in a rude manner as other people will have more experience than me. Just trying to share what I watched on mine being taken apart. The tools you highlight are not what I would use having seen the dealers tools. They are exactly the pointy things that will rip the leather due to the pressure area compared to the force needed. The items I watched in use were far wider to spread the load. So looking in the Amazon pool I suspect it was the part in the top right corner with a thin cut made down from the top centre to let it straddle the pin. https://www.amazon.co.uk/BQTQ-Pieces-Removal-Retainer-Installer/dp/B08DFN7WB6Also the little pins often die on engagement so it's helpful to have some spares. Morgan wanted £3 each for them!
