Morgan Aero 8
15 registered members (HeadlessBlue, carchick, CBY, Berlin, JMcL, DavidR, DCH, rcmatt, Hamwich, Frank K, Alan_Bass, planenut, SimonH, deano, M3W55), 145 guests, and 19 spiders.
+8Rich 387
John V6 301
Alistair 172
Peter J 132
Wanted M3W car cover
by donaldosaurus. 28/01/21 04:05 PM
Replacement door hinge fasteners
by JimV6. 28/01/21 02:32 PM
Fancy the other half?
by M3W55. 28/01/21 02:05 PM
Classic Engines: Briggs and Stratton
by Hamwich. 28/01/21 12:44 PM
Before I bought my first Morgan...........
by DaveW. 28/01/21 12:11 PM
Fuel pump problem
by jaypee. 28/01/21 09:05 AM
Some very expensive Morgans
by JohnMat. 27/01/21 10:23 PM
Another High Level brake light
Morgan puzzle made to order
TOK 258 drawings
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
bear65, Mogster +4, JimV6, IainG, Ollie
7346 Registered Users
Topics40,364
Posts672,712
Members7,346
Most Online1,033
Dec 28th, 2019
Hiwex
Indy Aero Service #673236
17/11/20 04:58 PM
17/11/20 04:58 PM
South Yorks
Clipper Offline OP
Clipper  Offline OP
South Yorks
It’s a big problem getting the S5 to the nearest Morgan garage for its service so thinking about a local classic/sports specialist (IK Classics) next service. They do lots of varied high end and classic stuff - also some classic Morgan’s.
Does anyone use an independent garage?
What are the potential problems and is there anything to be aware of that a Morgan dealer would sort that an Indy garage might miss?
Does the wing have to come off for a service?
2017 Ravenblau Blue Aero
2020 Lapis Blue Plus 6 evil You know it makes sense! thinking
Re: Indy Aero Service [Re: Clipper] #673242
17/11/20 05:43 PM
17/11/20 05:43 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
I don't use an independent...
There is so much that is a bit "left field" about the Aeros that I simply wouldn't feel comfortable. It may be a BMW engine and box, but the engine management computer has Morgan elements overlaid.
My local BMW specialist said, after hooking up to a BMW ECU diagnostic computer...no thanks.
A specialist is unlikely to have the Morgan service check sheet for the model, there are oddities not found on other cars and they could be missed, like greasing the propshaft UJ and splines...
Also, sourcing anything needed from Morgan is hard enough for a Morgan dealer, for an independant I suspect it would be harder.
The wings don't need to come off until 60,000 miles for a plug change.
My Aero Plus 8 has been serviced by the factory or by Williams since I purchased it in 2016. It is a 90 min drive and they need the car for 2 days, but they do provide a courtesy car, included in the service price.
Last thought, I wouldn't by an Aero or CX based Morgan that had been serviced outside the Morgan dealer world. I suspect that other Morgan owners might feel the same. The trads are different.
V8s are best....
Tarka the 'Otter Mog....2014 Plus 8
AMG C63 Estate.
Re: Indy Aero Service [Re: Clipper] #673243
17/11/20 05:44 PM
17/11/20 05:44 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
You've got Ledgerwood to the east or Oakmere to the west, can't they fit you in ?
Re: Indy Aero Service [Re: Clipper] #673254
17/11/20 06:15 PM
17/11/20 06:15 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Or the factory.
What PeterJ said.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Indy Aero Service [Re: Clipper] #673287
17/11/20 09:33 PM
17/11/20 09:33 PM
Sevenoaks,Kent
Viper Offline
Sir S1'a'lot
Viper  Offline
Sir S1'a'lot
Sevenoaks,Kent
Definitely wouldn’t use an Indy for the Aero for reasons above. Not a chance.
Not sure if I’d use one on the trad either.
2000 Plus 8 4.6
2002 Aero 8 S1
Re: Indy Aero Service [Re: Clipper] #673408
18/11/20 03:33 PM
18/11/20 03:33 PM
South Yorks
Clipper Offline OP
Clipper  Offline OP
South Yorks
Better stick with Ledgerwood on the Aero. Always had the Plus Four serviced by local garages - never failed an MOT and runs fine and is reliable so not sure what a Morgan dealer would do better.
Re: Indy Aero Service [Re: Clipper] #673424
18/11/20 05:23 PM
18/11/20 05:23 PM
Lancashire
RobCol Offline
RobCol  Offline
Lancashire
If it was a Porsche or Ferrari id be happy going to a specialist garage who had experience of them rather than a Main Stealer, but a local garage would be unlikely to have worked on an Aero.
Maybe full Morgan specialist service history isnt as important on a Trad especially an older one, however a full Morgan service history does look good to buyers if you ever sell.
Rob
4/4 Sport Grey
Re: Indy Aero Service [Re: Clipper] #673445
18/11/20 08:01 PM
18/11/20 08:01 PM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
Some of the elements on an Aero can be done by an Indie but I would be careful of elements that are quite specific.
Electronics are quite heavily custom and parts not easy to find
Dashboard removal and changes require the hands of a 6 year old and knowledge of how to jam the cables back
Access around the engine bay needs things done in the right order.
All the AirCon and radiator area needs careful handling as the pipes are quite custom I believe
The rose joints in the rear suspension need some resources.
Brakes pads or disc, nah.
My local garage also know how to MoT my Aero which does require a degree of understanding. Try holding the emission test probe up a 4 inch sidepipe and see what reaction you get!
The windscreen wipers have never ever parked effectively so new wiper blades prior to the MoT are always handy and they remember to do them.
Either way I would try and build a good relationship with one of your local dealers or a specialist like Simon.
Just time to burn a little more petrol before dinner.
Re: Indy Aero Service [Re: Clipper] #673466
18/11/20 10:00 PM
18/11/20 10:00 PM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
Probably a bit far away David, but Mark Middleton often works on Aero 8 - ex-MMC mechanic.
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'06 Saab 9-3 Convertible
Re: Indy Aero Service [Re: Clipper] #673493
19/11/20 08:05 AM
19/11/20 08:05 AM
YORK
KEVFITZ Offline
KEVFITZ  Offline
YORK
I think James BW uses Mark..for his scruffy S1..
He travels from the Northeast and has a short mini break whilst car being serviced.
Also handy for Factory visit while being serviced.
