1 registered members (DJC),
228
guests, and 14
spiders. |
Topics40,308
Posts671,605
Members7,333
Most Online1,033 Dec 28th, 2019
What procedure to remove front brake drum - 53 p4
#674018
21/11/20 05:08 PM
21/11/20 05:08 PM
Posts: 53 UK
SCX358G
UK
I have a 1953 plus 4 with steel wheels. I went to remove the front offside brake drum today, but was confused (easily done!). Loosened the brake adjust, took the wheel off. Expected to see one or two countersunk screws that needed to be undone to allow the drum to come off - but I could not see those at all. Pressed on anyway, hitting the drum in various directions with a heavy hammer and a block of wood. The drum rotates so the brakes are not frozen. But of coursse it does not want to coe off. y plan is to use a hub puller tomorrow but `maybe I just can't see the countersunk screws under the paint. Are there any drums that don't have these countersunk screws? Photo attached hopefully. Do I need to remove the big nut on the axle? I was assuming this was just a dust cover. https://www.tm-img.com/image/tsSp4https://www.tm-img.com/image/tsLut![[Linked Image]](https://www.tm-img.com/images/2020/11/21/MorganPlus4FlatradFrontDrum1.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/11/21/MorganFlatradFrontDrum2.jpg)
Dave Blue 4/4 1969, Green +4 1953
Re: What procedure to remove front brake drum - 53 p4
[Re: SCX358G]
#674022
21/11/20 05:32 PM
21/11/20 05:32 PM
Posts: 2,729 Northants, UK
TBM
Northants, UK
That's what I'd expect too. The rear drums certainly have two.
1972 4/4 4 seater - 3G Morganeer Too many ratty motorbikes
[Re: SCX358G]
#674029
21/11/20 05:59 PM
21/11/20 05:59 PM
Posts: 3,187 Yorkshire
Yorkshire
Looks like the version where you have to carefully unscrew the soft alloy nut (very fine soft thread) you can see, this then gives access to the castellated inner nut with a split pin through it, drive the pin out & remove nut, may be a thick washer behind, then the drum should wriggle off
[Re: SCX358G]
#674040
21/11/20 07:17 PM
21/11/20 07:17 PM
SimonH
The hub and drum are one piece on cars of that era.
You have to remove the aluminium dust cover nut, and then remove the split pin and undo the hub nut
You can then pull the hub and drum off The wheel bearings are not taper roller type and have a sized spacer between them to set preload, so a degree of knowledge is needed to tighten them back up
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
[Re: SimonH]
#674041
21/11/20 07:20 PM
21/11/20 07:20 PM
Posts: 53 UK
SCX358G
UK
Many Thanks, I''ll give the hub nut a go in the morning.
Ihttps://www.gomog.com/allmorgan8.html.
Is the preload procedure documented somewhere ?
