4 registered members (simonjrw, Bilymog, ChrisConvertible, Esprit), 148 guests, and 19 spiders.
+8Rich 346
John V6 284
Alistair 167
Peter J 146
Damaged Plus6
by brownbaker. 22/01/21 11:31 PM
Wanted - 3 Wheeler / Aero models
by NickCW. 22/01/21 07:04 PM
Corrosion protection
by Uzi. 22/01/21 06:53 PM
Driving Simulators
by JB62. 22/01/21 04:07 PM
M3W Aero Racing Luggage Rack
by Jonathan G. 22/01/21 02:57 PM
Aero Series 5 Headlamp Convertors
by The Flitting. 22/01/21 11:47 AM
Space haggis
by Gordon D. 22/01/21 10:42 AM
Morgan puzzle made to order
TOK 258 drawings
Two Approaches to the Easy Up Hood Stay
Vaccine is totally safe
Boddam and Ravenscraig
dodol, John Welch, CityGarage, Uzi, 1thebeano
7333 Registered Users
Topics40,318
Posts671,800
Members7,333
Most Online1,033
Dec 28th, 2019
No Birthdays
What procedure to remove front brake drum - 53 p4 #674018
21/11/20 05:08 PM
21/11/20 05:08 PM
UK
SCX358G Offline OP
SCX358G  Offline OP
UK
I have a 1953 plus 4 with steel wheels.
I went to remove the front offside brake drum today, but was confused (easily done!).
Loosened the brake adjust, took the wheel off. Expected to see one or two countersunk screws that needed to be undone to allow the drum to come off - but I could not see those at all. Pressed on anyway, hitting the drum in various directions with a heavy hammer and a block of wood. The drum rotates so the brakes are not frozen. But of coursse it does not want to coe off. y plan is to use a hub puller tomorrow but `maybe I just can't see the countersunk screws under the paint. Are there any drums that don't have these countersunk screws? Photo attached hopefully. Do I need to remove the big nut on the axle? I was assuming this was just a dust cover.
https://www.tm-img.com/image/tsSp4
https://www.tm-img.com/image/tsLut
Dave
Blue 4/4 1969, Green +4 1953
Re: What procedure to remove front brake drum - 53 p4 [Re: SCX358G] #674022
21/11/20 05:32 PM
21/11/20 05:32 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
That's what I'd expect too. The rear drums certainly have two.
1972 4/4 4 seater - 3G Morganeer
Too many ratty motorbikes
Re: What procedure to remove front brake drum - 53 p4 [Re: SCX358G] #674029
21/11/20 05:59 PM
21/11/20 05:59 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Looks like the version where you have to carefully unscrew the soft alloy nut (very fine soft thread) you can see, this then gives access to the castellated inner nut with a split pin through it, drive the pin out & remove nut, may be a thick washer behind, then the drum should wriggle off
Re: What procedure to remove front brake drum - 53 p4 [Re: SCX358G] #674035
21/11/20 06:41 PM
21/11/20 06:41 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
On mine (steel wheels but discs) that procedure would remove the entire front hub from the stub axle.
Re: What procedure to remove front brake drum - 53 p4 [Re: SCX358G] #674040
21/11/20 07:17 PM
21/11/20 07:17 PM
SimonH Online content
SimonH  Online Content
The hub and drum are one piece on cars of that era.
You have to remove the aluminium dust cover nut, and then remove the split pin and undo the hub nut
You can then pull the hub and drum off
The wheel bearings are not taper roller type and have a sized spacer between them to set preload, so a degree of knowledge is needed to tighten them back up
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: What procedure to remove front brake drum - 53 p4 [Re: SimonH] #674041
21/11/20 07:20 PM
21/11/20 07:20 PM
UK
SCX358G Offline OP
SCX358G  Offline OP
UK
Many Thanks, I''ll give the hub nut a go in the morning.
Ihttps://www.gomog.com/allmorgan8.html.
Is the preload procedure documented somewhere ?
Dave
Re: What procedure to remove front brake drum - 53 p4 [Re: SCX358G] #674044
21/11/20 07:26 PM
21/11/20 07:26 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
Thanks Jon and Simon. Every day a learning day smile
