0 registered members (), 184 guests, and 13 spiders.
+8Rich 172
John V6 164
M3WUSAPilot, Murman, motowfo, Ian Hubbard, csabi
7558 Registered Users
Oil pressure sensor for Sigma 4/4
by Heinz. 16/06/21 09:17 PM
MMC Bonnet stays
by Paul F. 16/06/21 08:38 PM
Choke cable - A Question
by DaveK. 16/06/21 05:36 PM
A bit lighter in the back pocket
by Reevie. 16/06/21 02:20 PM
Remove silencer
by TimG. 16/06/21 08:23 AM
Volvo C 70
by Moggo. 16/06/21 06:31 AM
FolkMog Northumberland Tour June 2021
by BuyBritish. 16/06/21 06:07 AM
Porpoise on the bow.
Replacing the floor boards _MOG414
Dolphins ahoy!
MOG414_ one-off 14.5ins steering wheel
Relays
Topics41,439
Posts693,940
Members7,558
Most Online1,033
Dec 28th, 2019
No Birthdays
morgan 4/4 petrol tank sender #674058
21/11/20 09:15 PM
21/11/20 09:15 PM
manawatu new zealand
bruce Offline OP
bruce  Offline OP
[align:center][/align]have a problem with fuel gauge car had been sitting over winter now gauge shows empty when full , have measured resistance to chassis shows 70 ohms was wondering if the logic should be the other way round eg zero resistance on full tank ? checked and cleaned the sender wiring also the earth to chassis , looks like the regulator is connected to the fuel and temperature circuits and should be ok as the temperature gauge works ok hoping someone has come across this , car is 1978 thanks bruce
Re: morgan 4/4 petrol tank sender [Re: bruce] #674061
21/11/20 09:43 PM
21/11/20 09:43 PM
Pitt Meadows, B.C. Canada
Dave Collis Offline
Dave Collis  Offline
Pull the sender out of the tank and make sure the float has not filled up with gas, usually happens with the old brass floats but I have seen the plastic ones do it also.
When you have the sender out, move the float arm...does the gauge position change?
I had one where the float arm had seized in the body of the sender.
1963 4/4 SER.V. B876 Owned since 1968
1965 Anglia 124E
Re: morgan 4/4 petrol tank sender [Re: bruce] #674189
22/11/20 05:06 PM
22/11/20 05:06 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Another quick check is to remove sender connection and touch to chassis. With ignition on gauge should rise slowly towards full assuming you have bi-metallic gauge. 70 ohms does sound high for full tank.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: morgan 4/4 petrol tank sender [Re: bruce] #674198
22/11/20 05:50 PM
22/11/20 05:50 PM
Staffordshire
IvorMog Offline
IvorMog  Offline
Staffordshire
Richard, I might be barking up the wrong tree here but the VDO lever type sender registers empty with minimum resistance (actually states 3 ohms) and full at maximum resistance (states 180 ohms).
So on that theory wouldn't grounding the wire give zero (or very low) resistance and therefore read empty.
Carrying on from that theory, if you simply disconnected the sender connection it would give a very high resistance and hence a full scale deflection on the instrument i.e. full.
Caveat 1. That's assuming a VDO Lever type sender. The VDO tube type sender is the other way round and I have no idea if Smiths senders are the same but it does suggest that we need to know what type of sender and instrument is fitted here.
Caveat 2. I've mentioned before that electrics are not my strong point.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Re: morgan 4/4 petrol tank sender [Re: IvorMog] #674220
22/11/20 06:50 PM
22/11/20 06:50 PM
SimonH Offline
SimonH  Offline
Vdo senders work the opposite way around to the smith’s senders...
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: morgan 4/4 petrol tank sender [Re: IvorMog] #674254
22/11/20 08:47 PM
22/11/20 08:47 PM
RichardV6 Offline
RichardV6  Offline
I assumed a '78 car would have a bi-metallic gauge Bob given the age and mention of an instrument voltage regulator. If so these require max current flow to actuate needle towards full hence minimum resistance. Apologies if I have made the wrong assumption.
Re: morgan 4/4 petrol tank sender [Re: bruce] #674293
23/11/20 08:25 AM
23/11/20 08:25 AM
Staffordshire
IvorMog Offline
IvorMog  Offline
Staffordshire
Richard, I think you probably made the right assumption as I didn't notice the date.
Might be worth double checking but I suspect you are right.
Bob
2009 Black Roadster
Re: morgan 4/4 petrol tank sender [Re: bruce] #674296
23/11/20 08:45 AM
23/11/20 08:45 AM
RichardV6 Offline
RichardV6  Offline
If you go back further Bob vehicles had moving iron fuel gauges with two coils. These relied on max resistance when full and had no need for voltage regulator. Easy to identify because you got an instant needle reading when ignition switched on. Both types were used on Series Land Rovers with the change to bi-metallic in mid 1967, to add some chronology.
As you can imagine there are numerous LR forum posts with owners querying why their gauges are working backwards innocent
Re: morgan 4/4 petrol tank sender [Re: bruce] #675113
28/11/20 01:52 AM
28/11/20 01:52 AM
bruce Offline OP
bruce  Offline OP
just figured out messaging thanks to all see post in maintenance
