Topics40,290
Posts671,046
Members7,327
Most Online1,033 Dec 28th, 2019
Re: morgan 4/4 petrol tank sender
[Re: bruce]
#674061
21/11/20 09:43 PM
21/11/20 09:43 PM
Posts: 45 Pitt Meadows, B.C. Canada
Dave Collis
Pull the sender out of the tank and make sure the float has not filled up with gas, usually happens with the old brass floats but I have seen the plastic ones do it also.
When you have the sender out, move the float arm...does the gauge position change?
I had one where the float arm had seized in the body of the sender.
1963 4/4 SER.V. B876 Owned since 1968 1965 Anglia 124E
[Re: bruce]
#674189
22/11/20 05:06 PM
22/11/20 05:06 PM
Posts: 3,411 East Harling, Norfolk UK
Another quick check is to remove sender connection and touch to chassis. With ignition on gauge should rise slowly towards full assuming you have bi-metallic gauge. 70 ohms does sound high for full tank.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1960 Velocette Venom
[Re: bruce]
#674198
22/11/20 05:50 PM
22/11/20 05:50 PM
Posts: 1,304 Staffordshire
IvorMog
Staffordshire
Richard, I might be barking up the wrong tree here but the VDO lever type sender registers empty with minimum resistance (actually states 3 ohms) and full at maximum resistance (states 180 ohms).
So on that theory wouldn't grounding the wire give zero (or very low) resistance and therefore read empty.
Carrying on from that theory, if you simply disconnected the sender connection it would give a very high resistance and hence a full scale deflection on the instrument i.e. full.
Caveat 1. That's assuming a VDO Lever type sender. The VDO tube type sender is the other way round and I have no idea if Smiths senders are the same but it does suggest that we need to know what type of sender and instrument is fitted here.
Caveat 2. I've mentioned before that electrics are not my strong point.
Bob
1999 4/4 2 litre Zetec
[Re: IvorMog]
#674220
22/11/20 06:50 PM
22/11/20 06:50 PM
SimonH
Vdo senders work the opposite way around to the smith’s senders...
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
[Re: IvorMog]
#674254
22/11/20 08:47 PM
22/11/20 08:47 PM
I assumed a '78 car would have a bi-metallic gauge Bob given the age and mention of an instrument voltage regulator. If so these require max current flow to actuate needle towards full hence minimum resistance. Apologies if I have made the wrong assumption.
[Re: bruce]
#674293
23/11/20 08:25 AM
23/11/20 08:25 AM
IvorMog
Staffordshire
Richard, I think you probably made the right assumption as I didn't notice the date.
Might be worth double checking but I suspect you are right.
Bob
[Re: bruce]
#674296
23/11/20 08:45 AM
23/11/20 08:45 AM
If you go back further Bob vehicles had moving iron fuel gauges with two coils. These relied on max resistance when full and had no need for voltage regulator. Easy to identify because you got an instant needle reading when ignition switched on. Both types were used on Series Land Rovers with the change to bi-metallic in mid 1967, to add some chronology. As you can imagine there are numerous LR forum posts with owners querying why their gauges are working backwards
